Samsung UN43NU6950BXZA no sound, no picture nor backlight.
  • bdorset
    • Aug 2013
    • 30
    • St Vincent, Caribbean
    Disconnecting the cable that link the mainboard and power supply brings on the backlights. With PS and mainboard connected, when I press the power button the power_on/off 3.3V goes to power supply, The PS voltage goes up to 12.9V from 11.5V when that happens. Backlight does not come on. After about 10-15 seconds Power_on 3.3V drop to zero, power supply goes back into standby. I disconnect the panel same problem. The mainboard numbers are BN94-14106F
    BN94-14106F, BN97-15621C, BN41-02662A. Any suggestions, any service information?
    Re: Samsung UN43NU6950BXZA no sound, no picture nor backlight.
    How about the control Voltages on pins 2, 4, and 6 when main board is connected and not connected?
    Seems to be main board issue since the power board self test is OK.
    • bdorset
      • Aug 2013
      • 30
      With PS disconnected from mainboard:
      Pin 2 =3.06V
      Pin 4 =0V
      Pin 6 =3.61V
      With PS and mainboard connected and TV in on state
      Pin 2 =0V
      Pin 4 =3.38V
      Pin 6 =0V
      Voltages were measured on PS connector. NB that pin 4 on the PS is NC (not connected) to the rest of the circuit.
        • 12268
        • U.S.
        As Bud suggested, looking like a mainboard issue.
        • bdorset
          • Aug 2013
          • 30
          A closer look at the PS above show that the STB should be 7.6V and the ON= 12.35V. I measured STB=11.5V and ON=12.9V. Are those normal or it because the PS is not under full load because the TV is not coming on 100%?
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • gl4709
            Samsung un55cu7000d with backlight and sound No Video / Picture
            by gl4709
            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
            01-23-2025, 06:21 PM
          • LaPCon_IT
            Samsung UE50TU7099U no picture no sound, backlight present
            by LaPCon_IT
            TV has one combo board (VTT55UH160). Symptoms are like this.
            When part of the screen is disconnected (white part), it looks like this
            Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
            I haven't noticed any shorts on rails listed below:
            VGH - 30V
            VGL- -9V
            VAA - 14V
            VCOM - 5.6V
            STV - 11.95V
            LC1, LC2 - +30/-12V
            All CKV lines (no shorts between them) looks the same:
            I've tried to cover some lines with...
            12-15-2023, 03:55 AM
          • henry21347
            Samsung LN52B550K1F no backlight has picture has sound
            by henry21347
            Hi I have a samsung LN52B550K1F LCD TV. There is no backlight but I can see a picture under a flash light. The sound is playing as normal. I have attached the pictures of the boards.
            With my laptop connected to HDMI4 port, I tested the voltages of the connectors:
            Power board (BN44-00267B) to main board (BN97-03035M) connector (CN801):
            5V_DET 0.1V
            E-PWM 2.77
            I-PWM 0
            INV-ON 0.05
            13V 12.81
            5.1V 5.15
            SB 5.2V
            PS 1.22
            SYNC 1.74
            Power board to LED driver board (SSB520H18V01):
            VCC...
            12-23-2022, 12:29 AM
