LG 42LD450-UA Powerboard replaced and still no power
  • Betviper
    • Jan 2019
    • 10
    I narrowed the issue down (so I thought) to the powerboard. I purchased one online and installed it but still no voltage coming out the pins. I have checked the LEDs with an LED tester I purchased and they test good. I put the TV aside for quite a while but with this Corona crap I have some free time. I am by no means an electronics repair person but I do enjoy fixing anything and everything. I am wondering if the board I bought online is defective. I found this capacitor (guessing that's what it is) and it has 79v on one side and 0 on the other. Everything I have tested on the primary side of the board seems to be ok as far as I can tell. This capacitor that I am suspect about goes from the primary side to the secondary side of the board. Curious if I am right thinking it's bad since there's voltage one one side but not the other. Here is a pic of the part in question. Thanks in advance for any advice.
    • 12331
    • U.S.
    Re: LG 42LD450-UA Powerboard replaced and still no power
    Maybe put your original board back in and test that capacitor, see if it reads the same.
    • R_J
      • 9625
      When you are measuring the 79v (ac? dc?) across that cap you are measuring ground cold ground to hot ground. The cap is fine.
      Are you getting any standby voltage on the secondary?
      • diif
        • Feb 2014
        • 6978
        • England
        Your TV doesn't have LED backlights, it has CFLs, no you won't have voltage both sides of that cap.
        • Betviper
          • Jan 2019
          • 10
          It was 79v AC. Maybe it's the beers but I'm not sure what you mean by "ground cold ground to hot ground". I measured it with the black lead on ground and the red lead on each leg of the capacitor. I tested other capacitors and they had voltage on both legs. This was the only one that did not. No standby voltage on the secondary at all.
          My LED tester lit up the back lights and according to LGs website "LG 42” Class Full HD 1080p LCD TV (42.0” diagonal), 42LD450 +6 ... This energy efficient TV uses LED backlighting to deliver a brighter and more vivid picture." I've seen wrong info on manufacturers websites before though.
            • 12331
            • U.S.
            How bout some good clear straight on pictures of each board and one of the whole back to see how they are connected.
            • R_J
              • 9625
              This power supply/inverter board is for CCFL Lamps. If you believe the panel has led's you are wrong. The voltage output from the two transformers T703 & T704 is high frequency high voltage AC It will not operate LED's
              The power supply has a primary side that is connected to the A/C line (see that dotted line on the board) that seperates the primary (HOT) side from the secondary (Cold) side. It is isolated from the a/c line so when you touch any exposed connections like the input jacks, you dont get a shock.
                You should recheck your FULL TV model number, your pictures in your post #1 clearly shows TWO HIGH VOLTAGE inverter transformers.
                https://www.badcaps.net/forum/attach...5&d=1586026005
                Please us pictures the whole back side of the TV showing all the boards.
                https://www.shopjimmy.com/lg-eay6086...upply-unit.htm
                  • 12331
                  • U.S.
                  • flibidy
                    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                    by flibidy
                    I have here a Magnum IA.100 which belongs to my parents.
                    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                    What Ive done........
                    01-01-2025, 01:26 PM
                  • eccerr0r
                    inverter H tree driver imbalance in an AC inverter
                    by eccerr0r
                    My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                    11-16-2025, 12:34 PM
                    by momaka
                    03-15-2023, 10:17 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • Vahalaru
                    Visio E600i-B3 will not power on.
                    by Vahalaru
                    [B]Background[/B]
                    I recently fixed our Samsung black screen of death by watching YouTube videos and reading through previous threads. Removed a few ceramic capacitors and fixed a short on the back side of the tcon board. So my father and law asked me if I could try to fix his visio. He said that it wouldn't power on. When he first brought it to me I plugged it in and there was a standby light. When I hit the power button the TV booted up and everything worked. I hit the power button again and then I saw what he ment. Since then I have not been able to get it to power on or have a standby...
                    08-24-2021, 07:23 PM
