Samsung Un60F8000 Boot Loop
  • csmith
    • Aug 2014
    • 46
    This set powers up shows logo then displays snow before
    powering down and restarting. Controls including remote
    have no effect. Any advice would be appreciated. Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Samsung Un60F8000 Boot Loop
    Something is failing in the boot up process. it could be the NAND/eMMC or something connected like the wifi card.
      Did you open up the TV and inspect the inside of the TV and also try re-seating the cables?
      What Voltage testing have you done?
      Remove the cable between power supply board and the main board and inspect both end of the cable.
      Also attach good clear pictures of the whole backside of the TV showing all the boards.
      • neilc6
        • Nov 2015
        • 1550
        https://ebay.us/4jdmoQ
        Main board failures our service covers:
        TV turns on to Samsung smart TV logo then off and repeats
        Contact this seller as well https://ebay.us/rGn10Y
        • csmith
          • Aug 2014
          • 46
          Cables were all reseated
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4456
            • Italy - Milan
            Hi.. i agree with diif, can you put the BN41-xxx model code of the mainboard?
            • csmith
              • Aug 2014
              • 46
              Here it is BN94-06616A .Thanks
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4456
                • Italy - Milan
                I said BN41-xxx it's in the corner
                • csmith
                  • Aug 2014
                  • 46
                  My bad. BN41-01959
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4456
                    • Italy - Milan
                    Do you have a RT809 programmer?
                    • csmith
                      • Aug 2014
                      • 46
                      No i do not, i was thinking eprom issue as the set stays powered up with mainboard
                      disconnected.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4456
                        • Italy - Milan
                        I can't help you without programmer , remove the wifi & btooth modules, then retry, if nothing changes check psu-to-mainb. connectors for burnings, last option change mainboard.
                        • csmith
                          • Aug 2014
                          • 46
                          Tried those things no joy. Need to get a main. Thank you for your time it is much
                          appreciated. If i get running i'll let you know.
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            This is something worth doing for any and all ES, F, and H series samsung sets. Disconnect everything from the main board. We are talking about the T-con LVDS ribbon, speakers, IR, bluetooth, wifi everything except the power supply. The only thing connected should be the power supply. PLug it in and see what happens.
                            Check the backlight to see if it turn on and off every 10 seconds or so as your guide to see if the set still cycles. If it does not cycle anymore, start connecting 1 thing back at a time until you find the culprit. If it still cycles, disconnect the Power supply from the main board and check the backlight. Does the backlight and power supply still turn on and off? If so then we can start to look at your backlight and power supply as the source of the issue. If not then you confirmed your main board is the issue.
                            If you confirm the main board is the issue it could be hardware or software. If it's hardware then 1 of two things are going to have happened. Either an IC shorted and maybe caught fire, or you have cracked solder joints.
                            The first is a visual, so do a careful look over each IC component and check for burnt parts. If none are visible, take your multimeter and do random short checks near IC's. Check for shorts near the big IC's as well as Ic's located near inputs such as HDMI, ethernet, or inputs that were used and had other devices connected to them.
                            If no shorts are found and no burnt components are found visually, heat up the BGA chips under the heatsinks with hot air and see if that makes a difference. If not then you may indeed have a software failure as mentioned in some of the previous posts.
                            • csmith
                              • Aug 2014
                              • 46
                              Thanks for the reply. Will do a closer examination of the main board for shorts,set stays
                              powered up with cable from the mother board disconnected. Set cycles on-off with
                              motherboard connected to P.S. all other connections removed. Powers up,10 sec then
                              powers down led flashes 5 times then powers back up.
                              • retiredtech30
                                • Jun 2018
                                • 4
                                • us
                                Had the same problem with my samsung it goes into this boot loop and just keeps restarting turned out to be the IR board ribbon when i reseated mine problem was Gone.
                                • Nick's Tvs
                                  • Jan 2014
                                  • 621
                                  CSmith sounds like a main board issue. Have you tried applying heat as mentioned in my previous post?
                                  • Takeatry
                                    Yet another Samsung QLED Boot Loop
                                    by Takeatry
                                    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                    10-04-2024, 02:57 PM
                                  • torchzack
                                    Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                    by torchzack
                                    Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                    I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                    Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                    08-28-2023, 07:42 AM
                                  • NolesFan
                                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                    by NolesFan
                                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                    10-24-2024, 06:36 PM
                                  • eigma
                                    Samsung UN40H5003 boot loop every ~8 seconds
                                    by eigma
                                    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                    Main board: BN94-07592P / BN97-08922R...
                                    11-20-2024, 10:31 PM
                                  • blaster_
                                    Samsung UE49MU6105K - boot loop, horizontal lines
                                    by blaster_
                                    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                    06-22-2022, 05:19 PM
