Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
  • glutton4punishment
    • May 2013
    • 81
    Samsung synchmaster 226BW.
    Before I replaced 5 caps, the screen was dim.
    Sometimes it wouldn't turn on.
    I opened it up, and found 4 bad caps in the pwr supply section.
    I unfortunately installee one backwards, i.e. wrong polarity.
    When I turned it on, I head a loud pop, and I quickly shut it off.
    The replaced caps are 3 860uF 25V's, and 1 330u 35V.
    One of the 860uF blew.
    I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close to 950uF, so I figured it was close enough to 1 kuF)
    Now, it:
    1. shows no signal detected (the signal's fine, check w/other monitor)
    2. the menu buttom doesn't work.
    Does anybody think replacing the 1000uF cap will help?
    What else should I be looking at to explain my problems?
    Thanks!
    master hoarder
    • May 2008
    • 12175
    Re: Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected"
    If you had 5 bad caps before, where were they and what (brand and series) were they replaced with? Same with the PSU board - what brand and series did you use for the new caps.
    Using the 1000 uF cap in place of the 820 uF cap shouldn't be the issue behind the problem you have.
    Could you post top and bottom side pictures of the power supply and logic board?
    I suspect the menu button not working could be a different issue now - perhaps bad solder joint, bad front panel cable, or damaged button board / cable assembly from taking the monitor apart twice.
    The signal not getting detected could be from any remaining bad caps on the logic board. Hence why I suggest to post pictures of both boards so we can see what you are seeing.
      • May 2013
      • 81
      Thank you for your reply, momaka!
      I'm confused about what the problem is.......but I don't think it's my cap replacement.
      I can get a very poor quality VGA pic.
      While the VGA cable/signal is input, the menu buttons on the monitor work
      But no DVI signal recognition at all.
      And menu buttons don't work when DVI is plugged in.
      I've used other monitors, and the DVI signal is good with other monitors.....
      When the DVI is connected, I don't even get a start up boot screen, and I've looked in the BIOS for settings, to no avail.
      BUT I am sure that I had the monitor working on the DVI side before I changed the caps.....
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
        by momaka
        03-15-2023, 10:17 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
