Vestel 50 inch LED backlight, Sound, No picture.
  • Ronan Wood
    • Sep 2016
    • 29
    • England
    Hello, I was recently given this tv by a family member.
    model LUXOR LUX0150004 01
    screen VES500UNDA 2D N03
    Power 17IPS71
    MB 17MB95
    TCON T420HVN06.3 CTRL BD 42T34-C03
    I have only carried out basic repairs to tvs in the past. Changing capacitors and LEDs ect. And have not yet come across this fault.
    The backlights light, the tv responds to the remote indicating the software is ok but no picture. Always a blank screen.
    As per the advice on other similar threads I removed and cleaned the contacts on the LVDS cable to no avail. I have also attempted to remove each of the 2 ribbon cables coming out of the TCON board to still have the same blank screen.
    I am thinking I have a panel fault or a faulty TCON board. I have no idea how to identify the small components on there or how to test / verify this.
    Please see attached pictures of the TCON board.
    Any advice is greatly appreciated, Thanks.
    Re: Vestel 50 inch LED backlight, Sound, No picture.
    Did you verify that you do have 12v dc at both ends of the SMD fuse of the T-CON board with ref to chassis gnd?
    If you do have 12V DC, then what do see on the screen if you have only one cable between the T-CON and the LCD panel connected one at at time?
    • Ronan Wood
      • Sep 2016
      • 29
      • England
      Is there any way for you to point the fuse out to me ? Does it have the letters F101 above it ? cheers.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You can check you have 12 volts at the test points V12INI and V12
        • Ronan Wood
          • Sep 2016
          • 29
          • England
          Yes 12 volts at v12IN1 and V12
          If I unplug each of the ribbon cables there is no change to the blank screen
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            So you do have 12V supply to Tcon and fuse is OK.
            Do you have sound or any indication that it responds to your remote control?
            Also, did you flip up the black bar on the Tcon connector to remove / insert the ribbon cables. If you did not then the ends of the ribbon cables may be damaged.
            • Ronan Wood
              • Sep 2016
              • 29
              • England
              Yes I do have sound and it does respond to the remote and auto standby so the software must be ok. The backlight is also on.
              The black bar was flipped and ribbon connectors are in perfect condition. I am very careful.
              I tried only having one ribbon connector in at a time as suggested above. This did not make any difference to the blank screen.
              Yes 12 volts at the test points you suggested
              • budwich
                • Jul 2015
                • 3097
                Normally, when one tcon to panel cable is disconnected, that "half" of the screen goes a "nice clean white" while the other side shows some form of picture. Please recheck this test. If necessary, post a picture.
                • Ronan Wood
                  • Sep 2016
                  • 29
                  • England
                  I have disconnected each panel to TCON cable and trust me the screen does not change at all. Only backlight showing
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    The Tcon has a number of test points where you can take a reading with your meter.
                    VGH by C704
                    VGL by C702
                    VSS by R202
                    AVDD by L204
                    AGIN by C113
                    Perhaps someone could interpret the results as to whether or not they look normal for the tcon.
                    • Ronan Wood
                      • Sep 2016
                      • 29
                      • England
                      VGH 0.18v
                      VGL 0.16V
                      VSS 0.02V
                      AVDD 0.34V
                      AGIN 0.00V
                      The above voltages were taken with the tcon connected to the pannel
                      Below with the pannel disconnected.
                      VGH 1.25
                      VGL 0.05
                      VSS 0.00
                      AVDD 1.34
                      AGIN 0.00
                      • Diah
                        • Feb 2013
                        • 6498
                        i faced before 6 years or so same issue with TOSHIIBA 3d set which its was also from Vestel. i went direct to replace the TCON and the picture come straight clear
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Those voltage are really low and would be immediately suspecting the Tcon is at fault.
                          These are a typical Tcon voltage given by another member but obviously for his Tcon however the voltages I would expect to be within the range shown.
                          T-con voltages (typical)
                          1. Vin (Vcc): 12Vdc or 5Vdc
                          2. Vlogic,LCM, Vddd,VCC): 3.3Vdc
                          3. Vda (Vs, Vsource,VDD, Vdda,Avdd): 14Vdc~20Vdc
                          4. Vgh (Vgon,VGHR, Von, Vddg): 20Vdc~30Vdc
                          5. Vgl (Vgoff,VST,VGHF,VGHEVEN, Voff,Veeg): -5Vdc~-7Vdc
                          6. HVDD about 8v
                          7. DVDD,VDDC 3.3v, 1.2v
                          8. VCOM about 5~10vdc (about half of Avdd)
                          • Ronan Wood
                            • Sep 2016
                            • 29
                            • England
                            Thank you very much for your time helping me with this.
                            I will replace the TCON and let you know if it is successful. Luckily enough these are only about a fiver on ebay.
                            Im glad there are people around willing to donate time and knowledge to keep these things out of landfill.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Good luck.
                              • sordids999
                                • May 2013
                                • 2161
                                • uk
                                Any update on this issue ?
                                • sordids999
                                  • May 2013
                                  • 2161
                                  • uk
                                  Exactly the same fault
                                  Backlight but no image on the screen,even if I disconnect the tcon ribbons one at a time it makes no difference what's so ever
                                  • nomoresonys
                                    • 12307
                                    • U.S.
                                    If your getting the same low voltages at the test points, it's probably the tcon at fault.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      If you disconnect the tcon ribbons from the panel strip with the set powered off and then power up again do the tcon test voltages change?
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        • uk
                                        Tcon ribbon connected
                                        VGH 0.10V
                                        VGL 0.00V
                                        VSS 0.10V
                                        AVDD 0.27V
                                        AGIN 0.00
                                        Tcon ribbon disconnected
                                        VGH 1.21V
                                        VGL 0.05V
                                        VSS 0.00V
                                        AVDD 1.31V
                                        AGIN 0.00V
                                        Any reason why theres nothing on the screen when you disconnect one ribbon at a time?
                                        Normally you get a white screen each side
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • Raulnn
                                          Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
                                          by Raulnn
                                          Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
                                          The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
                                          11-15-2022, 03:02 PM
