Dreamlink T1 plus two green lights, need working dump
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    I've got one oft these Dreamlink T1+ android boxes here with 2 green lights on the front as soon as one turns it on. There is no eeprom or spi flash on that thing, just one Essencore i3e-8gth2cmre eMMC that's it. I've did measurement's to no avail, there is no data of any kind going. So I took that eMMC off and put it in my BGA153 programmer. Aaaand? It's dead! Can't read anything from it. I actually turned that android box on without the eMMC and it behaves the same.
    I wonder if someone as any dump files from a working T1 plus?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Dreamlink T1 plus two green lights, need working dump
    Got a second one of these Dreamlink T1 plus today. Exact same thing than the post above. Both green lights are on and the eMMC is dead. Can't read nothing from it. Ugh!
      • 31294
      strange, are they over-volting or cooking the chip?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        It doesn't look cooked at all. Weird thing is that a lot of them Dreamlink T1 plus's fail with the 2 green lights on, but nobody seems to know why. Well, the 2 light's are on, because it can't see nor read from the eMMC.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Here it goes... dismantling time!
          I did some work on how to connect my RT809h to this Dreamlink using flying wires. Reason is, because I have one T1 plus in my possession that actually does work! I dind't want to chance anything to ruin the working one, because it doesn't belong to me. BTW, thanks to the owner for lending me his!
          I've made some pics and scribbled on them, so who ever wants to read their eMMC of the Dreamlink T1 plus can do so, without taking the eMMC off. It looks easy on the pictures, but just wait until you see the actual board. This is really small guys. Forget it without having magnification of some sort.
          Just put the RT809h in Auto ISP, 3.3V and you are good to go. It takes like 45 mins or more to read it.
          That's it for me today... next step is to program a new eMMC and solder that back on to the broken T1 plus.
          stj: I did measure about 3.37VCC and VCCQ on the working one.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            "Just put the RT809h in Auto ISP, 3.3V and you are good to go"
            Sorry, mistake... put the RT809h in Smart Identify > EMMC ISP> 3.3V, leave it on auto and read the chip.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              I proved today that reading the eMMC on the working T1 plus, doing a factory reset, reading the eMMC again, then flashing the first files I had read back to the eMMC, the box is still working and the factory reset was reversed. That was done with flying wires using the RT809h, I didn't take the eMMC off the board.
              Ran into a little snag, where I had burnt the 47k resistor on the D0 line (see pics above) and that changed it to 67k. The box wouldn't boot like that. That got me going all right, because I thought I had bricked it. Switched the resistor out and the box was working fine afterwards.
              The project is coming to an end for now, as I ran out of chip quick. So things have to wait for 3 weeks or so. After that I'll see if it is possible flashing the files I took from the working T1 plus to a 16GB eMMC and install that to one of the wrecked boxes and fire that up.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                Well, it is just about a month later now. Received the solder paste I needed to complete this project. Here is the verdict:
                SUCCESS!!!
                I've copied the image I took from a working box a while back to my salvaged 16GB EMMC (double the size), then I've soldered the flashed chip back to the board. Turned it on and it works!
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  The original Essencore I3E-86TH2CMRE 8gb EMMC is readable as a THGBM5G5A1JBAIR on the RT809h. Just fixed another one.
                  The dump of the EMMC is unfortunately too big to post here.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8352
                    Here is a CLEAN dump of the EMMC for a Dremlink T1 plus. Warning: This is not a file to put on a USB stick! You need a programmer and copy the .bin files directly to the EMMC either with flying wires or take it off / replacement EMMC / and the bga153 adapter and a RT809h.
                    The link to the dump is here:
                    https://drive.google.com/open?id=1bq...JV0U_aGzNuMWXT
                    Enjoy!
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      If one has a single red light and the unit wont boot, it's again something with the eMMC. I just repaired one by taking the eMMC off, read it and soldered it back to the board.
                      Another T1 plus saved.
                      • voip2014
                        • Dec 2019
                        • 2
                        I have two units with 2 green lights on both so just program the dump on the new chip and solder back and should be ok?
                        • voip2014
                          • Dec 2019
                          • 2
                          Also can someone give me a source to the 8GB chip, or capleaker if you can PM me with more info that would be great
                          • mmartell
                            • Oct 2013
                            • 3189
                            Nice work, CapLeaker. I have here a first gen Amazon Fire TV box that is stuck in an update loop. I suspect it's the eMMC as well but don't have the tools to repair it.
                              • 31294
                              you can probably do the fire-tv with a usb sd-card reader and a level shifter.
                              • mmartell
                                • Oct 2013
                                • 3189
                                You mean to program the emmc or in place of it ?
                                  • 31294
                                  to program it.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8352
                                    Probably the Essencore emmc is dead, which is 95% the case, I So you have to pull the spec sheet from the original and find a similar emmc if you need to replace it, just like i did. You cant put just some emmc in it, as some are faster than others. Depending on if you have the proper adapter for the programmer or not, you can either program the emmc off the board, or with flying wires with the emmc already soldered on board and the dump I provided. You do need an emmc programmer, I used the RT809h. The dump is not going to install via usb or something. I've got replacement emmc's from either salvaged units or Aliexpress. The thgbmfg7c1lbail worked perfect as a replacement and it had double the capacity, see post #8, first and second picture.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8352
                                      r
                                      No, with a dead emmc, there is no loop. it's dead. I think there is a corruption of some sort. I haven't come across a bad emmc that has a memory problem where just certain sectors die, like in a nand. The bad emmc's were so far always dead. No read or write etc. Open your box up and upload some pictures, so we can see what kind of flash is on there.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        r
                                        SanDisk SDIN8DE2-8G
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                          Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook Vero Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...
                                          09-07-2024, 03:10 AM
