Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    Just received it today from a friend.
    Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
    The same rail also does this when the PSU is in standby mode.
    https://ibb.co/5TBkg66
    The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
    What could have caused that?
    First time I have seen such behavior.
    3.3V and 5V rails don't have the same symptom. No output when in standby mode.
    • 31285
    strange.
    if you put a load on the 12v rail does it still happen?
    all i can think of is energy from the stanby transformer being magnetically coupled to the 12v transformer if they are too close.
    if thats true then the current will be almost nothing
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      I found the under-volting problem, it was caused by one of the output caps having a high ESR. I replaced it and 12V is back to 12V.
      PSU can start without shutting down, but this DC leakage issue still exists.
      It also seems to settle around 750mV or so after being left alone in standby mode for awhile.
      ​​​​​​Other than the 12V DC fan that it comes with, I haven't test the rail with any load, but it's pretty stable at 11.99V ~ 12.00V​​​​​
      • bimole
        Weird behavior on 3.3V rail of a CORSAIR CX600
        by bimole
        A colleague gave me an apparently ill CORSAIR CX600.
        He told me that he heard a banging noise, and smelt the magic smoke.
        After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
        I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
        It's another story on the 3.3V rail...
        I have some devices to test deeply PSUs (scope, AC source, electronic load)...
        02-13-2025, 04:49 AM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • Novgorod
        Corsair SF450 PSU: can faulty -12V rail be removed?
        by Novgorod
        I have a Corsair SF450 SFX power supply with slight water damage. 5VSB is present and it turns on via the ATX PS_ON pin, but immediately goes into protection mode (relais clicks on and off). During the brief moment before protection kicks in, all power rails are present except the -12V rail, which also went low resistance (24 ohm). I don't know if protection mode is triggered by over current on -12V due to the low resistance (the current limit is only 0.36A on that rail according to spec) or simply because the voltage is not present. I removed the IC generating the -12V (54231 buck converter)...
        08-21-2024, 06:38 PM
      • Victor Moreira Silva
        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
        by Victor Moreira Silva
        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
        Well, my decice specs are the following:
        Model: Acer Nitro 5 AN517-54-55T5
        CPU: Intel Core i5-11400H
        GPU: NVIDIA GeForce GTX 1650
        Motherboard: GH51G LA-L181P Rev:1c
        The symptom:
        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
        05-26-2025, 10:49 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
