LG 60 Plasma missing 15V Z-SUS
  • grimmi40
    • May 2020
    • Deutschland
    I have a LG 60" plasma TV model 60PH6608.
    problem: relay clicking after plugging in the power cable.
    The power supply is connected to the z-sus and then to the y-sus.
    I unplugged the connection between z-sus and y-sus
    --> relay clicks only once and tv stays on (no protection mode)
    --> I measured a shortage on the y-sus between vs and gnd.
    I continuied checking the voltages from the z-sus to the y-sus.
    On the 15V line I only get about 3 volts.
    I think the first step is to check, why there is no 15V from z-sus to y-sus.
    Where can I start checking the z-sus ? (no visible damages)
    greetz
    - power supply EAX64880002 (all voltages o.k. (VA=55V, VS=203V, 5V))
    - z-sus-board EAX64789601 (VA=55V, VS=203V, 5V, 15V (only 3
    - y-sus-board EAX64789501
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 60 Plasma missing 15V Z-SUS
    Send a clear picture of the bottom side of the board.
    • mmartell
      • Oct 2013
      • 3189
      The 15v doesn't go from zsus to ysus, it goes from ysus to zsus. Start by inspecting the transformer joints on the underside of the Ysus.
      That 15v line is sometimes run through the control board. Check to make sure you have good contact with those lines if in fact that's the case here.
      • R_J
        • Jun 2012
        • 9625
        I do believe the +15v comes from the Ysus board, T251 is the transformer, and D590 is the supply for the +15v via IC555
        I suspect the Vsc is also missing
        • BigPete
          • Jul 2012
          • 76
          • New Zealand
          https://www.badcaps.net/forum/showthread.php?t=69738
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • Salvatore057
            plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
            by Salvatore057
            I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
            Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
            I am lost, should I change the YSUS board? Is the YSUS board damaging...
            04-29-2018, 01:29 PM
          • alfredomfr1
            TV Plasma LG 60PN5000 ZSUS 15v missing
            by alfredomfr1
            All Voltages are OK except ZSUS 15v.
            YSUS board disconnected still 15v missing.
            ZSUS was replaced: 15v missing.
            Any help will be appreciated...
            04-29-2022, 11:26 AM
          • ugamazing
            820-02020 PPBUS_AON missing
            by ugamazing
            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
            02-05-2025, 04:21 PM
          • jpreza
            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
            by jpreza
            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
            Looking at the card, it appears to be missing the following:
            1x 1.0uH inductor - orange square
            2x...
            11-01-2024, 10:54 PM
