LG 32LH500B - No power, no standby
  • JeffJ
    • Apr 2012
    • 189
    No power no standby LED.
    Fuse ok, 154-155V across the caps.
    Doesn't seem to be outputting 12v or 24v and thus no standby.
    Any ideas?
  • JeffJ
    • Apr 2012
    • 189
    Re: LG 32LH500B - No power, no standby
    I decided to remove the transformer to and wire in a separate supply to the 12v 24v and gnd on the secondary side and the tiv fires up and works perfect.
    So the issue is on the Primary side im just not good enough to figure out what.
    Any help would be great! thanks a lot!
      Can I see good clear straight shots picture of the whole bottom side of the board?
      • JeffJ
        • Apr 2012
        • 189
        sure here it is.
          I cannot read the P/N of that SMPS IC U0D1?.
          Can you tell me what it is?
          • JeffJ
            • Apr 2012
            • 189
            U0D1 is "LNK6777K"
              Originally posted by JeffJ
              U0D1 is "LNK6777K"
              OK, I look up the spec sheet, see attached PDF.
              BTW, is this really LG TV? It looks like Skyworth re-badged TV which is junk and they can charge more by putting LG tag on them.
              Also, is that Boost converter board or Buck converter board connected to bench power supply?
              • JeffJ
                • Apr 2012
                • 189
                OK, I will look up the spec sheet.
                BTW, is this really LG TV? It looks like Skyworth rebadged TV which is junk and they can charge more by putting LG tag on them.
                I'm sure its a re-badge, it feels very RCA like. It's not one of their flagships, but it is branded LG and has the LG software on it. I'm just looking to fix it on the cheap and give it to the local scouts to use in their club house.
                and the buck converter is also connected to the bench supply. I had to step 24v down to 12v. But it does indeed fully function when i bypass the primary side and power the secondary on the bench supply.
                I believe i found a service manual, but again I'm not skilled enough to utilize it.
                LG+32LH500B+Chassis+6M69N.pdf
                Edit" ill have al ook at the data sheet you sent see if i can figure out a place to start from. thanks
                  Just check DCV of the BP pin against S pin, it should be about 5.7V.
                  The spec sheet explain what each pin of the IC is for.
                  BTW, you are working in the HOT deadly side of the circuit so at least plug the TV into GFCI outlet and do not touch anything in the hot dies with your hands or body.
                  • JeffJ
                    • Apr 2012
                    • 189
                    Thanks Budm, I'll give it a go tomorrow and post back. My workshop is all GFI so thats covered.
                      BTW, what power consumption does it show on the back of the TV where the model number tag is?
                      • JeffJ
                        • Apr 2012
                        • 189
                        120vac 1.2A
                        • JeffJ
                          • Apr 2012
                          • 189
                          VDC of the BP pin against S pin is 2.7VDC SO assumption is the LNK6777K is faulty?
                            If you look at spec sheet figure #3, the BP pin is the output pin of the 5.75V internal Voltage regulator fed by Voltage from D pin, so check and see if you do have about 160VDC at the D pin.
                            Low Voltage reading on the BP pin can be due to bad internal regulator, too heavy load on the BP pin, so check the resistance between BP and Source pin to see what you get. Also check the bypass capacitor connected to the BP pin.
                            BTW, so the tag says 120VAC 1.2A, that will be 144VA, that power supply is not rated that high I am surprised it lasts that long.
                            • JeffJ
                              • Apr 2012
                              • 189
                              Resistence between BP and S is 68.4Kohm
                              Bypass cap doesnt appear to be bad is 460 NF
                              D pin is 159.6VDC and do is across the caps (it has gone up 5vdc) i Removed the LNK6777K from the board to do these tests.
                              I might roll the dice and try the LNK6777K i have here.
                                I would try new IC.
                                The IC has exposed pad for heatsinking so it will take quite a bit of work to remove it from the copper plane.
                                They copper plane used for heatsinking looks too small to dissipate the heat for that much power, you may want to add heatsink using thermal conductive epoxy to attach a heatsink to the IC.
                                • JeffJ
                                  • Apr 2012
                                  • 189
                                  I would try new IC.
                                  Same symptoms with the new LNK6777K
                                  VDC across the caps has dropped back down to 155VDC and BP is outputting 2.7.
                                  So I'm missing something else here. with the lnk in circuit, the VDC is doping so low that what you suggested previously that its not outputting 5.7vdc on the BP.
                                  Once i get this working i will indeed sync the IC
                                    According to the block diagram of the IC, it is just a simple 5.75V regulator.
                                    If you look at figure 11 in the spec sheet, can you see if it has resistor like R9 that you can disconnect and also see if BP pin goes some where else too.
                                    According to page 4, the value of the BP cap program the protection mode. I wonder if it goes into protection mode.
                                    The rectifier diodes on the cold side are OK?
                                    • JeffJ
                                      • Apr 2012
                                      • 189
                                      thank you! i will do as you instruct and report back when i do.
                                      • JeffJ
                                        • Apr 2012
                                        • 189
                                        The rectifier diodes on the cold side seem to be ok, I have a 3K resistor in place (ROD9) which appears to be R9 in Figure 11. I can try removing that tomorrow when i get back to my tools.
                                        I have a diode close to ROD9 that seems to give me a reading both ways (Z0D5) in diode mode on my meter, Z0D2 and Z0D1 dont give me readins both ways.
                                        I've attached a close up of the area front and back.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Vahalaru
                                          Visio E600i-B3 will not power on.
                                          by Vahalaru
                                          [B]Background[/B]
                                          I recently fixed our Samsung black screen of death by watching YouTube videos and reading through previous threads. Removed a few ceramic capacitors and fixed a short on the back side of the tcon board. So my father and law asked me if I could try to fix his visio. He said that it wouldn't power on. When he first brought it to me I plugged it in and there was a standby light. When I hit the power button the TV booted up and everything worked. I hit the power button again and then I saw what he ment. Since then I have not been able to get it to power on or have a standby...
                                          08-24-2021, 07:23 PM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
