Remove rear panel Sony Bravia KD-65X7500F
  • viewerau
    • May 2020
    • 315
    Re: Remove rear panel Sony Bravia KD-65X7500F
    Sorry to be a pain again, but is checking all fuses on the control board the last thing before getting another board?
    Cheers
    Signature:Seemingly hopeless tv fixer
      Not much else you can do with minimum service info of the main board.
      • viewerau
        • May 2020
        • 315
        Thanks, do you mean that Sony does not make that information available for us to see.. cheers
        • viewerau
          • May 2020
          • 315
          I have bitten the bullet and bought a used main board Is there something I should do to protect it whilst replacing it. IE disconnect anything(other than have it off and disconnected from the wall) before doing so.
          • viewerau
            • May 2020
            • 315
            Success, 2nd hand main board has now brought new life to the Sony.
            Fitted it this afternoon, inserted the USB stick with the latest software/firmware ready to go.
            White light at bottom came on white, flashed for a while, it turned to green, and then sat there with the white light flashing. From memory I had seen this pattern when it has done an ota update, so I left it alone. About 10-15mins later the scrolling android startup screen splashed up, and from there all normal things were available.
            I ejected the USB and tried turning the tv on/off a few times and all is good.
            I'll refit the back cover panel over the next few days, and all should be good
            Many thanks to all those people here whom have assisted me, and without all your support, my outcome would never have been achieved.
            Thanks everyone...
              Thanks for feedback.
              I stop Automatic OTA updating, regular updating, I will wait a few months then look on line to see if many people has issue with new update or not. I had a few TV's in the Video lab that had lots of issues that were not there before updating.
              If the TV works fine and fit what I need then I do not update them.
              • viewerau
                • May 2020
                • 315
                Thank you...I just did the software update as the tutorial said this must be done each time a main board is changed. I do take your point in regards to waiting for others to use any updates, so that problems are not yours straight away
                • viewerau
                  • May 2020
                  • 315
                  Just a little feedback ...all still working well... Thanks
                    • 12331
                    • U.S.
                    #149
                    Good news another save. +10 on Budm's advice about stopping auto updates.
                    • guidodroid
                      Bad Panel in Sony Bravia X850G
                      by guidodroid
                      Hello all,
                      I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                      It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                      Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                      The issue is not as bad as others that I've seen around, but is indeed noticeable...
                      03-19-2022, 12:08 PM
                    • howardc64
                      Best method to remove Samsung screwless rear panel
                      by howardc64
                      I've done a few of these. Using Samsung Service Manul method always result in some broken bits and the snap lock metal wire always gets bent and not reinstall as nice as original. After reinstall often have some pops and clicks. This is the best method I found so far. Pull the wire out instead
                      https://youtu.be/paYZAc1rcWs?si=GHdTOv5ySIJgjZOC&t=82
                      Here is a pic of how the hook on the wire locks
                      Stil ended up with a couple of small broken bits on the bottom haha. But the wire stayed perfectly straight and seems easier/less forceful. Fishing...
                      10-12-2025, 07:52 PM
                    • m4a2t0t
                      Sony Bravia 75X850C panel
                      by m4a2t0t
                      After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                      Does Sony epoxy all their panels or just the expensive ones?
                      12-07-2023, 05:43 PM
                    • JUCaESAl
                      Sony bravia KD-65AF9
                      by JUCaESAl
                      Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                      Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                      10-20-2025, 04:03 AM
                    • swrb898
                      Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                      by swrb898
                      What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                      Problem:
                      Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                      My troubleshooting got me this far:
                      With the left-hand TCON to bottom-board ribbon cable...
                      12-28-2021, 08:12 PM
