TLC LE48FHDF3300Z Horizontal lines - question about T-Con
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4542
    • Italy - Milan
    Re: TLC LE48FHDF3300Z Horizontal lines - question about T-Con
    Now is ok. THe first and simpler attempt is to check with multimeter which contact on the connector on the right side is connected to the testpoint VSS1 and block it with a piece of adhesive tape, the second attempt is to perfect it blocking instead of VSS1 one or more of the CKV1/2/3 OR CKVB1/2/3 one at a time, but since i don't remember the difference between CKV and CKVB, i have to check, so for now let's be happy with the first attempt...
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • noisykid
      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
      by noisykid
      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
      12-30-2024, 07:15 PM
