Philips 47PFL4606 No Power Fuse Keeps Blowing
    Re: Philips 47PFL4606 No Power Fuse Keeps Blowing
    Originally posted by trunks81
    Hello Budm
    Done al the steps you asked except remove R965 that one isnt on the board. and R866 is R966.
    But now i have 5,9volt @pin 3 of ic905 and 4,6v on the 5v
    So now you do get 4.6V Standby Voltage?
    It should jump up to 5V when using 1K to simulate turn on signal, verify that.
    BTW, My typo on R866, it should be R966.
    • trunks81
      • May 2020
      • 265
      • Nederland
      #62
      Indeed when 1K in place iam getting the 5V
        Great!
        1) So leave those parts I had you removed out for now then check Q907 in diode mode and in resistance mode on all 3 legs combination.
        2) Check the resistance between two leg of cap C922.
        • trunks81
          • May 2020
          • 265
          • Nederland
          #64
          Hello
          On Q907 between C/B iam getting 1ohm in both ways..
          On caps C922 iam getting 266ohm
            Hello
            So Q907 is damaged when you had that blown up episode, the circuit is loading down the AUX Voltage (C946) so the TOP SMPS was in shutdown/restart mode, that is why you were only seeing about 2V on the 5V STBY output.
            Now we have to find out which circuit is causing 266 Ohms reading on C922, it can be the PFC IC902 of the 12v/24V SMPS IC901, MLCC C920, MLCC C915.
            I would try removing one MLCC cap at a time first, if the resistance still reading low on C922, if it still stay low then I would remove IC902, then IC901.
            BTW, check the resistance of C922 on the working board to see what you get.
            • trunks81
              • May 2020
              • 265
              • Nederland
              #66
              the resistance on the working board on C922 is 105Kohm
              Both caps C915 and C920 measure around the 260ohm on the defective board
              I removed C915/C920 and IC902 and now the short is gone
                That cannot be right. You are measuring the caps on the working board, correct?
                C915, C920, C922 are connected in parallel so the reading should be all the same.
                • trunks81
                  • May 2020
                  • 265
                  • Nederland
                  #68
                  Sorry.. C915 and C920 on the defective board measure around 260ohm,
                  Also i removed them and they measure OL
                    OK, that means the caps on the bad board is good, so it can be bad PFC IC902 or the SMPS IC901 for the 12v/24V, remove one of them and see if the resistance will go up.
                    • trunks81
                      • May 2020
                      • 265
                      • Nederland
                      #70
                      removed ic902, and now the resistance on C922 is 104kohm.. the same as on the working board
                        So the PFC IC902 is bad then.
                        Be sure to recheck PFC MOSFET Q902, R919, R917, R916.
                        Something caused the IC that you said you replace to go bad.
                        The original PFC IC is FAN6961 as shown in the schematic, correct?
                        • trunks81
                          • May 2020
                          • 265
                          • Nederland
                          #72
                          Hello
                          Orginal PFC is indeed FAN6961 !
                          Q902 = checked out good.. all high ohmages
                          R919 = is 0.33ohm
                          R917 = 9,90ohm on the good board 47.07ohm tested in circuit
                          R916 = OL and on the good board 133kohm tested in circuit
                            Hello
                            R919 = is 0.33ohm
                            1) R917 is 47 Ohms as shown in the schematic, it is connected in parallel with the diode, so your reading shows 990 Ohms, that means it is bad and possible the Diode D910 may be damaged too, check that.
                            2) R916 is 4R7 (4.7 Ohms) as shown in the schematic, you need to recheck it again and both boards.
                            BTW, you must look at the schematic to see what the values are shown in the schematic then look at the value as printed on the body of the resistors so we do not have to go back and forth re-verify your readings.
                            • trunks81
                              • May 2020
                              • 265
                              • Nederland
                              #74
                              Hello
                              R917 soldered out of circuit and that resistor is 47ohms
                              D910 soldered out of circuit and tested very low in both ways
                              R916 soldered out of circuit and tested OL
                                Hello
                                So you have more damaged parts.
                                "R916 = OL and on the good board 133kohm tested in circuit"
                                What does R916 of the good board show? It cannot be 133K as you reported, it is supposed to be 4R7 Ohms.
                                • trunks81
                                  • May 2020
                                  • 265
                                  • Nederland
                                  #76
                                  Strange tested R916 on the good board and soldered that one out of circuit and it tested OL
                                  • trunks81
                                    • May 2020
                                    • 265
                                    • Nederland
                                    #77
                                    Replaced the next parts.
                                    IC902 = FAN6961
                                    IC901 = NCP1271D65R2G
                                    R917 = 47ohm
                                    R916 = 4,7ohm
                                    D910 = 1N4148
                                    C920 = 1U 25V
                                    C915 = 1U 25V
                                    After replacing these parts got no 24/12V
                                    • trunks81
                                      • May 2020
                                      • 265
                                      • Nederland
                                      #78
                                      Ive got on the next voltages on C922,C915 and C920 = 0.83V
                                      Also seeing this back on both VCC pins of IC901/902 = 0.83V
                                      PFC D901 = Measure on both boards the same ! no low ohm
                                      Q907 = 9,8 to 10.5V on all the legs to hot ground
                                      On the + of D915 to hot ground = 411V
                                      On the + of C946 to hot ground = 10.52V
                                      ZD908 = 7.67V
                                      R959 = 4,7ohm (4R7 on schematic
                                      D916 is working measure 0.5V and reverse OL
                                      12V1 to ground is 340 ohm
                                      12V2 to ground is 1K ohm
                                      24V to ground is 2.47K ohm
                                      C946 When 1K resistor in place iam getting 10.52V and removed 7.8V
                                        I wish you did not put in all those parts in yet since I am not done verifying more parts.
                                        1) Remember that Q907 is shorted out. Your post #64 "On Q907 between C/B i am getting 1ohm in both ways". Did you put in the new one in?
                                        2) Did you put R947 (4.7 Ohms) back in place. My post #59 "2) Remove R947 (4.7R)"
                                        3) At this point if you did not put R947 back in place, you need to leave it out.
                                        4) Put in new Q907, then check the Voltage on all 3 pins with 1K and with 1K, the Voltage needs to be about 15V when 1K is connected (that is what you get on the good board and the other board that we repaired).
                                        • trunks81
                                          • May 2020
                                          • 265
                                          • Nederland
                                          #80
                                          1. i did place an part from an other donor board.
                                          2. i did not put back R947 and R966,Q906
                                          3. Yes iam going to leave it out.
                                          4. Q907 = 9,8 to 10.5V on all the legs to hot ground
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • simwalsh
                                            Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                            by simwalsh
                                            I am new to this forum and have searched for some answers with problems similar to mine.
                                            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                            It sounds like a power supply issue?
                                            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                            12-04-2023, 04:03 AM
