TV LG 55UF6450 -- OSD ok -- AUDIO ok --- BUT NO VIDEO ON ANY INPUT-- ANY IDEAS ?
  • anibal2100
    Anibal
    • 31
    Hi guys, got this LG (Ultra High Def) with the issue mentioned in the subject. The menu shows fine and sound is perfect but the video is totally scrambled on any input included tuner. Internet works fine also Netflix...
    This is the second TV I get with the same exact problem, in the previous one I replaced the video processor (LGE5332) and it didn't fix the issue so I just replaced the mainboard and the TV went back to normal.
    This time I'm trying to fix the issue since I saw many guys on ebay offering their services to fix this problem in the mainboard so I guess should be something not so complex.
    As always thank you in advance for any help
    Anibal
  • Wilderone
    • May 2018
    • 76
    Re: TV LG 55UF6450 -- OSD ok -- AUDIO ok --- BUT NO VIDEO ON ANY INPUT-- ANY IDEAS ?
    You need to replace the XD engine chips;
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I bought one of these unit (T-862++) quite some time ago and I'm far from impressed with it. I appreciated that it would take some experimenting with it to get it right but I found the control far to course and now it sits under the bench.
      I would be interested in hearing from anyone who uses this successfully.
      • anibal2100
        Anibal
        • 31
        HI Wilderone, thank you for the advice. I already did that in a previous TV having exact same problem but it didn't fix the problem. XD engine = LGE 5332. Yes , that's the logical path to follow since all inputs go strait to the XD. I agree.
        In other forum somebody said it can be a Tuner circuit issue since the Tuner is not only used to demodulate RF channel but also sends kinda clock signal to the XD to process HDMI and RCA inputs. Sounds weird to me but may be is possible. What do you think ?
        Did you have a similar case and was fixed replacing the XD ?
        Thank you
        • anibal2100
          Anibal
          • 31
          HI Dick, got one of those T862+ long ago and for me was frustrating because IR is only useful for small chips like phones or tablets. Now I use only hot air (Forestall RD5680) and works nice !
          Hope this helps
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8182
            I second the main IC.
            • anibal2100
              Anibal
              • 31
              @CapLeaker
              Hi there, you refer to the XD engine ?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8182
                Look at the HDMI port and follow it back. I think yours goes back to the main IC, which has a heat sink. Since there is no picture provided, I went to SJ and looked up the main board. IF it is a XD main IC, they are prime suspect. IF it is not an XD IC, but the HDMI still goes to the main IC, it is still a prime suspect.
                Some have another IC between the main IC and the HDMI port. IF that is the case, that switching HDMI IC is prime suspect. Hopefully that makes sense to you. Maybe upload a straight shot, high resolution picture from YOUR main board.
                • anibal2100
                  Anibal
                  • 31
                  Yes HDMI tracks go strait to the XD (no switch IC) Yes looks like the XD is to blame.
                  I was reviewing my previous case and I think that I was wrong I just reflow the engine not replace it.
                  So I'll order another XD and I'll post results after replacing it..
                  Thank you so much for your help !
                  • Wilderone
                    • May 2018
                    • 76
                    I spoke to an LG tech directly about this fault, he told me it was the XD engine chips, he also pointed me toward the revision boards available that address this fault.
                    He said they replace those chips, but if in warranty they replace the board with the revised ones.
                    Hope this helps.
                    • anibal2100
                      Anibal
                      • 31
                      Ok.Thank you for the info !
                      Do you know if they have any "revised" schematic for the board also ? or it's the same with a new edition of the engine ?
                      Since I'm about to purchase new XD, will be useful to know if they have a new coding or different version of the LGE5332 (XD engine in this mobo)
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Hope this helps
                        Thanks. Yes I only use a hot air station now.
                        • Wiebotje
                          • Jan 2021
                          • 9
                          • Belgium
                          Old topic, but i have the same problem and i'n curious. Got any progress with the TV?
                          • Tecc1229
                            • Jul 2017
                            • 16
                            Not to necro an older thread, I have the same issue with little luck finding replacement boards. Looking for the revised version of the "EBT64048902". Anyone have a part# or sku for the newer version?
                            • neilc6
                              • Nov 2015
                              • 1550
                              Seller kcrownie on ebay offers a repair service for this board. Have used him multiple times. https://www.ebay.com/itm/114307268026
                              • Tecc1229
                                • Jul 2017
                                • 16
                                Thanks for the info
                                • samson7point1@yahoo.com
                                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                  by samson7point1@yahoo.com
                                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                  The player processes the audio signal using two different reference frequencies. The "R"...
                                  04-30-2024, 11:22 AM
                                  HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                                  This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                                  09-12-2024, 03:36 PM
                                • Hakuu
                                  by Hakuu
                                  Hi There,
                                  More Details
                                  TV Model - LG OLED77G1PUA
                                  07-12-2023, 02:37 PM
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                • ItepK
                                  Panasonic TX-P42G30E green light blinking, no video, no audio
                                  by ItepK
                                  Hey everyone!
                                  I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                  This post describes my entire troubleshooting process of this TV.
                                  When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                  I've taken the unit apart, and I've started to check some voltages:
                                  • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                  12-22-2023, 05:06 AM
