no backlight supply volts hisense ub50ec591uwt
  • Diah
    • Feb 2013
    • 6380
    Re: no backlight supply volts hisense ub50ec591uwt
    Originally posted by jimbofz
    parts ordered i will update asap
    yours PSU working on almost the new standard circuit design by producing certain operation Voltage which converted VIA DC to DC step downer at MB, like other brands LG OLED / nano cells / U LED Panels.. which it need another method to run the PSU as stand alone.
    So i think you and any other members whom don't have yet ...need to have DC to DC step downer PCB, they are cheap less than 3USD with wide range in and out V.. so you can exam yours PSU and BL circuit with out need the MB to narrow any future issue it may accuse by MB
    • jimbofz
      • Apr 2013
      • 539
      • uk
      #62
      finally fixed .
      the led driver ic LX27901 ID was replaced ,
      i had to get it from a supplier in Spain ,so sorry for the delay in this post ,
      as you all know it seems to get harder with every job to source parts.
      thanks all for your help ,
      .ive learned not to trust what some customers say ,
      as this tv clearly had been got at by some previous attempt to fix .(two leds had been replaced)
      one of the foils feeding the panel had a slight tear in it add was damaged,
      ,(if you flexed it gently we had lines and noise in left hand side of pic) but i managed to replace it,after reducing the backlight settings from 100 to 25% still a good pic .thanks to all who took the time to help
      • giorgi711
        • Sep 2021
        • Georgia
        #63
        Can you please explain me, what does SW(BL_EN) abbreviation means? What is it for ?
        In order to measure voltage on sw pin, I connected the black wire of multimeter to gnd pin(num. 1 on XP805 on image) and red wire to SW pin, after that one of capacitors(25V) swollen and blew smoke.
        Before i did that, voltage between 12V pin and gnd was 24V, and between 16V and gnd was 32V.
        Here is scheme of PSU of hisense tv.
        • giorgi711
          • Sep 2021
          • Georgia
          #64
          Scheme image has poor quality, see PDF file in attachments.
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            Hello Sharp TV experts
            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
          • phuzzyday
            My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
            by phuzzyday
            This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
            (All the Electrolytics are brand new.)
            I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
            I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out...
            05-30-2025, 05:20 PM
          • ojmc
            Hisense 65H6570G - Color inverted after replacing LED backlight
            by ojmc
            Background:
            • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
            • I replaced all 6 of the backlight LED strips with these replacements: amazon
            • The TV worked again perfectly for ~2 weeks.
            • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
            10-17-2024, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • BoardHoarder
            XBR-65X850D Backlight/Power On Help
            by BoardHoarder
            Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
            02-09-2024, 11:00 PM
