Samsung UE32D5520 buzzing PSU, no picture
  • fejlong
    • Dec 2013
    • 55
    Re: Samsung UE32D5520 buzzing PSU, no picture
    Connected PS_ON to 5V and there is 12.7V on Vamp, B13V and 5.3V on B5V. These voltages are here with or without connecting PS_ON to 5v. Backlight does not come on though. Voltage at CNL802 118V on both cases.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      What is the voltage at Pin 1 of IC9101 with the mainboard disconnected and the 1K resistor in place????
      • fejlong
        • Dec 2013
        • 55
        Main board disconnected, PS_ON connected to 5V through a 1k resistor.
        Voltages on Vamp and B13V are 12.7V
        Voltages on A5V and B5V are 5.3V backlight is off, won't come on.
        The same voltage readings can be measured even if PS_ON is not connected to 5V
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          • fejlong
            • Dec 2013
            • 55
            12.7V is on pin 1 of IC9101 with main board disconnected, with or without resistor connected.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #26
              With the same setup as above, ie mainboard disconnected and 1K resistor in place, what is the TOP1+ voltage when you turn on the power supply.
              • nomoresonys
                • 12081
                • U.S.
                #27
                Strange, maybe try with cable from powerboard to mainboard unplugged, use about a 1k resistor from BLU_ON pin to standby pin, see if you get backlights up.
                • fejlong
                  • Dec 2013
                  • 55
                  #28
                  Hi, thank you all for your replies. I got to the stage where I couldn't bare it anymore and I ordered a working power board. It arrived today, but makes the same silly noise as with the suspect power board. And it doesn't work. My next suspect is the back light LED's, anyone ever tried to repair such thing? Does it worth bothering? I will disassemble it anyway, but for the moment thus project is on standby.
                  • nomoresonys
                    • 12081
                    • U.S.
                    #29
                    Well being a 32 inch and if for my own use, I would probably throw in some cheap used backlight strips or replace the little leds individually which are not expensive but require soldering and getting the lenses back on correctly and turn the backlight setting down as far as tolerable to your viewing likes if that is whats wrong. With the used stuff it could go out again pretty quickly BUT then you get to fix it again, what else to do during quarantine?
                    • nomoresonys
                      • 12081
                      • U.S.
                      #30
                      Maybe do those suggested tests again with the new powerboard and see if anything reads differently.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • ohren
                        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                        by ohren
                        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                        The models launched in 2018 and 2019 respectively....
                        09-08-2023, 05:24 PM
                      • C152Heavy
                        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                        by C152Heavy
                        Summary for TL-DR readers:
                        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                        • Have obtained Samsung schematic & service documents - Can upload if helpful.
                        • Have read ALL applicable threads
                        • C1818 and CP820 replaced as low hanging fruit
                        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • ermals
                        Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                        by ermals
                        Hi all!
                        I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                        1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                        2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                        3. I've checked voltages...
                        08-01-2022, 10:35 AM
