I just want to share the fix of my Sony KDL-46XBR4. It had an intermittent milky white image, typical of a bad chroma chip. The T-CON board model is 404652HHC8LV1.8 from Samsung.
The chroma chip on the T-CON board is an ISL24005. This is a programmable one (through an I2C interface), but it has 4 input references (VREFL_L, VREFL_H, VREFU_L and VREFU_H).
Thanks to the designers of this T-CON board, all the tests points for VGMA1-VGMA18 are on the BACK side of the board. I had to measure the VGMA voltages on the front side at the vias going to the surface mount connectors.
As expected, the VGMA voltages were off while the problem happened. I traced down the problem to the 4 input reference voltages. They were easily measured at the top of the 4 capacitors (CG4-CG7) just below the chroma chip (ICG1). The 4 reference voltages were produced by a series of resistors on the bottom side of the board. Here are the measured voltages through the series resistors :
GND
RG24 (390 ohm) : 0.19 volt good, 0.01 volt bad (measured at CG7)
RG51 (0 ohm)
RG23 (10k ohm) : 6.14 volt good, 15.18 volt bad (measured at CG6)
RG 49 (0 ohm)
RG22 (2.7k ohm) : 10.23 volt good, 15.24 volt bad (measured at CG5)
RG50 (0 ohm)
RG21 (10k ohm) : 15.12 volt good, 15.31 volt bad (measured at CG4)
RG20 (390 ohm)
16v input
It turned out that the 10k ohm resistor (marked 01C in EIA-96 notation) at position RG23 was intermittently open. Later on I also found the 2.7k resistor at position RG22 with an intermittent problem. Replaced the two resistors and the TV set works like a new, with vivid colors.
The fix would also apply to the similar 404652FIX2HC6LV1.2 T-CON board also from Samsung, and to the following TV sets:
KDL-40WL135
KDL-40XBR4
KDL-40XBR5
XBR-46HX909
KDL-46W5000
KDL-46WL135
KDL-46XBR4
KDL-46XBR5
KDL-52XBR4
If you are aware of any other models not in my list please post them.
Thanks.
GND
RG51 (0 ohm)
RG 49 (0 ohm)
RG50 (0 ohm)
RG20 (390 ohm)
16v input
KDL-40WL135
KDL-40XBR4
KDL-40XBR5
XBR-46HX909
KDL-46W5000
KDL-46WL135
KDL-46XBR4
KDL-46XBR5
KDL-52XBR4
Thanks.
