This TV was originally dead. I found the main fuse blown and a dead short across the main filter cap. Eventually traced the short to QL801 and QL802 which I replaced both (NCH, 500V, 4.5A). Now standby voltages are not stable. PFC voltage drifts 389-392V and both 13V and 5V have a slow oscillation (enough to turn on the TV for a few seconds and to read the peak voltage on my DMM). Don't have a scope. Closest schematic I can find online is for BN44-00498A.
Samsung UN50EH5300F BN44-00499A Power Supply Problem
Re: Samsung UN50EH5300F BN44-00499A Power Supply Problem
When I first plugged in the board, I did the backlight test and they came on momentarily. I opened up the the panel and confirmed all the backlights are working. I did check a few caps near the shorted FETs and they tested good. I also powered the backlight from the led tester and the tv was showing the logo and rebooting but likely from the oscillating supply voltage. The voltages are being measured with the main board and backlights disconnected.Last edited by neilc6; 02-23-2020, 02:43 PM.Comment
Well, you ha e to figure out:
A: is there too much current being drawn
B: can the voltage rail deliver enough current
You could disconnect the suspicious voltage rail and power it from a different supply.Comment
The fastguide indicates a 5sec delay for the backlights to come on after the backlight "ON" signal is activated. What is the cycle time?
https://cdn.badcaps-static.com/pdfs/...3db525660a.pdfLast edited by dick_barton; 02-25-2020, 11:47 AM.Willing to help but I'm no expert.Comment
I ordered a new board since it is difficult to troubleshoot without a schematic and without a scope. It is cycling on both 5V and 13V outputs with both the main board and backlights disconnected. Probably every 5 seconds. The fast track indicates delay is the bl-on signal from the main board. Interesting observation that the pulled up ps_on signal is a steady 3.3V.Comment
Thats the VCC for the pfc circuit, The source for that voltage is from the standby circuit, CS807 supplies the feedback VCC voltage for the standby ic, The elec. cap next to it, CS821 is the filter prior to the QS802 which is the VCC switch.
Check the voltage on CS821.
This schematic is similar, CS803(schematic)=CS807(on bn44-00499), CS821=CP812, CS808=CS821, QS802 is the sameLast edited by R_J; 02-25-2020, 01:41 PM.Comment
I ordered a new board since it is difficult to troubleshoot without a schematic and without a scope. It is cycling on both 5V and 13V outputs with both the main board and backlights disconnected. Probably every 5 seconds. The fast track indicates delay is the bl-on signal from the main board. Interesting observation that the pulled up ps_on signal is a steady 3.3V.Last edited by dick_barton; 02-25-2020, 02:37 PM.Willing to help but I'm no expert.Comment
The large main filter cap is holding the charge so it is only varying slightly if the VCC for the PFC is cycling. Backlights aren't even connected so not affecting the circuit at all. Will check the caps on the PFC IC.Comment
Hello, can you tell me wich codes or nomenclatures are for the Transistors (or mosfets) identified as like QL801 and QL802, thanks i have the same error...Comment
Cap does look a little domed, you probably checked those 2 diodes there.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by sempreHi I'm trying to repair the Samsung lt22b300 power supply. I replaced the srtw6052 chip that was shorted together with the blown fuse and a blown 222 1kv capacitor.
Now if I check the output voltages they all seem ok, but as soon as I connect a load, led or mainboard, all the outputs become oscillating (backlight flashes).
To rule out problems with the LEDs or the main board, I tried to replace the power supply board (PD23A0Q) with a borrowed one from another working TV and everything works regularly.
I checked all the diodes and non-smd capacitors... - Loading...
