Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
  • Raulnn
    • Nov 2022
    • 103
    • España
    Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
    The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops to almost 30v. If you disconnect the lighting, it does the same thing but it starts at 0v and ends at 0v. In the source there are present 12v, and 3.2v. Let's see if they can help me. Thank you very much in advance
  • nomoresonys
    • 12269
    • U.S.
    Re: Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
    probably a backlight issue, bad led/s or connection in backlight circuit.
    • Raulnn
      • Nov 2022
      • 103
      • España
      but it has no image, nor sound. I have tried to check with a flashlight and there is no image. I don't know if this can be caused by a failure in the backlights, as protection. I want to be sure before opening.
      • nomoresonys
        • 12269
        • U.S.
        of course it can, protection will kick in and shut everything down, tearing a 32 inch down isn't a hard task, I can usually tear one down in in less time than it takes to test everything else, these small ones that is, not the big screens.
        • Raulnn
          • Nov 2022
          • 103
          • España
          ok, thanks for your answer. the problem pointed to that... but it was to be clearer. The standby system and the remote work perfectly, but the rest doesn't. I'll try the backlight. Thx
          • nomoresonys
            • 12269
            • U.S.
            just need to be careful the smaller screens dont break as easy as big ones but still use caution, specially on reassembly, take notes and maybe pictures of how it comes apart, some are trickier than others, take it slow and make sure it lies flat and even, just a little bump or misalignment can cause a crack when its put back together, even a little crack in the screen is fatal.
            • Raulnn
              • Nov 2022
              • 103
              • España
              update! It was the backlight, 7 leds burned out, backlight changed and working
              • nomoresonys
                • 12269
                • U.S.
                Well glad to hear it, thanks for the followup.
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • triplefour
                  TCL 75S421 has sound but no backlight not even a flash
                  by triplefour
                  TCL 75S421
                  PSU BOARD: 40-L402H8-PWD1CG
                  it shows not even a flash of backlight when powering up.
                  but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                  testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                  unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                  i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                  with mb connected, PSON...
                  11-17-2023, 09:54 PM
                • freccia
                  Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
                  by freccia
                  I have a Finlux/Vestel Led Tv with the following fault and cannot reason from where the fault is. Fault is:
                  Sound ok, Backlight ok, Picture nothing but colour vertical lines. power supply vestel 17 IPS 71, main board 17MB82S
                  Checked 12V on tcon on fuse ok.
                  Checked 12v and 24v on power supply ok.
                  Volume works. removed l left ribbon cable no picture white on half, and same with right one.
                  Any idea from where I can start please?
                  Any help appreciated please....
                  01-09-2022, 05:14 AM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
