Samsung UN65KU6300FXZA no picture
Re: Samsung UN65KU6300FXZA no picture
i did see on SHOPJIMMY.COM they were sell a kit for the main board but are sold out and also selling EEPROM's, not sure if that is the problem with mine but i guess it's worth a try.Comment
I look at the main board pictures, but it is not clear enough for me to read those small prints on the board when I zoom in.
At this point the problem looks to be in the T-CON section of the main board, may be it is not getting the T-CON switched 12V for the T-CON section to run, bad components.
Since we do not have the schematic for the main board, all you can do is visual inspection, get the spec sheet of the IC's so we can do Voltage testing on the IC's, resistance testing.
I do not know how much times and efforts you will want to put into this board to troubleshoot down to component level.Never stop learning
Not having any luck finding data sheets or schematics. The EEPROM Shopjimmy is selling is in location IC1104 and the ebay site says "The T-CON is built into this board". So i am guessing that this eeprom is part of the T-Con circuitry? Just wish i could test it to see if it is indeed bad.
https://www.ebay.com/itm/Samsung-BN9...-/274409445796Comment
https://www.badcaps.net/forum/attach...7&d=1597435827
That IC (with 3 inductors with 100 marking on top surrounding it) looks to be for T-CON LCD bias power supplies.
Can you read the P/N printed on top of the IC.
The main board you have has integrated T-CON circuits.Last edited by budm; 08-14-2020, 08:28 PM.Never stop learning
I wonder why SJ does not describe what bad symptom of the TV this EEPROM will fix.
I wonder if unplug TV from outlet, cool the EEPROM with freeze spray then power up the TV trick will work.Last edited by budm; 08-14-2020, 08:44 PM.Never stop learning
I know SJ used to describe the issue it solved but not doing it anymore? i can try to pick up a can of freeze spray tomorrow, do you happen to remember the name of the spray by chance?Comment
I use canned air duster (DustOff from COSTCO) upside down to get the coolant for cooling, any office supply should have similar products.Never stop learning
let us do more test on the main boards
1-put every things in place except the wifi socket keep it out ( to reduce load). don't forget the chassis screw of MB.
2- play HDMI signal on the set at the HDMI socket which remarked with ARC then turn on the set.. let see what will happen...
the purpose of this all... to let the set synced with other source in case the RF section had issue and it share same the 12V range with T-CON circuitComment
by stingerWhen I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by notallbadPlug in and backlights with Smart Tv powered by Tizen logo shows on screen
then nothing, no stby led or response to remote, no sound from hdmi input.
This has only 1 board, a 3in1_kant_su2.
Try a usb stick with update firmware from Samsung and usb stick just flashes a couple of times, recognises usb, but thats it.
Remove ribbon to panel, same results.
I believe the leds are in an array of 3 x 12 @3v/led, going by what led sets are being sold for this tv on ebay and aliexpress.
1 string of 12 leds, power supply in 84v, out... -
by DobsukHi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes... - Loading...
