TLC LE48FHDF3300Z Horizontal lines - question about T-Con
  • sansonet
    • Nov 2013
    • 236
    • US
    Somebody gave me TV with bad screen, I want see if replacing t-con will fix it. I can get one from aliexpress pretty cheap - dont want invest too much in it since Im not sure if it will fix this TV. But for some reason most of Chinese sellers have this board without resistors, as it shown on this picture
    One listing I wanted to buy from (US seller) dont have resistors too (by time I opened TV to check board number it was gone ) https://www.ebay.com/itm/TCL-LE55FHD...-/333636600899
    Most of US sellers, also my TV have resistors on board, like this one https://www.ebay.com/itm/TCL-LE48FHD...1/392737451864
    But they cost 3 times more. Do I need buy one specifically with resistors, or it makes no difference? (I compared my board after I made pics and found few more missing components - some missing from my board, some from "Chinese" boards)
    Pics of my board attached, also picture of screen, one pic of full screen and t-con attached, pic with left ribbon cable removed, and pic with right cable removed.
  • jostewcrew
    • Mar 2020
    • 79
    Re: TLC LE48FHDF3300Z Horizontal lines - question about T-Con
    i will concede to others diagnosis since im still learning my self to pinpoint without a doubt....but for the guessing game...
    this is a panel failure i.m.o.
    • neilc6
      • Nov 2015
      • 1550
      Horizontal lines are panel failures. You can connect one side at a time to see if one side is good. If yes, you can try the tape cutoff method on the bad side.
        • 12157
        • U.S.
        https://www.youtube.com/watch?v=j7vl7-vZEL8
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4319
          • Italy - Milan
          It is too much hurt to input a video source instead of a poor all blue image?
          Anyway its 100% panel failure. The half connected screen test may not work on theese panels, if not make a photograph of the out part of the screen internal pcb, the long thin one, one is enough, them are almost equal.
          • sansonet
            • Nov 2013
            • 236
            • US
            I did, it shown on pictures 4 and 5. One side clears up, just one line on middle still there. What is "tape cutoff method"?
            • sansonet
              • Nov 2013
              • 236
              • US
              It was dropped in my barn, I dont have video signal source near it. I still can lines on blue screen so I not bothered to bring any player to it. I will try make pic or that board later.
              • neilc6
                • Nov 2015
                • 1550
                With one side disconnected, you should only see half a screen.
                nomoresonys posted a youtube link for that method.
                • sansonet
                  • Nov 2013
                  • 236
                  • US
                  I did, those halves on pics 4 and 5, I not made pics of full screen on those, just visible parts.
                  • neilc6
                    • Nov 2015
                    • 1550
                    If you have lines from both sides, then the cutoff method probably won't work.
                    • sansonet
                      • Nov 2013
                      • 236
                      • US
                      On pic #5 all lines are gone, just one single line on middle remains.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4319
                        • Italy - Milan
                        OK sorry it's a little hard to follow the forum on a telephone, now i'm on PC and i can see better, your last pictures reveals that you can't fix 100% the fault, but at least you can let the big part of the lines to go away. So make a photograph of the outer part of the screen's internal pcb, the long tight one, one of the two is enough, them are almost equal. Silkscreens are to be visible.
                        In photo 3 there is a curved line with backlight passign through, is it a scratch or a crack?
                        • sansonet
                          • Nov 2013
                          • 236
                          • US
                          On pic 3 just reflection of chair with chrome legs that stands near it. It have no cracks. Attached pics are of one of those boards - full one and few close ups.
                            • 12157
                            • U.S.
                            The blue connector there looks a little off kilter, make sure it's ok and not out of alignment.
                            • sansonet
                              • Nov 2013
                              • 236
                              • US
                              Its not connected, I never connected it back after making pics.
                                • 12157
                                • U.S.
                                Ok, that explains it.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  what does that mean... "dropped in my barn"?
                                  you do need to post pictures of the entire screen when you do the "cable disconnect tests" so that the forum can see what is exactly happening to the screen.
                                  • sansonet
                                    • Nov 2013
                                    • 236
                                    • US
                                    My friend brought this TV here and dropped it off in my barn.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4319
                                      • Italy - Milan
                                      OK, as you can see from pictures many silkscreens are not visible, are there no sunny days there where to make photos whitout flash? i need the outer half of the board, near the side.
                                      • sansonet
                                        • Nov 2013
                                        • 236
                                        • US
                                        OK, tried it again... Location is near side flex cable (first two pics) and middle cable (pic #3)
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                        • noisykid
                                          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                          by noisykid
                                          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                          12-30-2024, 07:15 PM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA Horizontal lines
                                          by x_orange90_x
                                          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                          07-15-2023, 05:06 AM
