Blaupunkt 50" LED TV firmware please
  • notallbad
    • Oct 2012
    • 1190
    Re: Blaupunkt 50" LED TV firmware please
    Yes I believe it is the correct board though would be useful to know whats on the reverse side of the board.
    • vinceroger69
      • Mar 2012
      • 6714
      i wonder if yokoono or diah can offer any help as into why the firmware update is not working on your tv it should be the correct files as direct from umc etc odd its still boot looping though.
      • notallbad
        • Oct 2012
        • 1190
        It was necessary to provide the Serial number from the label on the rear of the tv, the file received was only 34.3mb.
        • vinceroger69
          • Mar 2012
          • 6714
          you got the set sorted? i wonder if that was just like a software upgrade and not the full firmware files you need
          • notallbad
            • Oct 2012
            • 1190
            No, still not fixed.
            Just stating what I provided for the file.
            • R_J
              • 9555
              I suspect the data you changed in the service menu is stored elsewere,(maybe in the same nand/spi/eeprom) and upgrading or replacing the firmware is not changing that data. That way when firmware is upgraded, important data is not changed.
              • notallbad
                • Oct 2012
                • 1190
                I have at least now managed to connect via Usb-Uart, but what I do now is a mystery.
                Connecting with a blank USB stick gets the filenames its looking for...worth noting for future reference.
                FAC_BOOT_6308.cvt
                AllUpgrade_6308RTEC.bin
                AllUpgrade_6308_SOS.bin
                "BIST0-OK
                [123456789A][123456789A][123456789AB][123456789A]-5565
                U[AT][MB][start ub][620]
                U-Boot 2011.06-svn8303 (Sep 13 2014 - 11:34:21)
                DRAM: 256 MiB
                Hello U-Boot
                Stack Pointer at: 87e84440
                uboot held at [8f000000~90000000]
                Now running in RAM - U-Boot at: 871f0180
                NAND: DMA MODE
                [NC_Init] SDR NAND is detected
                CIS is found @Blk0
                FCIE is set to 54MHz
                128 MiB
                *** Warning - set default for mtdparts, using default environment
                Creating 1 MTD partitions on "nand0":
                0x000000640000-0x000000840000 : "mtd=2"
                Bad block table found at page 65472, version 0x01
                Bad block table found at page 65408, version 0x01
                UBI: attaching mtd1 to ubi0
                UBI: physical eraseblock size: 131072 bytes (128 KiB)
                UBI: logical eraseblock size: 126976 bytes
                UBI: smallest flash I/O unit: 2048
                UBI: VID header offset: 2048 (aligned 2048)
                UBI: data offset: 4096
                UBI: attached mtd1 to ubi0
                UBI: MTD device name: "mtd=2"
                UBI: MTD device size: 2 MiB
                UBI: number of good PEBs: 16
                UBI: number of bad PEBs: 0
                UBI: max. allowed volumes: 128
                UBI: wear-leveling threshold: 250
                UBI: number of internal volumes: 1
                UBI: number of user volumes: 1
                UBI: available PEBs: 1
                UBI: total number of reserved PEBs: 15
                UBI: number of PEBs reserved for bad PEB handling: 2
                UBI: max/mean erase counter: 1972/1944
                Volume not found!
                NAND read: device 0 offset 0x1c0000, size 0xa8
                168 bytes read: OK
                Volume "MPOOL" found at volume id 0
                In: serial
                Out: serial
                Err: serial
                Net: No ethernet found.
                Set MAC default
                MAC: 0x0: 0x30: 0x1b: 0xba:0x2: 0xdb
                It's the last cmd
                <NULL>
                No recovery information, needless to recovery
                Changelist: 00112233
                ============= set bootargs ===============
                Hit any key to stop autoboot: 0
                AC on
                Check USB port[0]:
                No USB is connecting
                usb init failed
                Error, couldn't init Lowlevel part
                Check USB port[1]:
                Host type:2
                scanning bus for devices...
                [USB] interface[0] conf:1 value 8:
                1 USB Device(s) found
                scanning bus for storage devices... bulk max packet size: ep 200 ep2 200
                max lun:0
                1 Storage Device(s) found
                ** Partition 0 not valid on device 0 **
                ** Unable to use usb 0:0 for fatload **
                reading FAC_BOOT_6308.cvt
                ** Unable to read "FAC_BOOT_6308.cvt" from usb 0:1 **
                ** Partition 2 not valid on device 0 **
                ** Unable to use usb 0:2 for fatload **
                ** Partition 3 not valid on device 0 **
                ** Unable to use usb 0:3 for fatload **
                ** Partition 4 not valid on device 0 **
                ** Unable to use usb 0:4 for fatload **
                ** Invalid boot device **
                reading AllUpgrade_6308RTEC.bin
                ** Unable to read "AllUpgrade_6308RTEC.bin" from usb 0:1 **
                reading AllUpgrade_6308_SOS.bin
                ** Unable to read "AllUpgrade_6308_SOS.bin" from usb 0:1 **
                UART BUS OFF!!
                mapi_uartdebug::Start 0x0 UartDebug_Start now here"
                • notallbad
                  • Oct 2012
                  • 1190
                  What I need to work out is how to change uart debug to off in Service Mode in debug mode.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Well, decided to order another board so at least its up and running again. Eliminates power bd and panel etc..
                    Accessing terminal via uart I am able to do nandbin, nandbin2 & nandbinall which gives me
                    CIS_BFN.BIN
                    KL.BIN
                    MBOOT.BIN
                    MBOOTBAK.MBO
                    NAND.BIN
                    NAND.DEF (only 1kb?)
                    PART1.BIN
                    RTPM.BIN
                    UBI.BIN
                    UBILD.BIN
                    UBIRO.BIN
                    Can these be used to create an .img file to recover the old board? or is there a way to create the restore .img file that I'm missing?
                    Meanwhile I have ordered some parts to hack up an interface to the tsop48 nand in-circuit to attempt a dump to flash to the old board.
                    • Hypercool
                      • Nov 2022
                      • United kingdom
                      #30
                      Was interested to know what happened next, I have same TV but a weird problem ithink capacitor may have gone weak since it takes turning it on about 10 times for it to stay on and number of times seems to be increasing day by day , started to leave it on all night in radio mode, now it turned off and won't stay on beyond the logo, and doesn't get to blue screen if no signal
                        • 12206
                        • U.S.
                        #31
                        check the electrolytic capacitors near the connector on powerboard, the one with the cable from powerboard to mainboard, maybe one or more bad/weak, also check all your solder joints on the underside of board, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                        • TheUser
                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                          by TheUser
                          Hello to everyone ,
                          This is my first post here, and i would like to share with you a small story in case you can help me.
                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                          02-10-2024, 02:07 PM
                        • zklgfs
                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                          by zklgfs
                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                          08-11-2025, 02:14 PM
                        • gurj1979
                          Ubiquiti firmware help. US-8-150W POE
                          by gurj1979
                          Hi guys.
                          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                          Got New chip and writes good.
                          THE PROBLEM...
                          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                          Does anyone have a Good Firmware I can have?...
                          07-22-2024, 05:13 PM
                        • wattage
                          AOC AG493UCX 49-inch monitor - Firmware request
                          by wattage
                          Hello Badcaps Community,
                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                          07-13-2025, 04:41 PM
                        • legendkray
                          BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
                          by legendkray
                          I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
                          07-05-2025, 09:25 AM
