Compatibility issue?
  • RooTV
    • Apr 2020
    • 128
    Hi there
    I have a LG 55LB5820 - TB and need to replace the power supply.
    The power supply I have is EAX65423801 rev 2.0
    I have found a EAX65423801 (2.1) from an LG 50LB5610 and the markings on it are:
    PCB: EAX65423801 (2.1)
    REV2.0
    2013. 12.10
    Would this be compatible? Not sure as it is a different size tv
    It is the same part number but different revision?
    Is that just a software difference or can it be a part difference?
  • neilc6
    • Nov 2015
    • 1550
    Re: Compatibility issue?
    That is the blank PCB part number and it could be populated differently for different models. The connectors may be different. Different size tvs will have different configuration and voltages for the LED strips so likely it will power the main board but not the LED backlight.
    • nomoresonys
      • 12331
      • U.S.
      Those two boards look pretty identical, I would be surprised if it DIDN'T work.
      • RooTV
        • Apr 2020
        • 128
        Ok thanks
        • diif
          • Feb 2014
          • 6978
          • England
          There's 10 LEDs different between those two models, they will be putting out different voltages.
          • handsworth
            • Oct 2015
            • 175
            They both look identical except one transformer is white and the other is blue. However there is a difference in voltage. Stay with the one you have
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
              by ugamazing
              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
              12-17-2024, 07:05 PM
            • DynaxSC
              Weired MSI B560M PRO (MS-7D20) - not starting with 11-th gen. CPU, 10-th gen. OK
              by DynaxSC
              I have a very weired problem with MSI B560M PRO (MS-7D20), board is upgraded to the latest BIOS version v1.9.
              The board is normally starting with 10-th gen. CPU, ie. Intel Comet Lake i5-10600K and Celeron G5905.
              However if I install a 11-th gen. Rocket Lake i5-11600K the board powers up, but is immediately stuck on CPU LED, not progressing further. Debug card shows FF, and after restart with long short of Power Button: FE, which is as usually of no help (Reserved for future AMI error codes).
              According to MSI compatibility site the board supports...
              11-04-2024, 04:04 PM
            • shahnld
              Lenovo legion 5 pro startup issue
              by shahnld
              Good day Experts
              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
              08-24-2025, 12:31 PM
            • ahmarzo
              Acer laptop battery draining issue
              by ahmarzo
              Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
              Help me to diagnose this issue as there is no shortage in the inputs MOSFET
              08-02-2025, 06:39 AM
