Blaupunkt 50" LED TV firmware please
    replied
    Re: Blaupunkt 50" LED TV firmware please
    check the electrolytic capacitors near the connector on powerboard, the one with the cable from powerboard to mainboard, maybe one or more bad/weak, also check all your solder joints on the underside of board, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
  • Hypercool
    replied
    Was interested to know what happened next, I have same TV but a weird problem ithink capacitor may have gone weak since it takes turning it on about 10 times for it to stay on and number of times seems to be increasing day by day , started to leave it on all night in radio mode, now it turned off and won't stay on beyond the logo, and doesn't get to blue screen if no signal
  • notallbad
    replied
    Well, decided to order another board so at least its up and running again. Eliminates power bd and panel etc..
    Accessing terminal via uart I am able to do nandbin, nandbin2 & nandbinall which gives me
    CIS_BFN.BIN
    KL.BIN
    MBOOT.BIN
    MBOOTBAK.MBO
    NAND.BIN
    NAND.DEF (only 1kb?)
    PART1.BIN
    RTPM.BIN
    UBI.BIN
    UBILD.BIN
    UBIRO.BIN
    Can these be used to create an .img file to recover the old board? or is there a way to create the restore .img file that I'm missing?
    Meanwhile I have ordered some parts to hack up an interface to the tsop48 nand in-circuit to attempt a dump to flash to the old board.
  • notallbad
    replied
    What I need to work out is how to change uart debug to off in Service Mode in debug mode.
  • notallbad
    replied
    I have at least now managed to connect via Usb-Uart, but what I do now is a mystery.
    Connecting with a blank USB stick gets the filenames its looking for...worth noting for future reference.
    FAC_BOOT_6308.cvt
    AllUpgrade_6308RTEC.bin
    AllUpgrade_6308_SOS.bin
    "BIST0-OK
    [123456789A][123456789A][123456789AB][123456789A]-5565
    U[AT][MB][start ub][620]
    U-Boot 2011.06-svn8303 (Sep 13 2014 - 11:34:21)
    DRAM: 256 MiB
    Hello U-Boot
    Stack Pointer at: 87e84440
    uboot held at [8f000000~90000000]
    Now running in RAM - U-Boot at: 871f0180
    NAND: DMA MODE
    [NC_Init] SDR NAND is detected
    CIS is found @Blk0
    FCIE is set to 54MHz
    128 MiB
    *** Warning - set default for mtdparts, using default environment
    Creating 1 MTD partitions on "nand0":
    0x000000640000-0x000000840000 : "mtd=2"
    Bad block table found at page 65472, version 0x01
    Bad block table found at page 65408, version 0x01
    UBI: attaching mtd1 to ubi0
    UBI: physical eraseblock size: 131072 bytes (128 KiB)
    UBI: logical eraseblock size: 126976 bytes
    UBI: smallest flash I/O unit: 2048
    UBI: VID header offset: 2048 (aligned 2048)
    UBI: data offset: 4096
    UBI: attached mtd1 to ubi0
    UBI: MTD device name: "mtd=2"
    UBI: MTD device size: 2 MiB
    UBI: number of good PEBs: 16
    UBI: number of bad PEBs: 0
    UBI: max. allowed volumes: 128
    UBI: wear-leveling threshold: 250
    UBI: number of internal volumes: 1
    UBI: number of user volumes: 1
    UBI: available PEBs: 1
    UBI: total number of reserved PEBs: 15
    UBI: number of PEBs reserved for bad PEB handling: 2
    UBI: max/mean erase counter: 1972/1944
    Volume not found!
    NAND read: device 0 offset 0x1c0000, size 0xa8
    168 bytes read: OK
    Volume "MPOOL" found at volume id 0
    In: serial
    Out: serial
    Err: serial
    Net: No ethernet found.
    Set MAC default
    MAC: 0x0: 0x30: 0x1b: 0xba:0x2: 0xdb
    It's the last cmd
    <NULL>
    No recovery information, needless to recovery
    Changelist: 00112233
    ============= set bootargs ===============
    Hit any key to stop autoboot: 0
    AC on
    Check USB port[0]:
    No USB is connecting
    usb init failed
    Error, couldn't init Lowlevel part
    Check USB port[1]:
    Host type:2
    scanning bus for devices...
    [USB] interface[0] conf:1 value 8:
    1 USB Device(s) found
    scanning bus for storage devices... bulk max packet size: ep 200 ep2 200
    max lun:0
    1 Storage Device(s) found
    ** Partition 0 not valid on device 0 **
    ** Unable to use usb 0:0 for fatload **
    reading FAC_BOOT_6308.cvt
    ** Unable to read "FAC_BOOT_6308.cvt" from usb 0:1 **
    ** Partition 2 not valid on device 0 **
    ** Unable to use usb 0:2 for fatload **
    ** Partition 3 not valid on device 0 **
    ** Unable to use usb 0:3 for fatload **
    ** Partition 4 not valid on device 0 **
    ** Unable to use usb 0:4 for fatload **
    ** Invalid boot device **
    reading AllUpgrade_6308RTEC.bin
    ** Unable to read "AllUpgrade_6308RTEC.bin" from usb 0:1 **
    reading AllUpgrade_6308_SOS.bin
    ** Unable to read "AllUpgrade_6308_SOS.bin" from usb 0:1 **
    UART BUS OFF!!
    mapi_uartdebug::Start 0x0 UartDebug_Start now here"
  • R_J
    replied
    I suspect the data you changed in the service menu is stored elsewere,(maybe in the same nand/spi/eeprom) and upgrading or replacing the firmware is not changing that data. That way when firmware is upgraded, important data is not changed.
  • notallbad
    replied
    No, still not fixed.
    Just stating what I provided for the file.
  • vinceroger69
    replied
    Originally posted by notallbad
    It was necessary to provide the Serial number from the label on the rear of the tv, the file received was only 34.3mb.
    you got the set sorted? i wonder if that was just like a software upgrade and not the full firmware files you need
  • notallbad
    replied
  • vinceroger69
    replied
    i wonder if yokoono or diah can offer any help as into why the firmware update is not working on your tv it should be the correct files as direct from umc etc odd its still boot looping though.
  • notallbad
    replied
    Yes I believe it is the correct board though would be useful to know whats on the reverse side of the board.
  • vinceroger69
    replied
    was that replacement mainboard in the link the rite one? it seemed a good price and was open too offers.
  • notallbad
    replied
    Fat32 formatted and only the update/ upgrade files is the normal procedure which is what I did, unfortunately not being able to access the menu i.e unresponsive, the only option was to plug in the usb stick and power on. As I've said, it appears to be doing the upgrade process and completing.
    I did check the usb ports havent got anything stuck inside making the tv think theres still a usb stick still mounted.
  • vinceroger69
    replied
    Yh, def removing the usb then powering off then back on.
    I havent tried another usb stick, currently using a 16gb stick, I guess thats a possibility, its not recognising the usb has been unmounted?
    This is the guide they sent me to update firmware
  • dick_barton
    replied
    I think the USB stick has to be formatted as FAT32 with only the update files on it.
  • notallbad
    replied
  • vinceroger69
    replied
    Wow, fast response, file received already.
    Unfortunately after it does the update the tv just power cycles (around 1 min) by itself with an unresponsive blue screen after the 'Blaupunkt' splash screen.
    Remote control and keypad has no effect.
    once the upgrade is done and the tv restarts are you taking the usb stick straight out im sure i had this issue and all it was i wasnt removing the usb stick once update had been done hence not booting fully
  • vinceroger69
    replied
    Mainboards seem quite cheap if this is the correct one i would make him a offer
    https://www.ebay.co.uk/itm/MAIN-BOAR...-/193352041711
  • notallbad
    replied
    No, but think they only have limited knowledge i.e providing fw only, perhaps staff levels are low currently.
    Been scratching my head all day over this.
    Unable to get a Uart connection via vga port so guess thats not wired out on the board and no other obvious connections.
    I also attempted to unpack the .bin file but only to get 2 header files, a lot of other stuff missing so unable to investigate the bin file either. Need to do more research on this.
    I do have a rasp pi so intend on trying to read the nand that way but at the moment have no way of connecting to the nand on board (a '360-clip' looks ideal but pricey) though I think a replacement board is in order to at least see it up and running again and to prove everything else is ok. I have no intention on attempting to upgrade the fw, thats for sure! Then again if I can get a board cheap enough I might be tempted or stoopid enough to!
  • vinceroger69
    replied
    pity neither sorted the issue out though did you mentioned you altered something in the service menu by mistake? so i would of thought reloading the firmware would of solved it
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • wattage
    AOC AG493UCX 49-inch monitor - Firmware request
    by wattage
    Hello Badcaps Community,
    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
    07-13-2025, 04:41 PM
  • legendkray
    BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
    by legendkray
    I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
    07-05-2025, 09:25 AM
