Vizio-D50u-D1 Pulsating Backlights
  • csmith
    • Aug 2014
    • 46
    This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
    Am I looking at a defective strip? Thanks in advance.
  • EazyBone
    • Jun 2023
    • 1360
    • United states
    Defective strip, loose connection PSU issue. Hard to know.
    I usually test them before assembling it all back together and make sure voltage is correct on all. Some tvs you can plug in while disassembled and the lights will come on, Samsung you need to disc the main board. Hisense disc the TCON at main.. etc to not short out the other components. I believe Vizio may work also but you need to hit the power button on the TV because the remote obviously won't work as it's disconnected. It gets bright 😎 😎
    You can try the led tester before disassembling it all, just disc the power board first. If ones defective it'll be lower then the others or pulsate
    • Diah
      • Feb 2013
      • 6497
      LED units depending on currents not Volts.. i would inspect one LED original and compare it with diode measurements with replacement..
      • csmith
        • Aug 2014
        • 46
        Today reseated connectors on backlights and now all is well. Take a break when your tired. As these sets will drain your energy. To confident put it together without checking which I normally do. Thanks Eazybone and Diah.
        • EazyBone
          • Jun 2023
          • 1360
          • United states
          Agreed. These Vizio's got so many damn screws and clips for the white deflector paper.. exhausting
          • max789
            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
            by max789
            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
            I made the following tests:
            1. Disconnected the main board from Power Board = backlight works.
            2. Connected the main board and disconnected the T-Con = backlights does not work.
            So I ordered a main board from Ebay also BN41-02156A but from...
            01-18-2024, 06:56 AM
          • bpcannan
            VIZIO M557-G0: Backlights or ???
            by bpcannan
            'Morning,
            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
            10-29-2023, 06:36 AM
          • Pize92
            Defective BIOS chip
            by Pize92
            Hello everyone.
            I have a problem.
            The BIOS chip on my Lenovo Legion 5 17ACH6H appears to be defective. I wanted to read the chip first with the ch431a programmer and then with the t48 and create a dump. However, it always threw an error during verification.
            I then bought a new BIOS chip from Aliexpress and loaded an existing dump onto the chip. With the corresponding DMI.
            Unfortunately, the laptop now keeps restarting.
            My question is, can you simply use the DMI from a foreign dump, or is the motherboard completely lost due to the defective BIOS chip?
            08-19-2025, 10:59 AM
          • rumpumpel1
            How do I find a defective RAM chip
            by rumpumpel1
            I have a ThinkPad T14 which always finds an error at a very specific address during a RAM test. I therefore believe that exactly one of the RAM chips on the mainboard is defective. How do I find this defective RAM chip?
            07-29-2025, 11:55 AM
          • x_orange90_x
            Sony KD-75X750H no backlights
            by x_orange90_x
            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
            07-16-2025, 07:49 PM
