Sharp LC-50P66U-completely dead PSU!!
    Re: Sharp LC-50P66U-completely dead PSU!!
    What Voltage do you have on center pin of diode VD821 with ref to chassis gnd?
    What Voltage do you have on center pin of diode VD820 with ref to chassis gnd?
    • kgavionics
      • Apr 2017
      • 152
      I didn't change anything, but somehow I got the 18.3 on the 16V rail, a fluctuating between 8.3 to 12.3V 12v rail, but no standby voltage!
      When I press either on the power button or the on remote nothing happens the pin SW doesn't go high. I guess it's normal, because the main board needs the standby voltage to be present to work properly?
        1) "I didn't change anything, but somehow I got the 18.3 on the 16V rail, a fluctuating between 8.3 to 12.3V 12v rail" so the 16V rail is steady at 18.3V, but the 12V rail is fluctuating between 8.3 to 12.3V?
        2) What do you mean No Standby Voltage? The 12V and the 16V are the standby Voltage. STB pin is the PS-ON pin for receiving the power supply on control signal from the main board, it is NOT Standby power supply output pin.
        3) SW pin the BL-ON pin for receiving the backlights circuit on signal from the main board.
        4) PWM is the backlights dimming pin, it gets the control signal from the main board.
        5) It has to be your measurement error for not getting the 16V and 12V at the connector in your earlier report because you cannot have PFC Boost Voltage and the 245V on LED connector if there are 0V on the 12V and 16V pins, it is impossible.
        6) What happen to my post 21 Voltage readings request?
        • kgavionics
          • Apr 2017
          • 152
          hello Budm and thank you for your help it means so much to me!
          I think it was my error for not getting the 16V and 12V!
          Regarding, the voltage reading requested in #21 I was getting 18.3 and a fluctuating 12V.
          Yesterday, I was contacted by the seller of the card, who is a TV repair technician. He's a super nice guy who offered me to help, he asked me to take the measurement across the backlight connector, which I did, I only was getting 1V or so! I removed the power for 15 min. After that I went to check the 12V and 16V, but I didn't have any of them. The booster voltage cap went down to 322V and I lost the 245V on backlight circuit!
          I'm not sure what happened!! Now I removed the board again to check it off power!
          • nomoresonys
            • 12123
            • U.S.
            So is the mainboard NOT sending the power on signal then?
            • kgavionics
              • Apr 2017
              • 152
              It looks like the mainboard, is not sending any signal back to the PSU.
              By the way, this set is poorly designed and even though is branded SHARP, it's actually a Chinese crap made by Hisense!
              • digitalscorpion
                • Mar 2012
                • 37
                Did you have any luck with this?
                I have similar power board with no output voltages.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  #28
                  What voltages have you measured? Do they agree with those shown on the schematic in post #2
                  • digitalscorpion
                    • Mar 2012
                    • 37
                    I have no DC output voltages on connector XP903.
                    Nothing connected to power board currently, receiving no STB voltage, no 12v or 16v as well.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      #30
                      Have you checked the wickman fuse F801 is not open circuit.
                      What DC voltage do you have when you measure across C870. Connect your meter probes to each leg of the capacitor.
                        Too bad OP never comes back with the follow-up.
                        • digitalscorpion
                          • Mar 2012
                          • 37
                          F801 is good.
                          C870 = 164V DC.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #33
                            The capacitor C815 which is connected to VCC (pin 8) of N801 should charge up to between 19 - 22V at switch on for the IC to start operating.
                            This capacitor is charged via VD801, VD802, R807, R808 abd R809 which you could check.
                            Next STB (standby) needs to be asserted. This can be accomplished by disconnecting the power supply from the mainboard and using 2 x 1.5V batteries connected in series to create a 3 volt supply. The negative lead of the battery to any ground pin of the power supply and positive lead of the battery connected to the power supply STB pin connection using a 1K resistor.
                            Then check the voltage again across C870
                            • digitalscorpion
                              • Mar 2012
                              • 37
                              C815 = 0V
                              When you say assert the STB voltage, do you mean I should attempt to Insert 3v into it? Shouldn't the power supply board be producting that STB voltage?
                                Originally posted by digitalscorpion
                                C815 = 0V
                                STB (Same as PS-ON) pin of this power supply board is the control signal Receiving pin that get the control signal from the main board to turn on the power supply, it is not Standby power supply output.
                                See my post #23 regarding to the pin names and what they are for.
                                • digitalscorpion
                                  • Mar 2012
                                  • 37
                                  Ohh. If no DC output to the main board, how does the main board provide control signal?
                                  I will attempt the 3v insertion on STB line and report back. Thank you guys!
                                    I did not read your thread to find what you and Dick_Barton found so far, I am just pointing out what those pin names are.
                                    • digitalscorpion
                                      • Mar 2012
                                      • 37
                                      I did not your thread to find what you and Dick_Barton found so far, I am just pointing out what those pin names are.
                                      I understand. i missed your #23 post with that detail.
                                      I will now try to insert the 3v and take a measurement.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        #39
                                        Reading the information on the IDP2303 it appears to be a programmable IC so there is the possibility it may have been corrupted.
                                        • digitalscorpion
                                          • Mar 2012
                                          • 37
                                          Applied 3v via method suggested. No change. C870 = ~168v DC. No other output voltages. At this point I will seek out a replacement power supply board. Thank you for the help.
                                          • borstar_micke
                                            Dead Sharp Aquos LC-32LE430E
                                            by borstar_micke
                                            My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
                                            I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
                                            Not a master with the multimeter, which is cheap and 10-15year old btw...
                                            So please make it basic...
                                            To the issue at hand.
                                            As stated, the tv is totally dead with no standby light....
                                            03-23-2023, 09:14 AM
                                          • metropical
                                            Sharp lc32d42u seems dead
                                            by metropical
                                            plugged in after being off for quite some time. No OPC lights. Tried flashlight test for backlight check, nada.
                                            Pulled the PS and checked all diodes including the 5w(?) D7908 that was the issue last time. All diodes check OK in circuit with DVM diode test.
                                            No caps look unhappy. It is 17 years old. Was gonna fix and give to my brother.
                                            But is there anything else to try or is it likely met its match.?...
                                            09-28-2024, 05:41 PM
                                          • Judderman69
                                            Sharp LC-40FG2241KF dead
                                            by Judderman69
                                            Hello and greetings from the United Kingdom, I'm looking for some help in repairing my grand daughters 'dead' Sharp LC-40FG2241KF smart tv. I have replaced the following damaged parts on the main PCB (TP.MS6486.PB711) :- fuse FB1, switch mode chip UB101, MOSFET QB101,capacitor CB116, resistor RB106, RB148 and a track from UB101 pin 6 to QB102.
                                            Unfortunately resistors RB105 and RB108 are also open circuit and because of their size (0201) I don't know their value. Could some kind soul please tell me or point me toward a schematic with a parts list, a very big ask but for this I would...
                                            02-02-2022, 11:29 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
