TV Sharp AQUOS LC-60LE635E TV not power ON
  • markolino
    • Mar 2020
    • 109
    • Slovenia
    #81
    Re: TV Sharp AQUOS LC-60LE635E TV not power ON
    Nomoresonys:
    no my t-con original board is burnt out and not working.
    i bought chinese via aliexpress, and it didn't work properly. was not compatible with my TV.
    then I found a used original T-con board model tv LC60LE635E on the classifieds
    and this one works properly
    finally.
    another tip.
    do not buy a T-Con board from Aliexpress because they are not compatible with European TVs
      • 12276
      • U.S.
      #82
      I see, thanks for clarification, glad you got it working.
      • Alschepmist
        • Jul 2018
        • 70
        How do you forced the backlight to turn on?
        • Clifton11283
          • Aug 2022
          • 10
          • Malta
          #84
          I also have a Sharp LC-60LE63E TV with Power supply board DPS-162KP B. Set was not switching on and when opened found R7900, IC7903 (physically cracked) and D7908 burnt. All parts have been replaced but R7900 and IC7903 were blown again (with a large spark) when supply has been switched on. Any idea what the problem might be please?
          Clifton11283
            • 12276
            • U.S.
            #85
            make sure the diode is not in backwards.
            • Clifton11283
              • Aug 2022
              • 10
              • Malta
              #86
              Thanks for your reply.
              Diode is soldered correctly. The only mistake I did to be honest is that resistor R7900 was 1/4W instead of 1/2W.
              Clifton
                • 12276
                • U.S.
                #87
                can you post a good clear picture of the area?
                • Clifton11283
                  • Aug 2022
                  • 10
                  • Malta
                  #88
                  Please find attached a pictures of the power supply board.
                  Thanks again for all your help.
                    • 12276
                    • U.S.
                    #89
                    did you mean D7905 instead of D7908? D7905 looks a little beat up, did you test it or change it out?
                    • Clifton11283
                      • Aug 2022
                      • 10
                      • Malta
                      #90
                      D7905 when tested with a multimeter looks fine. The black stain visible on the picture is due the spark done by R7900.
                      Clifton
                        • 12276
                        • U.S.
                        #91
                        I would build one of these for a few bucks so your not constantly blowing components up, which wastes time and money: https://www.youtube.com/watch?v=k5oNQ1etN2c
                          • 12276
                          • U.S.
                          #92
                          I would set meter to ohm mode and check all the diodes and caps thats all not just the electrolytics on the board, all should read pretty high, report any with a low ohm reading.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #93
                            Can I see a photo of the other side of the board. Check the component with three legs under the heatsink.
                            • Clifton11283
                              • Aug 2022
                              • 10
                              • Malta
                              #94
                              Thanks!!
                              • Clifton11283
                                • Aug 2022
                                • 10
                                • Malta
                                #95
                                During the weekend will try to do this test and get back to you.
                                • Clifton11283
                                  • Aug 2022
                                  • 10
                                  • Malta
                                  #96
                                  Please find attached a picture of the other side of the PCB. Attached please also find the circuit of the area where I am having issues maybe it helps you in helping me identify where the problem is.
                                  • Clifton11283
                                    • Aug 2022
                                    • 10
                                    • Malta
                                    #97
                                    I have just found low resistance on capacitor c7901 and instead of 100pf it's capacitance is 30pf. Could it be this js the main problem shorting IC 7903 and R7900?
                                      • 12276
                                      • U.S.
                                      #98
                                      could very well be, change it out and see what you get, also measure it out of circuit if you didnt, to be sure.
                                      • sda
                                        • May 2015
                                        • 11
                                        • Greece
                                        #99
                                        A follow up on a similar fault -
                                        Error 2 X flash slow / 5X flash fast
                                        Check 12V on T-Con
                                        If varying from 6~10V replace Q7120 12V regulator on the delta board p/n KIA378R12P
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
