no backlight supply volts hisense ub50ec591uwt
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #41
    Re: no backlight supply volts hisense ub50ec591uwt
    Originally posted by Diah
    show us clear photo of the back side of the PWB
    heres pics of print side psu in pic 3 you can see that the last 5 pins are not used
    • Diah
      • Feb 2013
      • 6435
      when you do 2 jumper 1K ... the second one between STB to PWM2 ( orange) how much the volts read on the orange pin after the 1K ?? and before on STB pin. and are you sure no V on BL socket ??( you can disconnect the LED socket and measure )
      BTW: i think you have over clock on the hot area.. this why the 16V show 20 ... UD901 &902 need to test them after the free them from the boards
      • jimbofz
        • Apr 2013
        • 539
        • uk
        #43
        ud 901/902 check out ok by comparison with similar board using same fets
        the psu pin STB has no volts on it until main board is plugged in so links with 1k resistors wont start
        • Diah
          • Feb 2013
          • 6435
          i am confused .. are you repairing now 2 power boards at same time ?? how it come STB voltage not exist only if MB connected ??? sorry man i cant follow your points.. it make real headage
          • jimbofz
            • Apr 2013
            • 539
            • uk
            #45
            sorry i may have confused you
            no i only have one board to repair
            i compared the resistances with a scrap board that uses similar fets for backlight
            the voltage on the STB pin comes from the MB and is not produced by the psu .the start up sequence is that once the 12v is produced the MB then provides this voltage
            thanks for trying to help me
            • Diah
              • Feb 2013
              • 6435
              you posted voltage reading https://www.badcaps.net/forum/attach...2&d=1596616541 16V=20 on STY...!!!
              Okay, so if the PSU only connect to wall socket and the power switch on it produce only 12V. !! is that correct ?
              in case yes..
              disconnect the socket from PSU side and JUST connect the 12V from PSU to the end socket of MB 12V.. and then check the voltage on the MB socket 16V and other.
              about the LED you replaced ... we don't know what kind replacement you did and what type are the original one !!
              • jimbofz
                • Apr 2013
                • 539
                • uk
                #47
                thanks for not giving up ,
                now its time for me to be confused ?
                the 12v must be regulated because its 12v on or off load ie; in and out of sby.
                the 16v with no load is 20v ,when you bring out of sby it drops a little to 19v
                now i dont understand what you mean "disconnect the socket from psu side and just connect the 12v from psu to end skt of MB 12V?"
                the voltage on the MB is the same
                the leds ive replaced have the same reverse resistance as the original ones BUT the replacement ones will light dim with test meter on diode check ,
                whereas the original ones need a slightly higher voltage so wont light with my test meter but will light with 4.5v
                • Diah
                  • Feb 2013
                  • 6435
                  LOL,
                  let forget your PSU.. for now.. because in general we could find one issue at TVs not 2 or more.. and you did found OPEN LEDs, but 8 pieces at once are so many..
                  do you want to say the replacement one was 3.v and the original could be more?
                  which type and size they are? could you show us.. the defect one and the replacement..
                  or by chance you got photo of the string label
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #49
                    i made sure the ones i replaced had the same zener foreward current readings with DM in diode test mode and replaced any that were showing do reverse reading pics to follow
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      #50
                      heres the pics ive sent pics but error occured will try again later heres the numbers off the original strips
                      50 hd500ud b01 11x6 3030c 3s1px2
                      1140066
                      • jimbofz
                        • Apr 2013
                        • 539
                        • uk
                        #51
                        pics
                        • Diah
                          • Feb 2013
                          • 6435
                          1140066
                          the size 3030.. 6V
                          LEDs for TV backlight choices never being with zener diode forward measurements with DM ......
                          because all kind of zener they will show same ( close range ) however the working voltage are different.. same as if you measure normal zener which limited 21V will test with DM same value for one which limted 5.1V.
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            #53
                            should i try to order 6v types with zener ?
                            this takes me back to start of post
                            this tv has two strings of leds each strip has 6 leds
                            3 are in one chain
                            and 3 are in the other chain on each strip .
                            so is it possible that the drive circuit "sees" a difference in the two strings and then shuts down the BL supply?
                            in total ive fixed about 60 tvs with backlight problems and usually managed a repair using salvaged leds from scrap tvs with broken screens or leds bought from china
                            i dont think ive had many with two strings of leds .
                            in the other repairs when the BL feed is removed you can usually measure voltage on the BL feed socket this is what is to me so unusual with this one
                            • Diah
                              • Feb 2013
                              • 6435
                              3 are in one chain
                              are you now uncertain that you found 8 LEDs open zener ?
                              usually voltage can be traced on LED socket for short time..if there issue at LED.. but remember you told here that you cant see any picture or info on the screen when you used torch light.. just sound you have.. it could be too MB don't turn on the BL and cut off picture.. we / i do make suggest on your comment and test..
                              show me all your scrap working strings label LOL we me find LEDs working for this set..
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                #55
                                no
                                with your advice the leds were o/c
                                even though they would light up with battery
                                ill have a sort out in workshop too see what leds i have
                                and see if they are suitable ,thanks for your effort
                                i need now to have a rest
                                  I am curious, what does your meter show when testing the working LED in diode mode in both directions?
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #57
                                    replacements:
                                    oc when lit dimly
                                    960 ohm in diode test with leads reversed
                                    originals:
                                    oc not lit (need a little more volts than DM supplies in diode test mode to light)
                                    960 ohm with leads reversed.
                                    the 8 ive replaced would all light up with DM but measured oc in reverse direction
                                      replacements:
                                      oc when lit dimly
                                      originals:
                                      Your meter when set to diode mode show the reading in Ohm?
                                      Meter in diode mode test it will show the Vf of the junction in Volt not Ohm.
                                      BTW, how many LED strips does this panel have and how many LED's per strip?
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        • uk
                                        #59
                                        theres 11 strips with 6 leds on each ,but theres two strings, so each strip has 3 that link to next strip so 33 leds on each string
                                        i stand corrected re the DM in diode test mode
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #60
                                          parts ordered i will update asap
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • frannyjunk
                                            Hisense 40H4F no backlight but turns off after splash screen
                                            by frannyjunk
                                            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                            TIA.
                                            09-24-2025, 10:59 AM
                                          • phuzzyday
                                            My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
                                            by phuzzyday
                                            This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
                                            (All the Electrolytics are brand new.)
                                            I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
                                            I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out...
                                            05-30-2025, 05:20 PM
                                          • ojmc
                                            Hisense 65H6570G - Color inverted after replacing LED backlight
                                            by ojmc
                                            Background:
                                            • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                            • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                            • The TV worked again perfectly for ~2 weeks.
                                            • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                            10-17-2024, 02:29 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
