moms vizio vx42L screen flickering
  • Slimerang
    • Jan 2012
    Re: moms vizio vx42L screen flickering
    I have similar problem witha 2007 42" Vizio LCD. Opened it up but don't see any obvious problems. This unit has intermittent flashing with it happening 95% of the time. It does however never flash when I give it no signal. It shows that blue screen with the words "no signal" floating around the screen. I'm wondering if this means its not the power supply board. Any ideas/comments? Thanks
    • awyatt2
      • Feb 2012
      • 407
      • america
      did you check the caps on the inverter boards? had the same problem with another model vizio and turned out to be the inverter caps. esr was off scale.
        Check and see if your TV uses these inverter boards if the LCD panel is made by LG.
        • Slimerang
          • Jan 2012
          I'll have to open it up and check. I remember two boards on either side the back panel that I seem to remember being directly attached to the LCD panel itself.
            It may have the same chassis as the VO series:
            http://s807.photobucket.com/albums/y...VO42LFHDTV10A/
            • theGinsue
              • May 2012
              COMMENT EDITED AFTER READING ENTIRE THREAD.
              BTW: Fantastic forum you have here.
              • lookimback
                • Aug 2013
                • 1489
                Sorry to bump this very old thread but I need some advice. I'm looking at my boss' vizio vx42l right now. It has same problem with screen flashing. I think its the caps on the inverter boards. I don't have a multimeter so I can't test the caps. I'll buy one today when I go out. All 4 caps are rounded on top. Not flat like the ones on the power board. Is this a physical indication that they are bad? Thanks
                ------------signature starts here------------
                • lookimback
                  • Aug 2013
                  • 1489
                  Well, I guess it is the caps. I found my own answer in the FAQ thread.
                    Yes, those sound bad.
                    Do not use capacitors from radio shack or other retail stores as they will fail in short order or not work at all.
                    Panasonic FC/FM/FR work well, Digikey and badcaps.net should sell them.
                    • lookimback
                      • Aug 2013
                      • 1489
                      Thanks for the reply. I ordered these http://www.digikey.com/product-detai...5554-ND/245153 from digikey. I hope they are OK. They are Panasonic.
                      • lookimback
                        • Aug 2013
                        • 1489
                        OK I looked at the data sheets and see that the ripple current is significantly different. I contacted Digikey and changed the order. Thank you Tom. You just saved me from looking like I didn't know what I was doing. These are the ones I'm going to use.
                        http://www.digikey.com/product-detai...0301-ND/266310
                          Those are suitable, they should fix it. Enjoy.
                          • lookimback
                            • Aug 2013
                            • 1489
                            • lookimback
                              • Aug 2013
                              • 1489
                              Well, I put the new caps in about a week ago (Panasonic FCs) and its been working great ever since. Thanks again for the help.
                              • Ltank
                                • Jun 2013
                                • 776
                                I had the same problem too. And replacing the caps fixed it. Before it had Blue flickering backlight. The power supply voltages were fine. I tested it with new caps that were correct uf but the voltage rating was too high that made the cap too large to fit where I needed it to. Normally a higher voltage cap of the correct uf is fine but the space will not allow it. I sar the bulges on the cap then turned on computer to see what the forum had and there it was! Great Job Guys
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  I used Panasonic FCs. Here is a link for them at digikey. This thread brought me here as well and revived my long lost hobby.
                                  • spice_disc
                                    Vizio TV M50-C1 reboot cycle and static on screen
                                    by spice_disc
                                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                    09-08-2024, 02:37 PM
                                  • Ado02
                                    Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                                    by Ado02
                                    We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                                    The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                                    12-16-2024, 02:33 PM
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • survivalbloke
                                    HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                                    by survivalbloke
                                    SN: 8CG0213H8W
                                    ProdID 3C311UA
                                    This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                                    05-08-2025, 12:21 PM
                                  • smic717394
                                    by smic717394
                                    07-25-2024, 10:16 AM
