samsung ln46d630 power supply fuse blown and burn mark
  • jmandawg
    • Jul 2020
    • 42
    picked up this curb alert TV. Looks like the fuse is blown, i don't have a fuse to replace is with, is it safe to short with something just to test it? There is also a burn mark in the white glue near a transistor so maybe the transistor is gone as well. Attached is a picture with the burn circled as well as the fuse that is blown.
    Board is labeled as: BN44-00463A
    What's my next best steps?
    Thanks.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: samsung ln46d630 power supply fuse blown and burn mark
    Remove the glue around the burnt area to see what is damaged.
    Do not use something in place of the fuse just to test, it clearly blew for a reason and you're likely to do more damage.
    • neilc6
      • Nov 2015
      • 1550
      Blown fuses almost always mean shorted diodes or FETs on the board. If you measure the resistance of one side of the fuse to ground, it will likely be a short that you need to track down.
      • jmandawg
        • Jul 2020
        • 42
        Here is what's under the glue. It seems like the left pin on the transistor is shorted to ground. I'm not getting a zero reading but it's close. Also looks like the blue ceramic resistor has a chip taken out of it. Looks like it burn out the side of the transistor. What is that white glue for? Is it too prevent fires?
        Transistor looks like it says CM0465R
        • neilc6
          • Nov 2015
          • 1550
          Yes that transistor is shorted. The glue is to prevent dust that may accumulate between high voltage pins from igniting. I have seen it a few times usually from tvs with indoor smokers.
          If you bypassed that fuse, you could have tripped your circuit breaker in your house by plugging it in since you are shorting the AC. I use a plug in GFCI outlet for dodgy power supplies based on recommendations here.
            It looks like the blue disk snubber cap had shorted out, remove it and see if the shorts goes away.
            BTW, FSCM0465 is a SMPS IC not MOSFET. You need to check the internal MOSFET of that IC to see if it is shorted out or not
            • jmandawg
              • Jul 2020
              • 42
              Ok I'll remove the blue disk tomorrow and check for the short. How do I check the mosfet of the IC? The right pin on the IC broke when I was removing the glue.
              Here is a better picture. How do Find a compatible blue cap. It looks like it says 101 1K.
                1) So did you check the the resistance of that blue disk cap to see if it shows as shorts?
                2) The inetrnal MOSFET can be checked for shorts by measuring pin 1 and pin 2 of that IC, see the spec sheet I provide that shows the pinout of the IC. BTW, if you test it again without the blue cap in place as you did in your post #4, does it show as shorts?
                3) The blue high Voltage ceramic cap is 100pF 1000V, I would replace it with 2000V rating instead.
                • jmandawg
                  • Jul 2020
                  • 42
                  The blue cap is measuring around 2k ohms. I removed it from the board and the short is gone.
                  I measured between pins 1 & 2 on the IC and there is no short there. Unfortunatly since i broke off a pin when removing the glue i also removed the IC.
                  Also i misread the IC it's actually a GM0465R (GM not CM).
                  1. Would the next best steps be to replace these 2 parts and the fuse and see if the short still exists.
                  2. Is this the correct IC replacment: https://www.digikey.com/products/en/...=1&pageSize=25
                  3. is there a better store to buy the parts from?
                    • 12137
                    • U.S.
                    You can try ebay for the cheaper shipping but hard to beat digikey for reliability.
                    • neilc6
                      • Nov 2015
                      • 1550
                      You are lucky that part is still in stock at Digikey and not obsolete. Ordering ICs from Aliexpress is quite the crap shoot and may be the only option for obsolete ICs.
                      • jmandawg
                        • Jul 2020
                        • 42
                        For the IC GM0465R what is the difference between L-forming W-forming and U-forming and will it make a difference which one i use?
                        Also can i replace the ceramic fuse with a glass fuse like this (same amps and voltage): https://www.digikey.com/product-deta...mSeq=331601576
                        They don't seem to have any ceramic ones in stock unless they are imported (tariffs/extra shipping).
                        • neilc6
                          • Nov 2015
                          • 1550
                          Not sure how you are searching but here's a ceramic
                          https://www.digikey.com/product-deta...212-ND/1008984
                          If you download the datasheet from Digikey, the physical specs at the end show the different forming packages. Just how the pins are pre-bent.
                          • jmandawg
                            • Jul 2020
                            • 42
                            Awesome thanks for the help, saved me from buying the wrong part. I will probably have to order that IC from china/ebay as digikey doesn't have it with the correct pin forming.
                              Are you going to get the replacement ceramic cap too?
                              • jmandawg
                                • Jul 2020
                                • 42
                                Yeah, i need the IC, cap, and fuse. I've having a hard time sourcing them all from the same place. Prob just get them all individually on ebay.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Just order everything from Digikey. You can just rebend the pins.
                                  Here is the cap https://www.digikey.com/product-deta...6PH-ND/2356736
                                    i would order more than one piece each in case of messing up the repair.
                                    • jmandawg
                                      • Jul 2020
                                      • 42
                                      Thanks guys i just ordered 2 of everything from digikey. I wasn't sure if the IC would still screw into the heatsink if i bent the pins, but hopefully they are long enough. Will update once it all gets here. Thanks.
                                      • jmandawg
                                        • Jul 2020
                                        • 42
                                        Ok guys parts came today. two of the IC pins were a little bit short so I had to solder on some extensions made from the disk capacitor pins. I got everything soldered on and I checked for the short and it was gone. I got everything assembled back together and turned the TV on and it worked! I attached a pic of the extensions to the IC pins. I think they should be ok.
                                        Thanks for all the help guys. You are all awesome!
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                          09-07-2024, 05:50 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • triplefour
                                          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                          by triplefour
                                          Samsung UN55ES7003
                                          made house call.
                                          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                          psu has self test feature.
                                          disconnected from mainboard.
                                          determined PSU ok BL ok.
                                          suspect mainboard.
                                          disconnecting tcon has no change on operation.
                                          markings on mainboard:
                                          BN97-06531P 0151
                                          BN94-06123R
                                          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                          for 54$
                                          second house call:
                                          with replacement mainboard, tv turns on, has sound,...
                                          07-13-2022, 03:53 PM
