Samsung UN50EH5300F BN44-00499A Power Supply Problem
  • neilc6
    • Nov 2015
    • 1550
    This TV was originally dead. I found the main fuse blown and a dead short across the main filter cap. Eventually traced the short to QL801 and QL802 which I replaced both (NCH, 500V, 4.5A). Now standby voltages are not stable. PFC voltage drifts 389-392V and both 13V and 5V have a slow oscillation (enough to turn on the TV for a few seconds and to read the peak voltage on my DMM). Don't have a scope. Closest schematic I can find online is for BN44-00498A.
  • CapLeaker
    Leaking Member
    • 8133
    Re: Samsung UN50EH5300F BN44-00499A Power Supply Problem
    unhook the main board from the psu and plug the tv in. See if the back lights come on and measure what the 12V and 5 V rails do.
    • neilc6
      • Nov 2015
      • 1550
      When I first plugged in the board, I did the backlight test and they came on momentarily. I opened up the the panel and confirmed all the backlights are working. I did check a few caps near the shorted FETs and they tested good. I also powered the backlight from the led tester and the tv was showing the logo and rebooting but likely from the oscillating supply voltage. The voltages are being measured with the main board and backlights disconnected.
      • R_J
        • 9535
        Check (or better, replace) cp812 and I would also check CS807 and the cap next to it (CS821?)
        • neilc6
          • Nov 2015
          • 1550
          The small electrolytic caps CP812, CS807 and CS806 all test good out of circuit. Tested CP820, CL802 and CY8075 previously as good.
          • CapLeaker
            Leaking Member
            • 8133
            Well, you ha e to figure out:
            A: is there too much current being drawn
            B: can the voltage rail deliver enough current
            You could disconnect the suspicious voltage rail and power it from a different supply.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              The fastguide indicates a 5sec delay for the backlights to come on after the backlight "ON" signal is activated. What is the cycle time?
              https://cdn.badcaps-static.com/pdfs/...3db525660a.pdf
              • neilc6
                • Nov 2015
                • 1550
                I ordered a new board since it is difficult to troubleshoot without a schematic and without a scope. It is cycling on both 5V and 13V outputs with both the main board and backlights disconnected. Probably every 5 seconds. The fast track indicates delay is the bl-on signal from the main board. Interesting observation that the pulled up ps_on signal is a steady 3.3V.
                • R_J
                  • 9535
                  Did you measure the voltage across CP812?
                  • neilc6
                    • Nov 2015
                    • 1550
                    Voltage on CP812 is not stable and cycling between 1 and 12V as well.
                    • R_J
                      • 9535
                      Thats the VCC for the pfc circuit, The source for that voltage is from the standby circuit, CS807 supplies the feedback VCC voltage for the standby ic, The elec. cap next to it, CS821 is the filter prior to the QS802 which is the VCC switch.
                      Check the voltage on CS821.
                      This schematic is similar, CS803(schematic)=CS807(on bn44-00499), CS821=CP812, CS808=CS821, QS802 is the same
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        My thought is that if it's a 5sec cycle that it may well be a led problem which although they have checked out OK with the tester, may be failing due to the higher current supplied when being powered up by the power supply.
                        • neilc6
                          • Nov 2015
                          • 1550
                          The large main filter cap is holding the charge so it is only varying slightly if the VCC for the PFC is cycling. Backlights aren't even connected so not affecting the circuit at all. Will check the caps on the PFC IC.
                          • neilc6
                            • Nov 2015
                            • 1550
                            Here is a closeup of that section. CS821 has pads for a chip cap but isn't populated.
                            • R_J
                              • 9535
                              It might just be the picture but that one cap looks a bit dome'ed I had to guess I thought it was CS821, must be something else
                              • enigmaelectronica
                                • Jan 2020
                                • 6
                                • Guatemala
                                Hello, can you tell me wich codes or nomenclatures are for the Transistors (or mosfets) identified as like QL801 and QL802, thanks i have the same error...
                                  • 12137
                                  • U.S.
                                  Cap does look a little domed, you probably checked those 2 diodes there.
                                    09-07-2024, 05:50 AM
                                  • cheeky2
                                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                    by cheeky2
                                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                    06-15-2025, 05:12 AM
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                  • howardc64
                                    Samsung UN55JU650DF network/streaming problem
                                    by howardc64
                                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                    07-09-2025, 12:44 PM
                                  • sempre
                                    Samsung T22b300 power supply problem
                                    by sempre
                                    Hi I'm trying to repair the Samsung lt22b300 power supply. I replaced the srtw6052 chip that was shorted together with the blown fuse and a blown 222 1kv capacitor.
                                    Now if I check the output voltages they all seem ok, but as soon as I connect a load, led or mainboard, all the outputs become oscillating (backlight flashes).
                                    To rule out problems with the LEDs or the main board, I tried to replace the power supply board (PD23A0Q) with a borrowed one from another working TV and everything works regularly.
                                    I checked all the diodes and non-smd capacitors...
                                    03-08-2022, 05:51 AM
