Replaced LED. Lights on its own but not in the strip
  • RooTV
    • Apr 2020
    • 128
    I had 1 LED out on a Bauhn ATVS58-0516.
    I had some spares so I took one of an old strip (after making sure it worked) and took the bad one off the strip.
    I then put the replacement one on the strip.
    Now all the original lights light up (same as before) but the new one doesnt.
    I put the backlight tester on each side of the replacement and it lights up no problem.
    What am I doing wrong? This is the first time I have tried this procedure and I thought it went well.
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Replaced LED. Lights on its own but not in the strip
    Sounds like the LED got hot during replacement or the solder didn't take.
    They call me......."threadkiller"
    • RooTV
      • Apr 2020
      • 128
      I have tried it again and same result.
      Im thinking maybe the pad was damaged when the original led blew?
      The pic is the pad. Not sure how I would fix that?
      Or does it just need some solder on the bigger part of the pad? Looks like there isnt any on it
      • RooTV
        • Apr 2020
        • 128
        I tried putting some solder on the pad but made no difference so I assume that the pad is damaged?
        But is it fixable. Thas the question.
        • RooTV
          • Apr 2020
          • 128
          Added photo of led strip with new led on it (not working)
            So the LED strip with the replacement LED installed, all the LED's on that strip light up but not the replacement LED? Since the LEDs are connected in series so for the strip to light up but the replacement does not t hen the polarity of the replacement is back ward so the current flow through the protection Zener diode of the replacement LED instead, if you shorted out the pad then the LED should not light up when tested with the tester. What is the Vf shown on your LED tester? 3v or 6v?
              • 12331
              • U.S.
              Maybe use a resistor to bypass that led, hopefully one led off won't be too noticeable.
              • yokoono
                • Apr 2010
                • 515
                1. The LEDs can be 3 or 6v
                2. The LEDs can be with + or - on the big pad
                3. The LEDs are replaced by heating the strip on the back, not on the LED.
                • RooTV
                  • Apr 2020
                  • 128
                  I thought they were both 3v. but Im not 100% sure.
                  Does either of these pictures tell which it is? 3v or 6v? This is the original strip.
                  And the donor strip is the 3rd and 4th pic.
                  Please let me know how you tell what voltage they are, if any of these pics tells you.
                  Im very much a newbie but very keen to learn and appreciate any help I get
                  • RooTV
                    • Apr 2020
                    • 128
                    I turned the LED around on the pad and then none of the LED's on the strip would light up, so I assume that was on the incorrect way and was affecting the others?
                    • RooTV
                      • Apr 2020
                      • 128
                      I have tried 4 different donor LED's so far backwards and forwards, but havent had any luck yet.
                      2.8v on both the donor LED and original LED
                        So it is 3V LED then.
                        How about my question?
                        "So the LED strip with the replacement LED installed, all the LED's on that strip light up but not the replacement LED? "
                        • RooTV
                          • Apr 2020
                          • 128
                          Yes
                          I have tried the LED in both orientations on the pad. In the first way the strip lights up but not the donor, in the other orientation, no led's light up.
                          I assume this is what I have done. Is there any fix for this or do I just order another strip?
                            Yes
                            Well if the other LEDs are lit up but not the replacement that means the replacement LED connection is bypassed somehow, otherwise the other LEDs will not be on, it is series connected circuit.
                            • RooTV
                              • Apr 2020
                              • 128
                              If the led connection is bypassed, does that mean the tv will work when I put it back together again?
                              Or I need to get another strip to replace it
                              sorry Im a bit confused
                                Well, that is what is confusing to me that the replacement LED does not light up but the other LEDs are lit up OK on that LED strip, but you said the replace lights up when using the LED tester so it it means the pads of the replacement are not shorted (bypassed), that is what not making sense to me. You can bypass 1 LED without triggering the protection circuit but you may see dark spot on the screen when you have light shaded scene.
                                • RooTV
                                  • Apr 2020
                                  • 128
                                  Im sorry I may have phrased it badly and confused you.
                                  When I say that the donor led lights up, I mean that when I put the led tester directly on the led, not the pad.
                                  • RooTV
                                    • Apr 2020
                                    • 128
                                    Im not sure the tv will work without the led anyway as that is what I think was the issue with the tv not working in the first place. (well I was hoping it was anyway).
                                    The tv was given to me because it was not showing a picture, but I could see one using a torch, which Im told normally means a backlight issue.
                                    I will put the tv back together again now as I dont have the room to leave it dismantled while I wait for parts, but Im not expecting it to work.
                                    I was really hoping to get the led fixed today as this thing is a real pain in the ass to pull apart and reassemble and everytime I have to do it means more chance of me doing something nasty to the screen
                                      When the LED goes open circuit, as per your original problem, the protection circuit will kick in, if too many LEDs are bypassed the protection will also kick in, but bypassing one LED may not trigger the protection circuit.
                                      It is beat to replace all the strips and the turn down the backlights level on all input mode and do not set them to other backlights mode, I.E. Dynamic, etc.
                                      • RooTV
                                        • Apr 2020
                                        • 128
                                        If I could get all the strips - they are bloody hard to find although I havent checked alib express yet - I would replace them all.
                                        I have to determine if its the only problem on the tv first, otherwise it isnt feasible.
                                        I do appreciate all your help and thank you very much.
                                        • joesmoe91
                                          Dell Precision 5530 15" died to blown chip. Replaced chip and now only get momentary fans, lights, no screen or boot
                                          by joesmoe91
                                          My Dell Precision 5530 turned off suddenly when I was running Matlab and wouldn't turn on, show any lights, fans, and/or any signs of activity at all. I opened the case, removed the battery and looked at the board with a thermal camera while the AC adapter was connected. I saw that PU1252 was >120C so figured the chip had died on me Got the part number off the attached schematic (see Mouser link below) and replaced the chip. After replacing the chip the board (connected to AC adapter) was able to briefly power on, spin the fans a little bit, and turn on the front led lights....
                                          02-22-2024, 07:38 PM
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • giddyupngo
                                          Backlight replacement mess, Vizio V505-G9
                                          by giddyupngo
                                          Hello, I would appreciate your expertise on this. I have about 5 years experience with copier repair, so I have done a lot of board and component replacement. This is the first LCD TV I tried to repair, and it really humbled me. The issue was that on power on the TV power light would go on and then fade out seconds later, and there was no image at all, screen stayed black.
                                          I thought this meant there was a power board problem, not realizing that the power light fading out was by design, probably so the light would not distract the TV watcher. This is not my TV, so I wasn't familiar...
                                          02-09-2023, 09:14 PM
                                        • csmith
                                          Vizio-D50u-D1 Pulsating Backlights
                                          by csmith
                                          This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                          Am I looking at a defective strip? Thanks in advance.
                                          11-07-2024, 02:56 PM
