LED LCD TV Screen Half Black, Half White - Panasonic TH-65AX800A
  • maneatingmonkey
    • Feb 2020
    • 36
    Any idea what could be causing the left half of the screen to be completely black and the right half completely white?
    No picture from any input or OSD. The audio, however, works fine. Also, the backlight changes intensity along with the input feed.
    I've tested the voltages on all the marked test points I could find and everything reads OK.
    I've tried applying both heat and pressure to the tabs connecting the panel to the buffer boards to no effect.
    Unplugging the white ribbon cables going into the 2 buffer boards on the black half of the screen has no effect. Unplugging a ribbon cables going into a buffer boards on the white portion of the screen turns that quarter black.
    • 12206
    • U.S.
    Re: LED LCD TV Screen Half Black, Half White - Panasonic TH-65AX800A
    Do you have about 12 volts on each side of the tcon fuse? black - probe on chassis ground red + probe on each side of fuse.
    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
    • maneatingmonkey
      • Feb 2020
      • 36
      Yep, FP1 is continuous and measures 12V on both sides. The other test points labelled V__ measure fine too.
        • 12206
        • U.S.
        Maybe check the MLCC caps on the buffer boards, see if any of them read very low ohms.
        • maneatingmonkey
          • Feb 2020
          • 36
          I did some more probing and of the buffer boards and found that VDDA on the right two boards (white half) was 17.7V, while VDDA on the left two boards (black half) was 0V. I traced VDDA back to VAAR (right side) and VAAL (left side) on the T-Con board, and confirmed that VAAL was shorted to ground! I discovered a couple surface-mounted capacitors were to blame.
          Unfortunately, I can only find replacement V500DK1-CKS1 T-Con boards from overseas, which with shipping are all more than I'm willing to spend. Plus, I inadvertently damaged the contacts on one of the ribbon cables while testing Oh well, at least I've isolated the problem and know that the other boards are all OK to sell.
          • diif
            • Feb 2014
            • 6978
            • England
            Why not just replace the capacitors and damaged cable ?
              • 12206
              • U.S.
              Seems like a nice 4k tv, I think you already did the hard work, ie figuring out the fault, nice work, I would try replacing those bad caps and find a replacement ribbon.
              • maneatingmonkey
                • Feb 2020
                • 36
                What value caps would I even replace them with?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Measure the working ones on VAAR.
                  • maneatingmonkey
                    • Feb 2020
                    • 36
                    I don't have anything to measure capacitance with :|
                    • maneatingmonkey
                      • Feb 2020
                      • 36
                      So now that the short is gone, when I connect the right two buffer boards I now get an image on that half of the screen (instead of solid white). But when I connect the left two buffer boards instead, I now get vertical bars and no picture (instead of solid black).
                      I actually put back one of the SMD caps, since only the second one I removed was shorted, even though both were in parallel, and it didn't change anything. So I suspect that there is another fault either on the T-Con board, or somewhere in the buffer boards or panel themselves?
                      • viewerau
                        • May 2020
                        • 305
                        Any update?
                        Signature:Seemingly hopeless tv fixer
                        • RooTV
                          • Apr 2020
                          • 128
                          Hi
                          I know its a long shot but you didnt happen to open this up and get the part number of the LED's?
                          I have this tv and am looking at getting replacement LED's but only want to open it up once.
                          Cheers
                          • Raulnn
                            TD Systems K50DLG12US half black and half white screen
                            by Raulnn
                            good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                            By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                            01-20-2024, 04:49 PM
                          • hcinne
                            Dell G15 ryzen edition black screen 2 amber 1 white
                            by hcinne
                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                            07-23-2024, 07:56 AM
                          • VcemPzd
                            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                            by VcemPzd
                            Hello everyone !
                            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                            04-28-2025, 10:14 AM
                          • Ihandyrepair
                            sony 55X850D black screen no front white or red led light.
                            by Ihandyrepair
                            Hi guys
                            strange one
                            I have a dead Sony 55X850D
                            when plug in, black screen, no front white or red LED, no back light no screen
                            Voltages I get
                            3.3v LD/power and main board
                            reg 12V
                            reg 19V
                            3.3v on power on pin
                            no Tcon on
                            no tcon 12v
                            no BL_on
                            I do get BL_ERR 2.0v
                            I tried to bypass it by ground it but still get same symptom
                            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                            or is possible the chip next to...
                            08-07-2024, 04:58 AM
                          • Rescogitans
                            Panasonic cf 20 will no longer boot-only black screen
                            by Rescogitans
                            Hello all. Only my second post.
                            I have a panasonic CF-20C5142VM which was booting to bios with no issues. I needed to add an ssd that was not initially being recognized by the bios. Found a link that suggested that I disable uefi mode and clear keys then to reboot to allow bios to now see New ssd. After restarting, screen is entirely black with no image. Found another post that suggested unplugging bios battery because some remnants of the bios may still exist in other parts of board but did not fix issue-screen is still black.
                            Anyone run across something like this before?...
                            12-07-2022, 12:04 PM
