Vizio D55-f2 backlight/power supply 20v/24v rail output high 26v
  • Nonya333
    • Aug 2018
    • 19
    no backlight on set.
    the 20v rail fuse on the mainboard was blown. i replaced and backlight and tv worked for about a day before flickering and out again
    input on mainboard for led should be 20v to fuse but is reading 26v at input and <3v output.
    power supply output should be 20v/24v from connector and output is reading >25.6-26v
    any suggestions?
    i also tested backlights with tester and they were all same steady voltage and on
    output switch transisters seem to be reading fine in circuit.
    will check capacitors esr next
  • Nonya333
    • Aug 2018
    • 19
    Re: Vizio D55-f2 backlight/power supply 20v/24v rail output high 26v
    is it normal for there to be aboit 26V on the 20v/24v power line and if not what would cause it to be so high?
    • dokma
      • Aug 2017
      • 39
      • Croatia
      You can check my thread where I've managed to fix 19V spikes on a 5.3V rail. My issue was a faulty switching voltage regulator on the power supply. Perhaps your issue is something similar.
      https://www.badcaps.net/forum/showthread.php?p=991809
      • Nonya333
        • Aug 2018
        • 19
        i will check it out. thank you for reply.
        • Nonya333
          • Aug 2018
          • 19
          on the ps board on output there is a power mosfet to the 20/24v power rail/connector to main.
          coming in from transformer there are 3 double schotky rectifiers.
          there is a heat sink with bridge rectifier and what i am guessing is voltage regulator since i cannot see untill i desolder heat sink.
          was your voltage regulator on hot side?
          • Nonya333
            • Aug 2018
            • 19
            there are 2 outputs to the led lights from the mainboard.
            the one with less pins still shows half as positive and half as negative but the output is reversed
            positive is showing up on negative and negative on positive
            i poked around everywhere i am thinking it is the ic chip that controls mosfets
            any help would be greatly appreciated
            thanks
            • R_J
              • 9535
              How about posting some high quality, in focus pictures so we know what we are dealing with? It seems the led's are driven from the main board so I doubt the power supply is at fault, more likely you have an open led in the panel. If the power supply provides 24v and it reads 26v it is likely due to the fact the backlights are not working. If they were working the higher current draw would lower the voltage to 24v
              • Nonya333
                • Aug 2018
                • 19
                please excuse the hackjob of the 15ohm resistor and wire for a fuse i could not find another 5R1 resistor.
                when i plug in the connector cn6101 upside down with positive on neg side etc there is backlight and display is working however half does look brighter.
                cn6101 is where polarity is reversed
                • Nonya333
                  • Aug 2018
                  • 19
                  i also removed mosfet pq4804 because i am getting inconsistent reading than other mosfets and pq4807 reading slightliy lower resistance as well
                  • Nonya333
                    • Aug 2018
                    • 19
                    i tested leds with tester to led directly without pcbs and on cn6102 the voltage was higher but each line from connector to strip produced steady voltage on all strips
                    i did not remove panel to access strips because i am not that good at removing and reassembling lcd without damage
                      https://www.badcaps.net/forum/attach...9&d=1601919019
                      Is that Brown Green Silver Gold resistor you installed? That is 0.15 Ohms.
                      That is current sensing resistor connected to the Source pin of the MOSFET's PQ4501, 4502 so you cannot just put in any value resistor it's place.
                      Was the 5R1 resistor bad? What are the color band of the resistor?
                      Where is the wire for the fuse?
                      • Nonya333
                        • Aug 2018
                        • 19
                        top circled smd is the resitor i replaced. there is another 5r1 smd slightly lower.
                        the circle on right is where i put a jumper wire for the smd fuse. difficult to see it is a tiny piece of wire
                          The 5R1 resistor close by is part of the RC snubber network for the Diode PD45??.
                          I cannot see how you can have a SMD resistor and SMD fuse on just two solder pads, you are not making any senses to me.
                          • Nonya333
                            • Aug 2018
                            • 19
                            there is no smd fuse i just soldered a jumper wire
                            • Nonya333
                              • Aug 2018
                              • 19
                              and replaced a 5r1 that was bad with the bigger 5ohm smd
                              • Nonya333
                                • Aug 2018
                                • 19
                                what could cause the polarity to be reversed at cn6101?
                                • Nonya333
                                  • Aug 2018
                                  • 19
                                  bad pu4501? i cannot find data sheet for this ic
                                    1) OK, i see the Fuse F4501 now.
                                    2) When did the fuse blow?
                                    3) Was the 5R1 resistor blown open circuit?
                                    4) Need to see the pictures of the whole backside the TV showing how all the boards and the backlight LED's are connected together.
                                    • Nonya333
                                      • Aug 2018
                                      • 19
                                      the fuse was blown prior to me touching anything. it was a white smd with the letter "Y". i also could not find info on that.
                                      i found a bigger package smd fuse rated at 2a and replaced that. the set worked for approximately 5-10 hours and then fuse blew again
                                      the 5r1 resistor was showing up as a capacitor on my cheap esr meter and showing higher resistance i believe. i still have it i will have to double check
                                        • 12123
                                        • U.S.
                                        You have to use the same type fuse that came out, it matters if it's a fast blow or a slow blow also.
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • прямо
                                          Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
                                          by прямо
                                          Just received it today from a friend.
                                          Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
                                          The same rail also does this when the PSU is in standby mode.
                                          https://ibb.co/5TBkg66
                                          The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
                                          What could have caused that?
                                          First time I have seen such behavior.
                                          3.3V and 5V rails don't have the same...
                                          02-19-2024, 09:52 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
