Hi friends .I have this set absolutely death .Power is ok .I have not acces to boot1,boot2 and user via emmc programmer.Programmer logs said - user area protection -0x50 ,I don't know , how disable it.I can read emmc , erase , but can't write.EMMC is KLMAG1ENB B041.Can I disable this protection or I need change emmc?
Sony KD-65XE9005 emmc .
Re: Sony KD-65XE9005 emmc .
did you take the emmc off the board, or did you use wires soldered to the main board?
Permanent Write Protect– Once the Permanent Write Protect is set, the protected memory region becomes read-only.
https://cdn.badcaps-static.com/pdfs/...b5e44f9744.pdf
so, you do need a new emmcLast edited by CapLeaker; 03-12-2020, 01:21 PM.Comment
apparently I didn't into run this problem yet. Nothing you can do about it, besides copying the old emmc to a new emmc and put that chip back on the main board.
You have to get the emmc very carefully off. You also need to reball the new emmc to put back on the main board, which is a pain in the butt.Comment
here is one of my run in's with emmc's:
https://www.badcaps.net/forum/showthread.php?t=74150Comment
by saghi88Hello everyone,
The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
does anyone have the EMMC dump file?
Model: Sony KDL-55W805C
Mainboard: 1-980-805-31
EMMC: SK HYNIX H26M52103FMR
Display-Panel: T550HVF06.0 -
by mhd beroHi.
I'm searching for an eMMC dump for Sony KD-65XD8505
Motherboard: 1-980-832-11
THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
Thank you. -
by bbenalmadenaI have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...08-30-2025, 10:40 AM -
by 5m44p1xThe TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
Model: Sony KD-55X750F
Mainboard: 1-982-454-11
EMMC: SK HYNIX H26M52208FPR08-01-2025, 12:26 AM -
Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,... - Loading...
