Samsung Ln55b650t1f Part Identification
Re: Samsung Ln55b650t1f Part Identification
Interesting... can you check the four rectifying diodes on that power board? Wait until the big caps discharge first. If you can, either remove the diode from the circuit, or just lift one leg off first.-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
Voltage between filter caps
Power Off with Main Disconnected from PS: 387
Power Off All Connected: 168
Power On: Spikes to 387 and drops back to 168
Tested the SB and yes, same result. Steady at 5.18 with Power Off.
When Powered on, voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)...when the button is pressed and these voltages are bouncing around, the standby light turns off.
So right now we do not have steady Standby power supply output.Last edited by budm; 04-12-2020, 08:50 PM.Never stop learning
When Powered on, voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)...when the button is pressed and these voltages are bouncing around, the standby light turns off.Never stop learning
So what Voltage do you have on INV-ON and I-PWM pins when running the power supply board without connection to the main board but everything else are still connected? Do see the backlights come on?Never stop learning
INV-ON: 7.3
I-PWM: No wire in this connection
E-PWM: 4.9
Correct, the standby light will be on when the TV is OFF and turn off when the power button is pressed. It turns back on after about 2 seconds.Last edited by philtvman; 04-12-2020, 09:09 PM.Comment
Maybe unhook the tcon from mainboard, keep mainboard connected to powerboard, see if you get proper steady voltages there at your powerboard connector.Comment
Check cable from powerboard to mainboard, see if there are any dark or burnt looking terminals, can also check for continuity from end to end, Sometimes I use stripped bread ties so as not to spread out or distort the terminal ends.Comment
Reply above, meant to quote it youLast edited by philtvman; 04-13-2020, 02:52 PM.Comment
by captainKKKI need to replace the pictured small (3x2 mm?) Samsung LED strip component. I traced it the entire length of the first section of the strip. I assume it provides the positive voltage for the 2nd, shorter, plugged part of the strip. It's the one labeled 24V and scribed with 4E. AJ. Ideas for replacements, thank you.3 Photos
by MufasaHello,
I'm trying to identify a part from a 65" Samsung un65tu700dfxza main board. Does anyone know what this part is and where I may find a replacement?
Thanx... -
by Ado02Hello,
I'm seeking assistance with schematics, board view, or help with identifying the component in the picture. Even if this component is replaced, I have a suspicion that something else might be at play. Therefore, a board view would be greatly appreciated....-
Channel: Schematic Requests ONLY!
by Kaar3lTV: Samsung QLED QE65Q7FNAT
PSU: BN4400940A
MB: BN94-12832K
I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r... -
by marcinqHello,
I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....4 Photos - Loading...
