Samsung Ln55b650t1f Part Identification
  • philtvman
    • Jun 2016
    • 94
    • America
    Re: Samsung Ln55b650t1f Part Identification
    Originally posted by ngth82
    +1 to BudM and the big scary cap comment. It's no joke. Don't die.
    Just getting to my e-mail... standby goes down to 1.3V? STBY isn't loaded down when the TV is off (e.g it's within nominal), and shouldn't be when the TV is on.
    Edit: also, you are missing a few pin numbers... You have pins 1, 2, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23, 25, 27, 29, 30... where are the rest?
    Correct. When Powered on, standby voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)
    All the pins I left out are not wired, just open holes in the connector.
    • ngth82
      • Jul 2015
      • 541
      Interesting... can you check the four rectifying diodes on that power board? Wait until the big caps discharge first. If you can, either remove the diode from the circuit, or just lift one leg off first.
      -Thomas
      I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        Originally posted by philtvman
        Voltage between filter caps
        Power Off with Main Disconnected from PS: 387
        Power Off All Connected: 168
        Power On: Spikes to 387 and drops back to 168
        Tested the SB and yes, same result. Steady at 5.18 with Power Off.
        When Powered on, voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)...when the button is pressed and these voltages are bouncing around, the standby light turns off.
        Ah, so the standby light does not stay on solid then, that this important if, unless I read your post #1 wrong and thinking that the standby light stay on when turn the TV on and then goes off when TV is turned off.
        So right now we do not have steady Standby power supply output.
          So in self test mode (power supply board not connected to the main board) the PS-ON pin has the pull-up resistor to simulate PS-ON control signal and the PFC Boosted Voltage is working fine,
            So what Voltage do you have on INV-ON and I-PWM pins when running the power supply board without connection to the main board but everything else are still connected? Do see the backlights come on?
            • philtvman
              • Jun 2016
              • 94
              • America
              #26
              Are these the four you are referencing? Thank you for your patience!
              • philtvman
                • Jun 2016
                • 94
                • America
                #27
                Yes, the backlights all come on with the main board disconnected.
                INV-ON: 7.3
                I-PWM: No wire in this connection
                E-PWM: 4.9
                Correct, the standby light will be on when the TV is OFF and turn off when the power button is pressed. It turns back on after about 2 seconds.
                  • 12183
                  • U.S.
                  #28
                  Maybe unhook the tcon from mainboard, keep mainboard connected to powerboard, see if you get proper steady voltages there at your powerboard connector.
                    • 12183
                    • U.S.
                    #29
                    Check cable from powerboard to mainboard, see if there are any dark or burnt looking terminals, can also check for continuity from end to end, Sometimes I use stripped bread ties so as not to spread out or distort the terminal ends.
                    • philtvman
                      • Jun 2016
                      • 94
                      • America
                      #30
                      No change in voltages when the T-Con was removed from the Main.
                      Also thoroughly looked over the Main/Power cable, everything looks good there.
                      Thanks for your help!
                      • philtvman
                        • Jun 2016
                        • 94
                        • America
                        #31
                        Reply above, meant to quote it you
                        • captainKKK
                          Part identification for Samsung UN50F6300
                          by captainKKK
                          I need to replace the pictured small (3x2 mm?) Samsung LED strip component. I traced it the entire length of the first section of the strip. I assume it provides the positive voltage for the 2nd, shorter, plugged part of the strip. It's the one labeled 24V and scribed with 4E. AJ. Ideas for replacements, thank you.
                          10-25-2024, 04:18 PM
                        • Mufasa
                          Samsung un65tu700dfxza Part Identification
                          by Mufasa
                          I'm trying to identify a part from a 65" Samsung un65tu700dfxza main board. Does anyone know what this part is and where I may find a replacement?
                          Thanx...
                          03-11-2023, 04:37 PM
                        • Ado02
                          Samsung NP930XDB schematics or part identification
                          by Ado02
                          I'm seeking assistance with schematics, board view, or help with identifying the component in the picture. Even if this component is replaced, I have a suspicion that something else might be at play. Therefore, a board view would be greatly appreciated....
                          11-14-2023, 09:00 AM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • marcinq
                          Samsung UE60KS7000 No Standby Light
                          by marcinq
                          I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                          I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                          05-26-2025, 11:36 AM
