Hisense 50K23DGW
  • iblackford
    • Feb 2006
    • 7
    Hisense 50K23DGW
    HI All, I have a hisense 50K23DGW that flashes the red status LED 11 times on startup. No other sign of activity.
    While the LED is off or flashing (trying to start, or after it tried to startup) I get the following voltages on the PS:
    12V = 12V
    SW = 2.8V
    STB = 3.8V
    16V = 19V
    While the LED is red, in Standby, I get the following voltages:
    12V = 12V
    SW = 0V
    STB = 0V
    16V = 21V
    I have also tried removing the LED string from the PS, no change in behaviour. I have included some pictures of the various boards in the TV, if they are helpful at all.
    Any assistance would be appreciated. I am willing to dive deep on this repair, if needed, but I'd like some guidance...are there similar models with schematics I can refer to?
    Thanks in advance, Ivan
  • R_J
    • 9551
    Re: Hisense 50K23DGW
    The fact that you can remove the led string from board and get the same result would indicate the led string in the panel is open. likely one or more open led's in the panel. You can try checking the voltage ACROSS the le connector, I suspect the voltage to be higher than 200v when the tv is turne on, this voltage will likely drop below 200v after a few seconds due to OV protection.
      1) Please attach good clear pictures of the v=backside of the TV showing all the boards so we can see how they are connected together.
      2) What Voltage do you get on the LED connector pins (connector in place) with ref to GND when TV is off and when TV is turned on, notes: you need to leave the test probes in place while doing this test.
      • Unspun01
        • Jun 2011
        • 349
        Sounds like failed backlight LEDs. Although I cannot recall if there was a blinking LED error code on the ones I fixed.
        Your 50K23DGW is very much the same as the non-smart version 50K20DG. LED light strings are very easy to replace on this TV when compared to Samsung or LG. Each LED strip is vertical and completely separable from the adjacent strip. They are all identical so no need to order two or three different types... If you order a replacement strip, get a couple - you may need more than one if a different strip fails in the future.
        You can replace a single LED in a string, but I have had to re-repair same TV for same problem with another LED 8 months afterwards.
        Not a difficult TV to fix if you're careful.
        • Jne2016
          Hisense 58r6e3 black screen dumpster dive
          by Jne2016
          Hello all,
          I was driving around and found a free hisense r6e3.
          I figured what the he'll I fixed a free tv before with a new lamp.
          So I plugged it in and got sound but no picture i see it light up though.
          I've tried using a flashlight to see a faint image no luck.
          I've tried unplugging a ribbon cable off the tcon board and the left side shows white when right is unplugged. All black when right is in.
          I saw a video were someone taped off some off the ribbon and it worked but I don't know how you find which pins to block off. And if...
          07-18-2024, 12:15 PM
        • Coolgoodman
          Faulty Hisense 85Q6NAU TV
          by Coolgoodman
          85” Hisense TV
          Greetings,
          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
          Dear TV technicians of forum, I hope this message finds you well.
          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
          07-24-2025, 03:02 AM
        • ShahZaib Ghumman
          Can I Swap Screens Between Two Hisense 75” QLED TVs?
          by ShahZaib Ghumman
          Hey folks,
          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
          03-25-2025, 10:59 PM
        • nono34
          Hisense stuck in Colors cycle like test pattern.
          by nono34
          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
          10-24-2024, 04:31 PM
