Sony KLV32U300A starts up then shuts down
  • Admirality
    • May 2020
    • 80
    • South Africa
    Sony KLV32U300A starts up then shuts down with ared led blinking twice with a pause then again the same over,ould someone pls give advice on where to lookfor rhe error
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony KLV32U300A starts up then shuts down
    Are you certain it's KLV32U300A and not KLV-32V300A
    The led fault code for KLV-32V300A is attached
    • Admirality
      • May 2020
      • 80
      • South Africa
      Thanks Dick,it is definitely klv32u300a
      • Admirality
        • May 2020
        • 80
        • South Africa
        And thanks for your input,much appreciated
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Can you post nice sharp photo's of the circuit boards
          Have you taken any voltage readings?
            • 12322
            • U.S.
            Try test number 3 below, be sure to post the pin label/description, number and voltage.
              Service manual.
              • Admirality
                • May 2020
                • 80
                • South Africa
                Hi Dick no i hav'nt checked the voltages yet and i will post pics of the circuit boards,yesterday i switche the tv on and it actually came on for 5 minutes and switched off automatically but after that the same on off occured again.what can you make of that
                • Admirality
                  • May 2020
                  • 80
                  • South Africa
                  Does it sound like the power supply or could it be on another board
                    • 12322
                    • U.S.
                    It's just speculation until you do the tests.
                    • Admirality
                      • May 2020
                      • 80
                      • South Africa
                      Thanks nomoresonys
                      • Admirality
                        • May 2020
                        • 80
                        • South Africa
                        Hi Dick,i checked voltages on standby and all seem ok but when i removed one plug from power supply going to the main board then green light stays on which indicates that the fault is on main board but the led flashes 2 times still which according to the chart of blinking codes should indicate that the psu is the culprit,how do i post pics of the boards on here
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Post pictures by clicking on "Go Advanced" and then I add them one at a time.
                          • Admirality
                            • May 2020
                            • 80
                            • South Africa
                            Hi Dick i did go on advanced and added the attachments but how do i post them,when i add attachments on email i have no problem but on here i just dont seem to get it done
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              RJ gives an explanation on how to add attachments
                              https://www.badcaps.net/forum/showpo...18&postcount=4
                              • Admirality
                                • May 2020
                                • 80
                                • South Africa
                                Sorry it looks like i cant add attachments yet it states invalid post
                                • Admirality
                                  • May 2020
                                  • 80
                                  • South Africa
                                  • Admirality
                                    • May 2020
                                    • 80
                                    • South Africa
                                    Ok i finally managed to attach the psu and main board
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Can you give the voltages read on CN201, CN202 & CN203
                                      eg
                                      CN201
                                      Pin 1 GND
                                      Pin 2 GND
                                      Pin 3 PWR_6V = xxV
                                      Pin 4 PWR_6V = xxV
                                      Pin 5 GND
                                      etc for all pins
                                      • Admirality
                                        • May 2020
                                        • 80
                                        • South Africa
                                        CN201 Pin 1=GND 2=GND 3=5.63V 4=5.83V 5=GND 6=GND 7=5V 8=5V 9=GND 10=GND 11=14.60V 12=14.60V 13=GND 14=32V
                                        CN202 Pin 1=0.2V 2=0V 3=4.1V 4=GND 5=GND 6=GND 7=4.1V 8=4.1V
                                        CN203 Pins 1-5=0V And 6-10=24V
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • Shobos
                                          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                          by Shobos
                                          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                          Any help is welcome. Thanks !
                                          07-29-2025, 03:53 PM
                                        • IamPritesh
                                          Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
                                          by IamPritesh
                                          So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
                                          ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
                                          What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
                                          07-31-2022, 05:23 AM
                                        • PowerAmpFreak
                                          LG OLED 65B7V starts with green screen a few seconds then shuts down
                                          by PowerAmpFreak
                                          LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
                                          Can this be a sign of shorted ceramic caps in the T-con ?
                                          Best,
                                          10-07-2022, 10:27 AM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
