LG UF6450 half screen is black, half is blue/white
    • 12206
    • U.S.
    #41
    Re: LG UF6450 half screen is black, half is blue/white
    That's a good question, maybe some of the guys familiar with these UF's can advise, seems kind of scarey with the XDA engine BGA chips being known to fail way too early and mainboards being so scarce and expensive.
    • budwich
      • Jul 2015
      • 3097
      Originally posted by jskuyper
      If the tcon board replacement had no effect. Is the next thing to go to is the main board or am I just throwing money away? I see the tcon ribbons attach to another board assuming that is the lcd. Could it just be a bad lcd?
      there are some VCOMxxxx points near the tcon to panel connectors... you might check and list those also. Further, some of those voltages that you already posted can be found / should be found on the bottom edge / driver boards of the panel. You might also check some of those.
        At this point I would check the resistance of MLCC's (Multi Layer Ceramic Capacitor) on the tab bonding board, it does not cost any money to do that.
        • jskuyper
          • Jun 2020
          • 23
          What should these values be
          • jskuyper
            • Jun 2020
            • 23
            Vcomrfb 5.64
            Vcom1 5.68
            Vcom2 5.9
              • 12206
              • U.S.
              #46
              Check them in ohm mode, probably be suspicious of any under 100 ohms or so.
              • Unspun01
                • Jun 2011
                • 349
                This TV has a bad mainboard. In fact, the main IC (IC100) under the black heat sink in center of board has failed. IC100 is a Ball Grid Array IC part number LGE5332 (XD Engine). My mainboard is EBT64048902, with TV model 55UF6450.
                Either replace the mainboard, or replace the IC.
                Re-flowing or re-balling the IC will not work.
                This appears to be a common failure mode of similar LG 4K LED TVs. I've seen a few 55" LG 4K LED TVs that use same IC and similar issues.
                On my TV, I had one side with video, and one side not, often there was snowy picture, and even flickering. Could not get video on HDMI if I recall it only got black/white video through component/composite? The symptoms presented as a bad TCONN or a bad panel, but it was the mainboard that was bad.
                I got a good deal on a working replacement mainboard, but I bought a couple LGE5332 ICs on aliexpress.com for reasonable price in case I need to do BGA replacement
                Be wary of buying a used board since many resellers may think the TV has a panel issue and sell the mainboard as working but may actually be bad mainboard. I was lucky that mine was a good one. It would be helpful to ask for a photo of the TV screen showing video, (even with cracked panel)
                Here is a link to another thread on this issue:
                https://www.badcaps.net/forum/showthread.php?t=70107
                Apparently there is a revised board that addresses the issue, but I cannot recall the new part number.
                Reason for edit: I typed the wrong part number.
                • jskuyper
                  • Jun 2020
                  • 23
                  Found a new main board but continue to have issues. The screen will sometimes be all black and other times split with two colors or all static
                  • jskuyper
                    • Jun 2020
                    • 23
                    I guess it makes a difference mounting the mainboard down
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4343
                      • Italy - Milan
                      #50
                      First of all i think Unspun is right, but to be more precise it lacks some testpoints in tcon, Vgl1 & 2, VGH even & odd, the showed video tells of a lacking of a signal from mainboard to tcon where there is Hsync, you can also test it with the help of a screen datasheet or also without. I'm on a cellphone so i can't help you.
                      For the new chips found on Aliex i can say that almost surely them are used chips removed from boards.. and not surely working...
                      • Raulnn
                        TD Systems K50DLG12US half black and half white screen
                        by Raulnn
                        good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                        By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                        01-20-2024, 04:49 PM
                      • hcinne
                        Dell G15 ryzen edition black screen 2 amber 1 white
                        by hcinne
                        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                        07-23-2024, 07:56 AM
                      • maneatingmonkey
                        LED LCD TV Screen Half Black, Half White - Panasonic TH-65AX800A
                        by maneatingmonkey
                        Any idea what could be causing the left half of the screen to be completely black and the right half completely white?
                        No picture from any input or OSD. The audio, however, works fine. Also, the backlight changes intensity along with the input feed.
                        I've tested the voltages on all the marked test points I could find and everything reads OK.
                        I've tried applying both heat and pressure to the tabs connecting the panel to the buffer boards to no effect.
                        Unplugging the white ribbon cables going into the 2 buffer boards on the black half of...
                        02-28-2020, 07:22 PM
                      • VcemPzd
                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                        by VcemPzd
                        Hello everyone !
                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                        04-28-2025, 10:14 AM
                      • Ihandyrepair
                        sony 55X850D black screen no front white or red led light.
                        by Ihandyrepair
                        Hi guys
                        strange one
                        I have a dead Sony 55X850D
                        when plug in, black screen, no front white or red LED, no back light no screen
                        Voltages I get
                        3.3v LD/power and main board
                        reg 12V
                        reg 19V
                        3.3v on power on pin
                        no Tcon on
                        no tcon 12v
                        no BL_on
                        I do get BL_ERR 2.0v
                        I tried to bypass it by ground it but still get same symptom
                        I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                        or is possible the chip next to...
                        08-07-2024, 04:58 AM
