samsung ln46d630 power supply fuse blown and burn mark
  • nomoresonys
    • 12087
    • U.S.
    Re: samsung ln46d630 power supply fuse blown and burn mark
    Glad to hear it so looks like the blue ceramic cap was the issue on this one.
    • jmandawg
      • Jul 2020
      • 42
      Yeah, you were right, now i'm wondering if the old IC was fried, it might have been functional still. Too bad i broke the pin off at the base.
      • petehall347
        • Jan 2015
        • 4425
        had one recently .both had blown . not same model but similar power supply .
          Thanks for the follow-up.
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
            09-07-2024, 05:50 AM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • triplefour
            Samsung UN55ES7003 has blown fuse on TCON and short to ground.
            by triplefour
            Samsung UN55ES7003
            made house call.
            red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
            psu has self test feature.
            disconnected from mainboard.
            determined PSU ok BL ok.
            suspect mainboard.
            disconnecting tcon has no change on operation.
            markings on mainboard:
            BN97-06531P 0151
            BN94-06123R
            found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
            for 54$
            second house call:
            with replacement mainboard, tv turns on, has sound,...
            07-13-2022, 03:53 PM
