I need to replace the pictured small (3x2 mm?) Samsung LED strip component. I traced it the entire length of the first section of the strip. I assume it provides the positive voltage for the 2nd, shorter, plugged part of the strip. It's the one labeled 24V and scribed with 4E. AJ. Ideas for replacements, thank you.
Part identification for Samsung UN50F6300
Tags: None
Thank you. I am aware of all the places to replace the entire set of LEDs, but since every LED string tests good, I want to get this one last strip working so I can test both channels of its power supply. Any idea if what the pictured component is?. Most new replacement sets, do not have these three components on the first half of each strip, so may not be compatible with my power board. Currently, only 4 of the nine led rows illuminate, with the 15th pin of the power board's LED connector showing ground. Ideas?Comment
As far as I can determine, the component in question here, works with the other two 12 volt components to regulate the voltage / current to the second half of each LED strip. Therefore, the second half of one row will not work unless I can identify the proper component replacment. Also, a complete LED set replacement is likely not going to work without these component regulators on the LED strips, because the power supply will not start the second channel LED power circuit. Thus I cannot find any suitable zenor diode.Attached Filesif you find these attachements useful please consider making a small donation to the site
by edugimenoHi There!
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by MufasaHello,
I'm trying to identify a part from a 65" Samsung un65tu700dfxza main board. Does anyone know what this part is and where I may find a replacement?
Thanx... -
by Ado02Hello,
I'm seeking assistance with schematics, board view, or help with identifying the component in the picture. Even if this component is replaced, I have a suspicion that something else might be at play. Therefore, a board view would be greatly appreciated....-
Channel: Schematic Requests ONLY!
by Baludoki80I have a wrong motherboard,does not switch on,no power.the framed part heats up,and the smd market is RUA3 but I couldn't find this part.I search schematic thank you...
by Viktor ÁrvaiHi !
I would need some help in part identification , on a GH53G-LA-L191P motherboard , i have downloaded a boardview file from here for LA-L191P there are some difference but essentialy its the same on this file it shows prm6 i would like to know the value of that resistor i think.
Thank you !... - Loading...
