Samsung UN55H8000AFXZA No Backlight, LED Strips OK
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    TV show image with the help of a flashlight but no backlight. I can confirm that all led are OK.
    CNL802A
    TV OFF
    0v
    TV ON
    Pin 11 and 12: 16v
    All others: 0v
    CNL802B
    TV OFF
    0V
    TV ON
    Pin 9 and 10: 16v
    All others: 0v
    Re: Samsung UN55H8000AFXZA No Backlight, LED Strips OK
    1) Do you get backlights if the cable between the power supply board and the main board is not connected?
    2) What did you use for ground for the meter when you measure 16V on the + pins?
    3) What are the Voltages of each pin of the connector of the power supply that goes to the main board? Notes: measurement is done with all cables in place and you need to put down the pin name for each pin so we can easily see what you have on each pin..
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      1- Not backlight with the cable disconnected.
      2- TV Chassis
      3-
      2 SD: 0.3v
      4 STT: 0.2v
      6 DATA: 0.1v
      8 VSYNC_IN: 3.2v
      10,12 LD: 3.2v
      14 BLUONOFF: 4.97v
      16 PWRONOFF: 3.3v
      18,20 GND:
      22 Vamp: 12.68v
      24 GND:
      1 LD: 3.28v
      3 CLK: 1.69v
      5 CONT: 0.07v
      7 GND:
      9,11,13,15,17 A13V: 12.68v
      19 GND:
      21,23 V AMP: 12.68v
      • R_J
        • 9551
        Monitor the voltage between chassis ground and J816 when the tv is first turned on, What is the voltage?
        • alfredomfr1
          • Oct 2014
          • 318
          • usa
          J816: 16.2v
          • alfredomfr1
            • Oct 2014
            • 318
            • usa
            J876, J864: 16.2v
            • R_J
              • 9551
              That voltage is low, What is the voltage across one of the main filter caps, CP811S or CP812S ? If this voltage is about 385vdc then the pfc circuit is working ok.
              • alfredomfr1
                • Oct 2014
                • 318
                • usa
                CP811S: 387v remember I can see image in the dark screen
                  What is the power supply board P/N? BN44-?????
                  • R_J
                    • 9551
                    I know that, but if the pfc was not working properly the led boost circuit would not be getting full voltage.
                    It seems like the problem is that the Led voltage is not being boosted to 34v. This could be caused by a bad led in one of the strings causing the led controller to shut down. 1 bad led in any of the 16 strings could cause the issue.
                    • alfredomfr1
                      • Oct 2014
                      • 318
                      • usa
                      Bn44-00740a
                      • alfredomfr1
                        • Oct 2014
                        • 318
                        • usa
                        R_J I already open the screen and tested all the LED
                        • R_J
                          • 9551
                          And how did you test all the led's?
                          You tested all the led's in all 16 seperate strings?
                          • alfredomfr1
                            • Oct 2014
                            • 318
                            • usa
                            With my led tester, every string same voltage: 30v
                            • R_J
                              • 9551
                              Check the fets Q9951 & Q9952, and the gate drive resistors, this is the led boost circuit, what is the number on the controller IC995?
                              • alfredomfr1
                                • Oct 2014
                                • 318
                                • usa
                                I will check the FETs tomorrow, thanks to budm and R_J for your help.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  not sure what power supply this is in this video but maybe worth a watch
                                  https://www.youtube.com/watch?v=2BCdAz0xE70
                                  • alfredomfr1
                                    • Oct 2014
                                    • 318
                                    • usa
                                    Q9951 and Q9952 OK, R9988 and R9958 OK
                                    IC 9951: NCP1034DG
                                    10k R9972 and R9973 are OK when tested out but R9973 only read 68 ohm in the circuit. All components on the picture are OK
                                      https://cdn.badcaps-static.com/pdfs/...2b3c1b8a2d.pdf
                                      Start checking to see if the IC has the VCC for it to run.
                                      • alfredomfr1
                                        • Oct 2014
                                        • 318
                                        • usa
                                        VCC: 11.92v
                                        FET Q9951 Gate: 76v
                                        FET Q9952 Gate: 16.7v
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • Kingfreddie
                                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                          by Kingfreddie
                                          Ok.. this is the story:
                                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                          This is kinda how it looked, just that mine were at the bottom of the screen:
                                          09-11-2021, 01:57 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
