Philips DOUBLE IMAGE FAULT
  • lanada
    • Oct 2013
    • 50
    • Malta
    I have a philips 49PUT6101/12 CHASSIS TPL16.1E with double image problem as attached, any one knows regarding this problem?
    Any help will appreciated
  • Diah
    • Feb 2013
    • 6460
    Re: Philips DOUBLE IMAGE FAULT
    show us photo of the menu OSD while the set display external video signal via AV or scart.
      LCD panel Gate tab bond issue, tape off method may work.
      • lanada
        • Oct 2013
        • 50
        • Malta
        a video taken what exactly is the problem ,signal from external decoder through HDMI and it's alternating 4 sec ok and 4 sec with double image problem
        I hope it a bit clear
        • Diah
          • Feb 2013
          • 6460
          the video show the screen display correct image first and back again so..
          1- clean the LVDS cable between main boards and T-CON and seat it back in tight way.
          2- take out the 2 ribbon cable between the T-CON and the panel .. inspect the silver / GOLD pins of them from both side with good loop . then clean them carefully and put them back one by one. each time u put back one side ribbon upload photo over here
          • lanada
            • Oct 2013
            • 50
            • Malta
            Hi Diah
            I Cleaned the lvds cable from both sides and switch on again but with no hope, I also clean the the two flat cable from tcon to panel to LCD, attached will find two photos one with left flat cable removed and result in half pure white display, then I put back and i removed the right one and results is with half picture and with grey lines
            • Diah
              • Feb 2013
              • 6460
              its tab bond issue ... hope u can fix it by working round apply pressure on the effected side
                So do you still get the same double images as shown in your post #1 when everything are connected back to normal?
                • lanada
                  • Oct 2013
                  • 50
                  • Malta
                  YES still the same and i checked the tab cables it it seems fine ,i suspecting the TCONBOARD
                    It is the Gate tab bonding as shown in post #3. Try taped off methods.
                    For examples:
                    https://www.youtube.com/watch?v=j7vl7-vZEL8
                    https://www.youtube.com/watch?v=9eT5-3L_BLU
                    You can try T-CON if you like.
                    • lanada
                      • Oct 2013
                      • 50
                      • Malta
                      yes but if you check post 3 the video attached the display is alternating from 4 sec ok to 4 sec to grey horizontal lines,so that why I not suspect with the tab bonding
                        Like I said, you can try the new T-CON if you want.
                        The Gate drives are on the side of the panel.
                        Tape off method does not cause money to try, it is up to you, do what ever you want.
                        • Diah
                          • Feb 2013
                          • 6460
                          yes the video show like cold soldering point .. also if you are sure went thru all tab bond and no change.. try with your HDMI signal while it play make pressure on the metal shield on the Main Boards.. and on several pints at the corners of the chassis to see if the issue changing time changed.. give time let the set warming up too.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4498
                            • Italy - Milan
                            This is 100% panel fault, don't waste money in other, need a tape masking method, unfortunately here is very hot and i don't know if i can help you for free.. tab rip off doesn't work i think because there are no tabs.. tellme if you have LG display.
                            • Diah
                              • Feb 2013
                              • 6460
                              who are you to asking fee for service over this forum and there allot other member more better than you give the advice and share their know how..
                              no need to list names over here... but one words enough to you shame on you.
                                • 12305
                                • U.S.
                                Originally posted by diah
                                Who are you to asking fee for service over this forum and there allot other member more better than you give the advice and share their know how..
                                No need to list names over here... But one words enough to you shame on you.
                                +1000
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4498
                                  • Italy - Milan
                                  Diah it is better that you stop it, you are not a moderator, i think was not a problem for the forum but i received a warn, so stop with your unuseful polemic, i don't shame on me stay calm, i think you was OK but i guess you are not so friendly, i don't think i am better than you, the difference is that i don't come here to make stupid comparison,, i'm not making a race, if you think you are better than me let demonstrate here solving this case without bothering me, i think you surely will solve this easy problem foryou like i think you have a good job that surely makes true every your desire. Don't make much moral. Don't make it so seroius, it was wonderful if everything was for free. It is more serious to offer a serious paid assistance than offer free advices that takes the wrong road like certain user are common to do here and appears in every discussion.
                                    • 12305
                                    • U.S.
                                    ^ Isn't that a forum violation? Over 200 words and none had anything to do with fixing this double image issue, OP did you try turning down the backlights not brightness and see if display changes any?
                                    • piershs
                                      Toshiba plasma 50WP16 wierd double image fault
                                      by piershs
                                      My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                                      Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                                      • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                                      • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                                      08-01-2020, 01:07 PM
                                    • Cornito
                                      Samsung UE55RU8000 reboot and then double image after heating up
                                      by Cornito
                                      Hello team,
                                      I'm back with another tv and another problem.
                                      I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                      First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                      Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                      Then double image reduce in height and move to the top.
                                      The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                      When I...
                                      03-31-2024, 01:37 PM
                                    • Agent24
                                      What kind of fault causes this image error?
                                      by Agent24
                                      I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                                      The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                                      What's the most likely cause of this problem, does anyone know?...
                                      09-22-2025, 11:42 PM
                                    • alro7779
                                      Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                                      by alro7779
                                      Hello there!
                                      Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                                      08-07-2025, 11:53 AM
                                    • tuner2000i
                                      Philips 65PUS8518/12 distorted image after main board replacement
                                      by tuner2000i
                                      hello everyone,
                                      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                      07-15-2025, 01:15 PM
