TCL Model 55S405 - No Pic, No Backlight, No Sound - HELP!!!
  • koolx
    • Jun 2020
    • 27
    Re: TCL Model 55S405 - No Pic, No Backlight, No Sound - HELP!!!
    Check the sticker numbers on the panel/back chassis see if they match.
    The person from whom I want to buy the tv is too weak to bring the tv down from its wall mount. So she cant read off the stickers from the back of the tv. Is there another way to do that?
    • koolx
      • Jun 2020
      • 27
      Someone wants to buy this tv from me for $90. Do you guys think its worth that I should sell it or try to fix it?
      • nomoresonys
        • 12129
        • U.S.
        #43
        Probably a pretty good tv you have there, probably just a matter of what's wrong with it, which may be found with proper testing but it's work and not always easy if inexperienced with electronics.
        • koolx
          • Jun 2020
          • 27
          Hi nomoresonys. I hear ya. I'm experienced with replacing parts on laptops and I built my own custom PC if that qualifies me for a "techie." Not completely inexperienced by those standards. It does seem like an easy fix just a matter of dialing in on what part should be replaced.
          The tv itself is enticing me to keep it to fix it. The only drivers keeping me from embracing it fully are the viewing angle which gets cloudy and the low brightness level. I want a bright tv not one where I have to struggle to make out images. But if you think these factors are mitigating let me know.
          Looks like budman is busy working today. Hope he reads this today and get his input.
          • nomoresonys
            • 12129
            • U.S.
            #45
            If you got a meter working properly, try the tests in post #20, they're pretty simple, the test is on the cold side of powerboard, the HOT/PRIMARY side is the side with the DEADLY VOLTAGES and you MUST be very careful when working in that area, number 2 below shows a video tutorial.
              I'm waiting for your test result in my post #20.
              Did you read it and understand it?
              Did you verify that the meter is good for sure at this point?
              • koolx
                • Jun 2020
                • 27
                Hi budman. I will get those readings out to you. I ran into an unexpected snag today. All I ask is just a little bit more patience. Thank you budman.
                • nomoresonys
                  • 12129
                  • U.S.
                  #48
                  Well I was referring to the panel sticker info, which is on the back metal chassis of tv on a sticker, you need to take the back cover off to access it, guess you could see if there is a service code number on the back cover, might start with srv code or sum such.
                  • koolx
                    • Jun 2020
                    • 27
                    Thats too much work for the person who owns that tv.
                    • nomoresonys
                      • 12129
                      • U.S.
                      #50
                      Figured it would be because you said they were old, there are 2 suggestions there, the other is just look at the back cover without removing and see if there is a service code number, other than that, I don't know.
                      • koolx
                        • Jun 2020
                        • 27
                        Hi nomoresonys.. when you say to "look at the back cover without removing" do you mean the stickers on the back of the tv that contain info like serial number?
                        • nomoresonys
                          • 12129
                          • U.S.
                          #52
                          Yes indeed.
                            So where is the follow-up?
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • nickgronk
                              iMac PowerPC G4 very low sound • Sunflower Model
                              by nickgronk
                              Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
                              I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
                              I cannot find any schematics...
                              08-05-2024, 07:04 AM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
