Samsung UE32D5520 buzzing PSU, no picture
  • fejlong
    • Dec 2013
    • 55
    • United Kingdom
    Got this nice monitor for a while now, I struggle to make it work again, and I read that here might be some very nice people that could point me in the right direction to repair it.
    Under power the backlight won't come on, a buzzing sound starts and then fades away after a few seconds, then it starts again. Can't tell exactly from where, but I think it's the transformer in the middle of the power supply board, or around it.
    The red LED in the front of the tv flashes five times, then 2-3secs off. Probably this is an error code, cant find a service manual to look it up. Are some samsungs simillar in opration, ones error code will be the same as other model's error code?
    I am suspecting that the power board is faulty, but I might be worng.
    If the mainboard is disconected from the power board the intermittent buzzing sound turns into a more finer continueos buzzing. The cable between the LED board and power supply board still connected at this point. Voltages at CNM803 are 12.83V(13V) and 5.32V(5V). There are two main capacitors on this power board voltages are 347V is this high enough?
    any help would be apreciated,
    Re: Samsung UE32D5520 buzzing PSU, no picture
    Pictures are too dark for me to read anything on the board.
    Please provide straight shots pictures of the whole top and bottom side of the power supply board.
    What is the P/N of the power supply board? BN44-?????
    • fejlong
      • Dec 2013
      • 55
      • United Kingdom
      Board is BN44-00460A
      These are the best pictures I can take with maximum light that I have.
      • R_J
        • 9588
        You could try measuring the voltage on CNL802 since the problem is likely with the backlight, Check it on TOP1+ when you first turn on the tv. It should be around 148vdc
        • fejlong
          • Dec 2013
          • 55
          • United Kingdom
          on CNL802 reference to ground
          1.TOP1+ 118V,
          2. N.C.
          3. TOP1- 67V,
          4. N.C.
          5. TOP2+ 67V,
          6. N.C.
          7.TOP2- 18V
          8. N.C.
          9. IF2
          10. IF1
            Disconnect the LED connector form the power supply board, leave the meter connected to TOP1+ and chassis GND then turn on the TV to see what Voltage reading will be.
            • fejlong
              • Dec 2013
              • 55
              • United Kingdom
              With the LED connector disconnected on TOP1+ the same voltage can be measured. Not on the rest of the pins though.
              The TV cannot be turned on. It is digital touch buttons and doesn't seem to respond to them.
              As the cord is plugged in, red LED blinks a few times and goes out.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Led voltage is givenon the power supply board as 148V @ 290mA.
                What dc voltage do you have beween the two legs of CP814S. Be careful that your meter leads do not slip off the capacitor legs when taking the measurement.
                What is the voltage at CNL802 PIn1 at switch on. It may go higher than 118V then drop quickly. The min/max function on your meter would be useful for catching a spike in voltage.
                • fejlong
                  • Dec 2013
                  • 55
                  • United Kingdom
                  DC voltage on CP814S is 347V
                  Voltage on CNL802 is around 104V at start-up and goes up to 118 in about two seconds. It is not higher than 118V, tried multiple multimeters, but with one of them, a fluke 113, the board behaves differently when connected to ground and pin 1 on CNL802. The difference is in the buzzing that becomes continuous and the fluke measures around 73V at this stage. The red LED blinks twice, pause, and repeats.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    I would have expected the voltage across CP814S to be closer to 380v - 390V and could explain why the led voltage does not boost to 157V.
                    What dc voltage do you have across the legs of CM852
                    What dc voltage do you have on Pin1 of IC9101 when you try bringing the set out of standby?
                    • fejlong
                      • Dec 2013
                      • 55
                      • United Kingdom
                      Voltage on CM852 is same 118V
                      I am manually trying to power up the board from CMN803 power on pin. Before power on pin 1 of IC9101 has 12.7V. After power on this voltage drops to almost zero, a few millivolts.
                      Also measured voltage on CP814S before and after power on and the voltage drops slightly 2-3V
                      Can these two capacitors be faulty, CP814S and CP815S ? They are connected in parallel
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        CM852 could well be OK. Under the 200V rating of the capacitor.
                        Pin 1 of IC9101 has 12.7V which is what would be expected but drops towards 0V when power applied. This does not appear to be correct. I would expect it to be 0V when the set is in standby and 12.7V when out of standby ie switched on. Can you recheck.
                        What voltages do you have on the pins of CNM803 in standby and when out of standby.
                        • fejlong
                          • Dec 2013
                          • 55
                          • United Kingdom
                          I re-checked and I confirm, standby 12.7V, power on drops close to 0V
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            So you are confirming that Pin 1 of SEM5025 (IC9101) voltage drops from 12.7V to 0V when you come out of standby ie turn on the set.
                            • fejlong
                              • Dec 2013
                              • 55
                              • United Kingdom
                              Yes
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                The 13.1V feed to Pin 1 of IC9101 is fed from Q9104 which is switched on/off by BLU_ON
                                Can you check the voltages at the connector as in post #12
                                • fejlong
                                  • Dec 2013
                                  • 55
                                  • United Kingdom
                                  No voltage on BLU_ON at connector if this is you question
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    BLU_ON should go from 0V towards 5V when the TV is turned on out of standby.
                                    • fejlong
                                      • Dec 2013
                                      • 55
                                      • United Kingdom
                                      I understand. So, if cord is plugged in(nothing else), 5V should be present and not 12.7V, right? But 12.7V is also present. Normally, if pin Power On/Off on connector CMN803
                                      is connected to 5V 12.7 should come alive, right?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Disconnect the mainboard from the power supply and connect the 5V to PS_ON which is Pin 14 of CNM803 using a 1Kohm resistor. That should bring up all the supplies and the backlights should also come on.
                                        Can you confirm Vamp, A5V, B5V, B13V are all correct and that you have 12V on Pin 1 of IC9101
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
