SONY Bravia KD-55SD8505 Please HELP!
  • goluins
    • Jul 2020
    • 46
    • Russia
    Hi!My Sony Bravia Kd55Sd8505 2times red blinking!what is a problem?how i can repair that?
    After flash usb they turning on but only backlight, remote and sound works,no picture! only one vertical line by the center!Please help me somebody who knows what kind of problem!I will very appreciate!
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: SONY Bravia KD-55SD8505 Please HELP!
    probably T-con issue what do the fuses measure on the T-con
    • Diah
      • Feb 2013
      • 6363
      you wrote you have just sound. to approve if you have video signal. just connect the sony with extra TV via scart.. be sure the scart side of the sony side had out put video signal.. if you see the video on the second tv mean main boards okay.. go ahead with t-con check
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4318
        • Italy - Milan
        Surely you have a bad panel, i see for the first time a tcon with 3 outputs, so the screen is splitted in 3, since you have a central line that i don't see so probably the fault is in central screen board or source cof, but much probably is in side COG not fully repairable. I can't explain all now it's late night...
        • goluins
          • Jul 2020
          • 46
          • Russia
          What is it COG?
          • goluins
            • Jul 2020
            • 46
            • Russia
            new T-con installed!!
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4318
              • Italy - Milan
              then?
              • goluins
                • Jul 2020
                • 46
                • Russia
                Then 2 times red blink and no voltage to the mainboard! 19.8v 2pinouts and 2.2v 1pinout on mainboard!no 3.3! what is it?
                  • 12156
                  • U.S.
                  Look thru the the little holes in the back, are your backlights purple? You might have more than one issue.
                  • goluins
                    • Jul 2020
                    • 46
                    • Russia
                    no, backlights is white color and its absolutely normal!
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      i said bad panel..
                        Can you please clarify that? I do not understand what you are indicating "and no voltage to the mainboard! 19.8v 2pinouts and 2.2v 1pinout on mainboard!no 3.3!"
                        Those Voltages are correct with the old t-con board and now they are not correct?
                        Can we see good clear hi-res straight shots of the whole T-CON board?
                        • goluins
                          • Jul 2020
                          • 46
                          • Russia
                          Ok give 10 min please!
                          • goluins
                            • Jul 2020
                            • 46
                            • Russia
                            here they are
                            • goluins
                              • Jul 2020
                              • 46
                              • Russia
                              1-tcon 2-mainboard 3-power supply with led driver
                              • goluins
                                • Jul 2020
                                • 46
                                • Russia
                                19.8v and 2.2v from powersup. to the mainbord! 2times red blinked!
                                  I am confused.
                                  1) So the 19.8V is the Voltage from the AC adapter where DC jack is, correct?
                                  2) Where is this this 2.2V are measured at? So you have the 2.2V when old T-CON board is installed, correct?
                                  3) How about the 3.3V you are talking about? So you have the 3.3V when old T-CON board is installed, correct?
                                  4) So with the new T-CON board you are still getting 2-blink, correct?
                                  5) So how does the TV acts differently between Old and New T-CON board? Still getting backlights and same image as in your post # 1 when new T-CON is installed? I am trying understand what is going on.
                                  • goluins
                                    • Jul 2020
                                    • 46
                                    • Russia
                                    1)Yes! the 19.8V is the Voltage from the AC adapter where DC jack is
                                    2)the Voltage from the AC adapter where DC jack is!!
                                    3)no 3.3v at all!!!old t-con is on short!!
                                    4)Yes! Its only on new Tcon board!!Old tcon shows white screen and the line
                                    5)Only if I flash usb port!but after unplug and restart, 2red blinks))
                                    Yes Tcon is installed)
                                      So you are telling me that you only get 2.2V at the dc input jack instead of 19V when you install new T-CON board? It sounds like your T-CON board is bad and loading down the 19VDC adapter, the adapter is probably in shutdown/start cycle.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4318
                                        • Italy - Milan
                                        i see confusion in the answers.. better to carry the tv to tv tinkerer..
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                          10-16-2024, 05:15 AM
                                        • Spc.
                                          Sony Bravia KD43XF7596BAEP - Android no picture
                                          by Spc.
                                          Greetings everyone.
                                          I also have Sony Bravia, model:
                                          Sony Bravia KD43XF7596BAEP - Android.
                                          What happend is that image dissapeared while we were watching tv.
                                          Diagnostics:
                                          1. TV turns on, no errors
                                          2. Backlight turs on, no errors
                                          3. Power indicator turns on, white color, no errors
                                          4. Menu works on android, you can hear sound while switching channels
                                          5. Volume up and down works via TV remote and via buttons
                                          6. Tunner works, HEVC / MPEG-4 decoder works
                                          7. I get audio from channels
                                          8. No picture is present,...
                                          05-19-2022, 04:28 AM
                                        • KYBOSH
                                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                          by KYBOSH
                                          Previous owner said TV just went blank one day.
                                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                          I just downloaded the Sony KD-75X7800F Service Manual and...
                                          11-19-2024, 10:12 AM
