Yamaha DSP-AX861SE Sub problem
  • Capestang
    Nick
    • Jan 2023
    • France
    I really hope someone will be able to help me?
    I have recently moved house and dismantled a working 5.1 home cinema
    system. Unfortunately when putting it back together again I get no
    sound out of the sub, I'll try and give you as much (probably too much)
    information to hopefully allow you to sort my problem, or at least
    point me in the right direction.
    * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
    various sources and outputting through speaker cables to 4 x Monitor
    Audio Radius 90s, 1 Radius 225 and a via the dedicated sub pre out
    via a high quality RCA cable to the Right line level input of a RS
    W12 sub
    * When using auto set up with the dedicated microphone connected to
    the receiver for the new room the wiring to the sub was not detected
    with the receiver indicating a 3/2/--- system
    * So my first problem was trying to sort out if it was the receiver,
    the cable or the sub
    * I switched in two different cables with the same result so was
    fairly confident that it wasn't the cable
    * After much searching on the internet I found a quick test to see if
    a sub is working, with all power off remove the sub cable from the
    receiver, then power up the sub and tap a finger on the centre post
    of the cable and an audible "thump" should be heard. I got two
    "thumps" but after this no more and it has not done this again
    despite numerous attempts
    * Next I disconnected the sub and using an RCA to phono cable adaptor
    I connected the receiver sub pre out to a powered stand alone ipod
    speaker.
    * When sending a test tone from the receiver to selected speakers I
    was able to hear an output from the stand alone speaker when the sub
    test signal was selected
    * When I ran the auto set up it detected the wiring
    * Next I reconnected the sub as before and this time used the Left and
    Right line level outputs on the sub to connect to the stand alone
    speaker. Again a test tone could be heard from the stand alone
    speaker but not from the sub itself
    * When I ran the auto set up the wiring was detected, and the test
    tone could be heard from the stand alone speaker, but not the
    sub, and the receiver indicated a 3/2/0.1 system
    Therefore from the above I concluded that:-
    * The receiver output an LFE signal from it's dedicated pre out
    * This was successfully carried by the cable
    * It reached the sub
    * The sub was not able to output a sound itself
    * The sub was able to pass on the LFE input to another speaker
    Thanks in advance
    Nick
  • budwich
    • Jul 2015
    • 3097
    Re: Yamaha DSP-AX861SE Sub problem
    Is this the service manual for your unit? Probably going to have some fun trying to service the plate amp as most subs that I have seen, have glued down components and such. Hopefully, the schematic will help you find where the signal stops in the sub.
    I wasn't sure about whether you have tried the sub in "auto" mode versus "on".
    • sanalelevenstar
      Yamaha RX-V485 receiver. After encountering a "version error"
      by sanalelevenstar
      I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
      After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
      I managed to find the service...
      09-10-2025, 01:54 AM
    • Pete D
      Yamaha HTR-5460 Receiver protection code info.
      by Pete D
      Hi Guys, My first time on the forum.
      I have a Yamaha HTR-5460 Receiver that I have used for a few years. It has recently developed a problem of giving a pop in the speakers and then shutting down. This is intermittent and might happen after an hour or a couple of days of playing.
      I have put it into Diagnostic Mode and it comes up with code “PS PRT 020 B”. According to the service manual “PS PRT” signifies a power supply problem in the mains transformer, 5V or 12V DC supplies. I'm assuming that the “020 B” part of the code would define which one of these...
      11-03-2023, 07:00 AM
    • DXseekerMO
      Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
      by DXseekerMO
      Hello everyone!
      Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
      Symptoms:
      1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
      2) TV does not appear to turn on
      3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
      4) "Power on" terminal on Power Supply has 3.26v
      5) "A13V" terminals have 12.9v
      6) Stand-by test jumper on Power Supply has 12.9V
      7) Optical audio jack on Main Board illuminates
      8) With stand-by...
      06-09-2021, 12:19 AM
    • alfredomfr1
      YAMAHA AV Receiver RX-V585 No Power
      by alfredomfr1
      120v ok, No voltage on the connectors, Fuses OK, 165v DC on the main capacitor...
      09-12-2023, 09:47 AM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
