17MB82S : Detected but no signal
  • novak2
    • Jul 2020
    • 32
    • France
    Hello there.
    First, excuse me, because english is not my mother language.
    So, I have a Tucson TV model TL2204B274 for many years now, and the HDMI never worked.
    Let me explain.
    I have a laptop with an HDMI output (on Debian Buster), so I can test the output. When I connect via HDMI, it IS detected as a Vestel TV (which is obvious, since the internal board is a Vestel 17MB82S).
    But, when I switch source to HDMI ON the TV, it says "No signal" (with the 5min timer).
    The sub board which contains the LED and the IR receiver have been broken years ago, but I managed at least to resolder the IR receiver, so remote control works fine.
    I tried to update the firmware with the correct instructions, but it DOESN'T update (or at least I don't know, since I don't have the LED.
    Note also that I manage to have a "new software" but was a bad one (glitchy yellow screen), but only on the USB, and it only worked ONCE. I managed to find the correct 17MB82S update PKG file, but I CANNOT boot on it.
    So, what is going on with my HDMI ? And also how can I update the firmware since it doesn't boot (or once within thousands of trials) ?
    Thanks !
  • Diah
    • Feb 2013
    • 6614
    Re: 17MB82S : Detected but no signal
    so my questions.. what do you have on screen when you first time plug your tv on .. please post the result over here with photo
    • novak2
      • Jul 2020
      • 32
      • France
      Nothing particular, TV works fine, but I just cannot boot the "upgrade_loader.pkg" from the USB and HDMI does not work even if it is detected.
      And what do you mean by "first time" ?
      • novak2
        • Jul 2020
        • 32
        • France
        No one for any help ?
        Tested different things but still cannot upgrade 17MB82S (Vestel) firmware...
        • yokoono
          • Apr 2010
          • 515
          Type MENU and 4725 and put a picture.
          • novak2
            • Jul 2020
            • 32
            • France
            I'm at work right now, but in 2h you will have it.
            What I remember if it can help :
            Version is 0.7.8
            Over 3000 hours of life time.
            But just wait for the picture thanks
            • novak2
              • Jul 2020
              • 32
              • France
              Here you have it, the service menu.
              • yokoono
                • Apr 2010
                • 515
                Latest software version: 1.3.7. Type MENU and 1505 and install.
                • novak2
                  • Jul 2020
                  • 32
                  • France
                  Thanks it worked !
                  But still no HDMI output...
                  • novak2
                    • Jul 2020
                    • 32
                    • France
                    Maybe it is some kind of Hardware failure. But it is very strange since my laptop detect the HDMI as a Vestel monitor....
                    But thank you very much for the 1505 code !
                    And a small and not that important question :
                    One time, with an "upgrade_loader.pkg" which wasn't the correct one, I manage to boot the TV in a strange mode. It was all yellow glitch screen, but it has some fadeout when I push buttons and all. Also, it didn't install anything on the TV, I just shut down and remove the USB and all was back to normal. Any clue of what that is ?
                    I did it with the "Turn on the TV while pressing OK on RC" method.
                    • budwich
                      • Jul 2015
                      • 3097
                      what other hdmi sources have you tried?
                      • novak2
                        • Jul 2020
                        • 32
                        • France
                        So I tried :
                        - Laptop Debian Buster (with XRANDR)
                        - Nintendo Switch
                        - Sony Playstation 3 (with correct settings to set the output to HDMI)
                        None of them worked, but on the laptop the HDMI is detected.
                        I only have 1 HDMI plug on the TV (even if it says HDMI 2 enabled on the service menu).
                        • novak2
                          • Jul 2020
                          • 32
                          • France
                          Note that I have a brother with the exact same TV but his HDMI works.
                          So I very suspect hardware failure.
                          • higuys
                            Does anyone have Bob Carver Sunfire Ultimate Receiver Firmware Update 3.22?
                            by higuys
                            Hi everyone, I posted this over in AVSForum and someone mentioned I should try posting here. Does anyone have Sunfire Ultimate Receiver Firmware update 3.22? Sunfire only has version 3.20 on their website, I was told by one of the few people that worked on these units 3.22 is the latest version but his computer just stopped working. I've emailed Sunfire several times and they won't respond or update the version on the site. Any help is much appreciated!
                            06-11-2023, 12:37 PM
                          • AstutePauciloquent
                            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                            by AstutePauciloquent
                            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                            11-23-2023, 11:02 PM
                          • glutton4punishment
                            Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                            by glutton4punishment
                            Samsung synchmaster 226BW.
                            Before I replaced 5 caps, the screen was dim.
                            Sometimes it wouldn't turn on.
                            I opened it up, and found 4 bad caps in the pwr supply section.
                            I unfortunately installee one backwards, i.e. wrong polarity.
                            When I turned it on, I head a loud pop, and I quickly shut it off.
                            The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                            One of the 860uF blew.
                            I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                            03-18-2023, 12:49 PM
                          • Capestang
                            Yamaha DSP-AX861SE Sub problem
                            by Capestang
                            I really hope someone will be able to help me?
                            I have recently moved house and dismantled a working 5.1 home cinema
                            system. Unfortunately when putting it back together again I get no
                            sound out of the sub, I'll try and give you as much (probably too much)
                            information to hopefully allow you to sort my problem, or at least
                            point me in the right direction.
                            * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
                            various sources and outputting through speaker cables to 4 x Monitor
                            Audio Radius 90s, 1 Radius 225...
                            01-24-2023, 04:00 AM
                          • EvazX
                            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                            by EvazX
                            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                            However, after some time, the replacement motherboard...
                            08-25-2025, 06:09 PM
