Philco 55 Inch 4k LCD, Is this a side tab issue?
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Philco 55 Inch 4k LCD, Is this a side tab issue?
    They do get mixed everywhere except the leftmost part.
    • Diah
      • Feb 2013
      • 6435
      post clear photos on whole boards to show how they connect together,,, and one very close and clear with high res of the t-con
      • budwich
        • Jul 2015
        • 3097
        Here it is, this is the screen aftes 5 minutes of this fixed image.
        that resulting image is a "non-driven drivers" related to the tabs on the right side looking at the screen. Post a picture showing the tabs along the side.
          It is panel issue.
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            The T-CON had already been messed with, this TV was taken to Philco's authorized repair shop before for diagnosis of the fault, those two transistors that were resoldered are the same ones listed on the electronica-pt repair hint.
            This is what "Alancoteau" at electronica-pt described: T-Con fault, Insulate (cutoff) Pins 9~13 and exchange NPN transistor C5886A, also check A2097.
            Nothing unusual with C5886A and A2097, I've taken them out of the board and measured each one, normal forward voltage, no leaking when polarized in reverse, maybe the other technician already replaced them, all the SMD resistors are good and no shorted capacitors or open fuses.
            NOVATEK NT50115 - IC3004
            NOVATEK NT71788MFG-000 - IC2001
            MXIC MX 25L8006E - IC1001
            RT6914 - IC4002
            BO85BM - IC3006
            • Diah
              • Feb 2013
              • 6435
              for future the test you did of slide show and showing mixing image related to T-CON, but now different story.. how it was before they took it to service center NO ONE KNOW... i wounder what kind of service do this instate put in place new t-con maybe one user over here working there..lol
              !!! so funny
              BTW i saw more bad displaying picture on 4K sets with out name.. they look like the liquid of crystal washing away over the screen,,, and the reason was part of firmware which injected the t-con with most important part the refresh rate..
              i advice you to spend on working t-con in case you didnt or any other missed with tabs
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                #27
                Alright I've just gone and ripped the 8 side tabs from the right, now it's back to life, cool. Full image is working without clouding or darkening anywhere, just some minor horizontal faint lines near the edge of the right side, guess that can't be helped, thank you all Badcaps members for guiding me through the solution.
                • budwich
                  • Jul 2015
                  • 3097
                  glad it worked out. It certainly is better than scavaging the boards as this gives someone a watchable panel as opposed to a "garbage dump lobby". :-)
                    Thanks for the follow-up.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      Can you post a picture of the final outcome.
                      • Diah
                        • Feb 2013
                        • 6435
                        i would like to add my last comment on this threat hope some one read it if he face narrow issue to this set displayed..
                        you removed innocent part player on the panel ( the side driver )... but not the prime causer (T-CON).. for private who don't care do it but never expect joy with it.
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          #32
                          It's kinda weird to say it's working but not post a photo, now it's more proper.
                          The TV and the eight side tabs that I peeled off by hand carefully.
                          If you're 2 meters or farther from the screen you can't see the horizontal lines, I've also not removed the tape cutoff, don't think it will change anything.
                          The T-CON may have cause the issue, I'm not an LCD expert, so I don't know anything about what happened to the panel, but only removing side tabs "fixed" it, also no info on any of those NOVATEK chips or service manual for this TV, so no way to service the T-CON.
                            The pictures will not be perfect but usable when one side of Gate drives are removed.
                            Big panel need to have Gate drives on both sides, if it is on only one side then you will have propagation delay for the drive signal to get all the way across the screen to the Gate on other side, so right now the left Gate drives are doing all the works and you see some minor effect.
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • scubacamper
                              Sharp Aquos LC-70C6400U Half Screen Dark
                              by scubacamper
                              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                              05-03-2025, 12:19 PM
                            • RetroComputingGrotto
                              IBM LTO 7 Tape Drive - Dust Sensors??
                              by RetroComputingGrotto
                              I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                              I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                              09-19-2024, 01:54 AM
                            • kca
                              by kca
                              Hello all ~
                              08-31-2025, 06:38 AM
                            • spice_disc
                              Vizio TV M50-C1 reboot cycle and static on screen
                              by spice_disc
                              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                              09-08-2024, 02:37 PM
