Sony KD-65XE9005 emmc .
  • leszekp
    • Mar 2017
    • 31
    • Poland
    Hi friends .I have this set absolutely death .Power is ok .I have not acces to boot1,boot2 and user via emmc programmer.Programmer logs said - user area protection -0x50 ,I don't know , how disable it.I can read emmc , erase , but can't write.EMMC is KLMAG1ENB B041.Can I disable this protection or I need change emmc?
  • CapLeaker
    Leaking Member
    • 8352
    Re: Sony KD-65XE9005 emmc .
    I can tell you as long as you can see and read the emmc, you should be able to write on it. At least I was always able to do so with my RT809H. What programmer are you using?
    • leszekp
      • Mar 2017
      • 31
      • Poland
      I am working with Ufibox ,RT809h too .
      • CapLeaker
        Leaking Member
        • 8352
        did you take the emmc off the board, or did you use wires soldered to the main board?
        Permanent Write Protect– Once the Permanent Write Protect is set, the protected memory region becomes read-only.
        https://cdn.badcaps-static.com/pdfs/...b5e44f9744.pdf
        so, you do need a new emmc
        • leszekp
          • Mar 2017
          • 31
          • Poland
          Connect via wires - direct emmc .
          • CapLeaker
            Leaking Member
            • 8352
            apparently I didn't into run this problem yet. Nothing you can do about it, besides copying the old emmc to a new emmc and put that chip back on the main board.
            You have to get the emmc very carefully off. You also need to reball the new emmc to put back on the main board, which is a pain in the butt.
            • CapLeaker
              Leaking Member
              • 8352
              here is one of my run in's with emmc's:
              https://www.badcaps.net/forum/showthread.php?t=74150
              • leszekp
                • Mar 2017
                • 31
                • Poland
                Thanks for help .I need replace ic , I think.
                • Lanparty
                  • Oct 2012
                  • 8
                  • Bulgaria
                  you just need the dump and flash it nothing else
                  • zomi
                    • Nov 2011
                    • 513
                    You will loose netflix when u do it, just be aware.
                    • EazyBone
                      Sony 55/65 A1E sony OLEDs EMMC dumps
                      by EazyBone
                      Does anyone know where one would get these dumps for EMMC? I have two 55/65 A1E sony OLEDs that likely need new EMMC chips but I do not have the file.
                      Is there a database or website you use to find these?
                      lotas anything in the Russian space websites you know of also?
                      10-31-2025, 06:22 PM
                    • saghi88
                      i need eMMC Dump for Sony KDL-55W805C
                      by saghi88
                      The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
                      This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
                      does anyone have the EMMC dump file?
                      Model: Sony KDL-55W805C
                      Mainboard: 1-980-805-31
                      EMMC: SK HYNIX H26M52103FMR
                      Display-Panel: T550HVF06.0
                      07-04-2025, 02:11 PM
                    • mhd bero
                      Sony KD-65XD8505 EMMC NEED
                      by mhd bero
                      Hi.
                      I'm searching for an eMMC dump for Sony KD-65XD8505
                      Motherboard: 1-980-832-11
                      THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
                      Thank you.
                      09-09-2025, 09:31 AM
                    • bbenalmadena
                      Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
                      by bbenalmadena
                      I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
                      I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
                      That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
                      08-30-2025, 10:40 AM
                    • 5m44p1x
                      Looking for Sony KD-55X750F EMMC dump
                      by 5m44p1x
                      The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
                      Model: Sony KD-55X750F
                      Mainboard: 1-982-454-11
                      EMMC: SK HYNIX H26M52208FPR
                      08-01-2025, 12:26 AM
